My power button is not swicth on - Washing Machines
  • tom cassidy
    tom cassidy Apr 29, 2015
    Hi devi jeanne, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • Washing Mach... Master
  • 5,323 Answers
Power If your washing machine won't start, begin by looking at the power source. First of all, is the washing machine plugged in? If it is, has it tripped a circuit breaker or blown a fuse? Check and reset the breaker (or replace the fuse) if necessary.
Lid Switch The main control for the washing machine is the switch inside the lid. If this has stopped working for some reason, your washing machine won't start. It's not especially difficult to troubleshoot this on a washing machine. You might have to open the top to access the switch. With the power on, depress the switch and listen for a click. If you don't hear one, the switch MAY BE BAD and will need to be replaced. Confirm defectiveness with a multi meter checking for continuity OHMS. An open circuit reflects a bad switch..
If the switch works but the washing machine still won't start, check to see if your washing machine has a special fuse for the lid switch. It will usually be inside the control panel. If it's blown, you'll need to replace it before the washing machine will start.
Door Interlock The problem could be with the door interlock. If the lights come on but the machine won't start, this might well be the cause. This could either be down to the wiring that runs to the door interlock, or the door catch not activating the interlock itself.
Timer Knob Some models of washing machine use a mechanical timer knob and won't run until the water in the machine has filled to the selected level. If the knob doesn't line up properly with the graphics on the control panel, you can try to troubleshoot the washing machine problem by advancing the timer a little. When you've done this, pull it out a little way and see if the washing machine will start properly.
Push start switch may need to be tested with a multi meter for continuity OHMS should show a closed circuit when pushed in or turned on.
The start switch on some top load washers is often part of the timer and is activated by pulling out on the timer knob. Although not normally available as a separate part, the switch can be tested for continuity with a multi-meter. You will need to remove power from the appliance and then locate the correct timer contacts as noted on the wiring diagram. On some electronic controlled models, the start switch is a momentary contact type switch located on the control console. You can test this switch for continuity with a multi-meter when the push button is held in
Overheating If you've run several loads, one after another, without any problem but suddenly find your washing machine refuses to start, overheating could be the cause. The simple way to discover whether this is the problem is to give the machine ample time to cool down, say for a couple of hours, and then try it again. If it works fine, overheating has been the problem and you may have a motor with bad windings.
By the way my advice is free cuz God is good!
All washing machines use a motor that is responsible for spinning and agitating during the cleaning cycle. Many top load brands use a reversing motor which means the motor spins in one direction for agitating and another for spinning and draining. If the motor does not start, but makes a humming or buzzing noise then it may be defective. To verify if the motor is at fault, remove the drive and /or pump belts and then try to start the motor again. On direct drive models, you will have to disengage the pump and the direct drive coupling to the transmission. If the motor starts, then the problem is with the transmission or the pump and can be further diagnosed by reconnecting each one individually. If the motor does not start or continues to hum or buzz, then it will need to be replaced
Lastly CONTROL BOARD
If the control board does not provide the proper voltage to the drive motor, fill valve, drain motor or door lock then the washer may not start. The main control board on most washers is complicated and difficult to diagnose without proper test equipment and procedures. You can visually inspect the control for signs of electrical arcing or burned or damaged components on the board. You should use caution when replacing a control board as sometimes the burned components are caused by external component failures.
my power button is not swicth on - power-button-not-swicth-fgv1ctnzjgewe3hu2qpqylbk-3-0.jpg
Posted on May 08, 2015
Swicthed off with the remote last night, to day the red light on the left bottom side is off. Can't swicth on, the remote or the panel. help please.
Try unplugging it & while pushing the the main consul power button in for 30 seconds, that happen to me, it was just dead.. its like losing a friend, I was almost in tears, I did the unplug & hold power & it came back on. it might not work but its worth a try
Jun 01, 2015 | LG Televison & Video
Jaczzis as no on off swicth
I would wire it to allow (a) GFI and (b) Control of the Tub. Right now, you have to turn the timer on and that is not the smartest thing to do
Apr 15, 2013 | Cars & Trucks
Power button not working, no resistance on swith?
You need to replace power switch if they did not contact.What swicth is the deffect,the main swicth or the tack swicth the second power?
Jul 04, 2011 | Televison & Video
Not swicthing on when preesing the on button and jumpy picturce
trty to turn it on by the controller. hold the power button or push start twice and hold it the second time. if it dosent turn on you mite have a situation with the power suply. try moving it to another outlet to see if it is the outlet if not then it mite be the power brick.
Dec 11, 2009 | Microsoft Xbox 360 Console
Jose349, asked my epson r300 not turn-on with power button.
Open case, check the on swicth. Check electricity to front panel. Check voltage output form ps to board.
Jun 09, 2009 | Epson Stylus Photo R300 InkJet Printer
Power n
hi
look out for a power on button it should have a small icon like what your TV power on button has
Sep 05, 2008 | Toshiba Tecra 8100 Notebook
Swicth not working
power on/off button print is brake now then tell me what can i do to repair it
Mar 14, 2008 | Samsung SGH-V200 Cellular Phone
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
