Question about Refrigerators
When i press defrost button it stucks inside it, is it normal???
  • 8 Answers
Hi
If it is a manual defrost fridge with a push button defrost then yes the button stays in until it has finished the defrost cycle.
But as no model & make have been provided this is just a in principle answer.
Bryan
Posted on Apr 29, 2015
How do you manually defrost a Samsung RF261 refrigerator and how long should the defrost cycle last.
Defrost cycles in normal conditions can last from five (5) to 25 (25) minutes, depending on variables like humidity, runs times and how often the door is opened. Defrosting the unit manually as you've done is merely a short term solution as it recurs again over time. You should find out why it is not working automatically, as intended. This could be a problem with poor air flow (fan, blower or restricted air), a bad control, or even loose connections. Forcing defrost without correcting the underlying issue will not eliminate the problem.
Dec 06, 2014 | Samsung Refrigerators
Hoshizaki freezer stuck in defrost
most likely a fan not running or a bad defrost timmer. open door, press in and door switches and Feel or listen for a fan.. it is normal for ice to start to build on evaperator, this must be melted by a electric heating element when in its defrost mode..
Feb 01, 2014 | Hoshizaki Freezers
Microwave oven will not start but the light stays on even when door is open.
One of the micro switches in the door is stuck ( faulty ) there are normally 3 switches so after removing the lid open and close the door and you will see the door latches pressing in the button of the micro switch and one of them would indicate that one of the switches is not in line with the latch to press the button in or one of the micro switches has melted inside cosign the switch to release normally open or normally closed, you need a multimeter to test the switches in that case
Oct 07, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
No heat just a/c fan works new thremostat flushed heater core seems like everything under the hood is fine temp gauge is normal just no heat
There is a simple test you can do in case the blend door is stuck. On the climate control panel, simultaneously press the OFF and FLOOR buttons, then within 3 seconds push the AUTO button. It is best to do this with the engine warmed up, but you can do it without the engine running, just turn the key to ON position. It will cycle the mini computer for a few seconds, After it stops, press the defrost button. Might fix it for free.
Nov 05, 2011 | 1996 Lincoln Town Car
Volume is stuck, buttons on tv wont lower it and the remote will not lower it..anything i can check??
Sometime if a button is stuck it can lock up the processor and cause all the buttons connected to it to not function. Insure all buttons press and release normally. If all buttons appear to press and release in a normal fashion a trip to the repair center may be call for.
Jul 03, 2010 | Initial HDTV-320 32 in. LCD TV
Evaporator coils ice up after a few days and the refrigerator comparment only stops cooling. The unit is 2 years old. When removing the backing from the inside of the fridge and after thawing out the coil...
I have some information on your model and that would involve forced defrost by the service manual page 28 at bottom. How old is your Samsung? Forced Operation Function (Pull-down / Refrigerator Defrost / Refrigerator . Freezer-Defrost / Cancellation)
● This function enables a pull-down mode, a defrost mode for the refrigerator only, a defrost mode for the freezer and the
refrigerator at the same time, and a cancellation of this function.
● Press Power Freeze and Fridge Temp. buttons for 8 seconds simultaneously to get in the ready mode for a forced
operation.
● The display panel will return to normal after 20 seconds in the ready mode.
● At the ready mode, press any button(except Ice Type and Child Lock) once to start a pull-down operation, twice for a
defrost cycle for the refrigerator, three times for a defrost cycle for the freezer and the refrigerator, and finally four times
for cancellation of this function.
● Another way to cancel this function is to simply plug out and in the power cord.
1) Pull-down
1-1) At the ready mode, press any button once then the buzzer will beep (ON for 1/2 second and OFF for 1/2 second)
until this mode is cancelled.
1-2) At this pull-down mode, the compressor will start immediately (No 5 minute delay) and if the system is in the
defrost cycle, it will be cancelled right away.
note) If this pull-down mode begins right after the compressor was off, the compressor may not start to run due to an
overload condition.
1-3) At this mode, the compressor and freezer fan will operate continuously for 24 hours and the refrigerator fan will be
on and off according to the set temperature(34℉)
1-4) After 24 hour operation, the system will be cycled at -14℉ for the freezer and 34℉ for the refrigerator.
1-5) In order to cancel this mode at any time, select the next mode on the ready mode or power off the system.
2) Refrigerator Defrost / Refrigerator . Freezer-Defrost operation
2-1) At the pull-down mode, press any button again on the ready mode to begin the defrost cycle for the refrigerator.
2-2) The beep sound continues for 3 second at the beginning, then ON for 3/4 seconds and OFF for 1/4 second until
this mode cease.
2-3) After this operation, the system will come back to normal operation.
2-4) At this mode, press any button again on the ready mode to operate the defrost cycles for both compartments.
2-5) The beep sound continues for 3 seconds at that time, then ON for 1/4 second and OFF for 3/4 seconds until the
defrost operation cease.
3) Cancellation
3-1) At the R,F-Defrost mode, press ant button again on the ready mode to return to a normal operation.
3-2) Simply unplug the power cord, then plug it again to return to a normal operation.
Press both button for 8seconds at the same time Send maual in one moment, Thanks, Sea Breeze
Jan 20, 2010 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
KF48 Beverage Air Freezer permently stuck on "defrost."
Unplug the fridge overnight and defrost it completely. Ensure the thermostat is properly set.
If it does not restart normal function after you plug back, then there may be a fault concerning the digital control, in that case call the number listed on the owner manual.
Jan 06, 2009 | Beverage-Air 44.9 cu. ft. / 1271 liter...
GE Microwave TimeCook defaults to Defrost Auto
It sounds like your keypad (membrane switch) is failing.
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting. You can use it to test for a bad keypad.
If you'd rather have us fix it for you, we do that for $39.95 plus parts and you can visit us via our link her eon Fixya http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
I defrosted the fridge. Took 24 hours! but it won't go back on!
if u press the defrost button of the switch after some time the switch have to come to the original position it would have been stuck due to some problem do press it once more and it would be back to work have a nice day
Jun 27, 2007 | Avanti 310SST Compact Refrigerator
Refrigerators Logo
181 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
