Question about Dryers
How do I access the igniter, not heating - Dryers
  • Dryers Master
  • 5,323 Answers
See pics
how do I access the igniter, not heating - 25670953-hed3japwagud3imxwy3n1koj-1-0.gif
Posted on May 16, 2015
Tumbles but no heat, how do i check out the igniter?
Some dryers have an access panel below the door. If there is a panel and you can remove it, you will be able to observe the igniter. Turn on the dryer so it begins tumbling and demands heat. A good igniter will glow long enough to heat the thermocouple and turn on the gas valve (click). Igniters are rather delicate and can crack with age but newer ones are less likely to do this.
Apr 23, 2016 | Dryers
My dryer will not heat up Model #dpsr610ggwt what could be the problem?
If this is a gas dryer, it is probable that the igniter on the bottom got drowned. The access panel at the bottom can be removed to expose the igniter for service. There may be water damage to other parts of the igniter assembly as well
Apr 16, 2013 | GE DPSR610GGWT Dryer
There is no heat on any of the cycles.
Check Igniter, Igniter Sensor (Senses Igniter is glowing) & gas valve Coils. Remove Front or rear access panel to observe/access these items. Set heated dry cycle & start dryer while observing Igniter, should start to glow bright orange for several seconds, sensor should send millivolt power to valve coils that will CLICK opening valve producing blue flame for heat. If Igniter doesn't glow within a minute, its bad, If it glows & nothing else happens it's either Sensor or Coils are bad, check the coils by using Ohm meter across plug ends of coils, if bad you will get no reading on meter, coil is open & no good, or take both Sensor & Coils to repair shop and have them tested. All 3 are accessable thru access panel opening.
Feb 14, 2011 | Dryers
Dryer spins,screen clean,exhaust open blows good no heat
Check the coils on valve or the igniter. Access both thru Access panel on lower right of front panel. Set heated dry cycle & start, igniter should glow bright followed by a "Click" sound, which is valve opening. If it glows and no click, replace the valve coils (2 donut looking objects on top of valve). If no glow, replace igniter, usually just unplug to remove, carefully, they are ceramic and break easy.
Feb 13, 2011 | Maytag MDG2600BWW Gas Dryer
Sg7800 maytag dryer stopped giving heat
Sounds like burner not igniting. On front of dryer in the lower right there should be a gas valve/burner access panel. Usually you just have to pry out at bottom of panel & swing out and up to remove. This gives you access to valve coils and igniter. With panel removed set timer for heated dry and start dryer, observing first the igniter which should glow bright orange-red, then after a couple seconds you should hear a "Click" which is gas valve opening and a blue flame ignites for heat. If no glow is seen after a few seconds or at least a minute, igniter is bad, if it does glow and no click is heard from the gas valve, the coils (electro magnets) on the valve are bad, or the "Flame present" sensor is bad. Chances are it's either the coils or igniter.Try this on all heat settings, if you get heat at only one setting it might be in timer contacts, but not common. Again you can repair/replace both the igniter (usually just plugs into a receptical) and the coils (2 donut looking objects on the gas valve, replace both.) Access door may be on back if not on front, but normally their on lower right of front.
Feb 13, 2011 | Dryers
The dryer has no heat when turned on.
Check your coils & igniter. Access door usually located in lower right front of dryer. Remove (pry up & out from bottom of panel, if no screws, exposing burner assembly. Set dryer for heated dry and start, you should see the igniter glow bright orange (give it at least a minute) followed by a CLICK sound,(again, a few seconds) this is the coils opening the gas valve, followed by a blue flame for heat. If no glow, replace igniter. If igniter glows bright and no click, replace the coils.
Igniter is glowing and heat is building up in the oven but no fan
Turn the gas supply valve off to the oven.
Remove the oven racks and base to access the burner and igniter. Place a clamp on amp meter on one wire of the ignitor.
Turn the oven control on and let the ignitor heat up. If the amp draw is less than 3.0 amps,replace the ignitor.
Oct 28, 2009 | Tappan TGF657 Gas Kitchen Range
Fridgidaire stove
You probably have a week oven igniter. Unplug unit first!!
Remove oven floor. Remove flame spreader. Igniter is attached to side od burner tube. It removes with 2 screws. Remove drawer to access connections. New igniter will come with wire nuts. Cut wires at old igniter, strip back insulation and connect to new igniter. The 2 wires can go either way. Re-assemble and test.
Nov 10, 2007 | Ovens
Dryer spins but does not heat
It sounds like to have a bad igniter. In order for your dryer's gas valve to open,the igniter has to be functioning properly. This is a built in safety feature to prevent gas from flowing without ignition. The igniter is located inside the machine usually under the drum near the gas valve. If you can access the inside look for a glow after you push the start button. If there's no glow, your igniter is bad. I hope this helps.
Mar 30, 2007 | Frigidaire FullFGX831C Size Stack Gas...
Dryers Logo
66 people viewed this question
Top Dryers Experts
