I came home and found My receiver w2blown fuses.I replaced them,and got it off protect mode.amp engages but no sound.I don't have manual or remote
  • John Perdue
    John Perdue Apr 29, 2015
    Sony str-sr591
  • John Perdue
    John Perdue Apr 30, 2015
    Sony str se591
    Genius:
  • Audio Player... Master
  • 1,054 Answers
What brand/model are we talking about?
Posted on Apr 29, 2015
  • 3,957 Answers
You can Google search your manufacturer make and model and the word manual. If one is available, you can find it in the search results.
SOURCE: Onkyo Tx-v940 Receiver/Amplifier Protection Mode
Audio amplifier IC's damaged you need to change it.Good luck
Posted on Jun 11, 2008
  • 4 Answers
SOURCE: klh r7000 no sound
Like I wrote, I had a similar problem with popping and then no audio for an extended period of time. I found the solution on another site, http://dexsoft.com/blog/?p=15
Apparently the solder joints are weak, and just as the blog described when I opened up the receiver I saw the same scorch marks from overheating. Just as the blog described, I added solder to each of the joints in the photo and have had no problem ever since.
I am no solder expert, this is my 2nd time, but all I did is build up each of the joints and I have been listening to music, playing movies in surround sound with no problems, no popping for the last 2 weeks.
Posted on Oct 04, 2008
  • 3 Answers
SOURCE: amp comes on and goes
Do you still have the AVR1500? I have one with a bad tuner--and would be interested in purchasing your for parts. Let me know if you still have it and if you'd be willing to sell it.
Posted on Apr 29, 2009
barbu51
  • 566 Answers
SOURCE: my onkyo receiver (tx8511) keeps going to protect
Hi there
To answer your question;
Your amplifier goes into protect mode when it detects a fault or condition that could damage the speakers and/or the output stage.
Often caused by shorted outputs.
Although this does`nt tell you much on how to fix this problem, the best help i can give you at this point is to tell you to have it looked at by a repair shop.
Hope this help good luck
Posted on Apr 18, 2010
SOURCE: How do I reset from the amp protect mode Onkyo receiver TX-SR600?
How do I reset my amp / receiver from protect mode ?
Posted on Jan 29, 2011
My RX-V2095 Yamaha receiver won't power up.
Wont power up, or stuck in "protect mode"? Unplug the unit & let it sit for a couple hours, then plug back in & listen for a "click" a turn (power supply relay energizing.) If no lights & no click, the first place to check is the mains fuse. If the unit is under warranty - take to an authorized facility & they will take care of it for you.
Oct 20, 2014 | Yamaha Rx-v2095 7ch Flagship Home Theater...
Denon avr2312ci shuts off and blinks red
Yes that is why. The receiver is protecting itself from an un-stable load impedance which causes current/voltage spikes through the final amplifier components and proportionally through the input where the protection relay is (click),. Do not continue using the amp until you have repaired or replaced the blown speakers. A rule of thumb is to maintain 8 ohms on each speaker wire plugged into the amp. Keep that in mind or eventually you will damage it.
Jan 23, 2014 | Denon AVR-2312CI
Protect mode constant
doubtful, protect on a sony receiver usually means there is a short in the amp section
Feb 03, 2013 | Sony Ht-6600dp Home Theater In A Box
RX-V665 turns on for a second then turns off
don`t open it yet
check ur speaker wires, try disconnect all wires from back of unit and then try to turn on unit .
if it stays on whit no wires attached than u have short connection at speaker wires .
if doesn`t come on then try to fasten screws at back of the unit ,
may sound like BS but if amp board don`t have good ground connection it can go in protection mode happened to me on RX-V592
Dec 13, 2012 | Yamaha RX-V665 Receiver
Sony STR DE835 receiver - no sound from speakers and headphone jack
The problem is in the audio output semiconductors, they have shorted causing the fuses to blow and it is in auto protect mode to prevent further damage. I recommend a professional to assess.
Mar 10, 2012 | Sony STR-DE835 Receiver
May 07, 2010 | Onkyo TX-SR605 Receiver
My Sony XMGTR2022 goes into protect mode at
I discovered that there is a compatiblilty problem between the Bose receiver and the Sony amplifier. If I disconnect the receiver from the amp then the amp starts up normally. Apparently the receiver sends out a dc offset or a "thump" that the amplifier doesn't like and goes into protection mode. I solved the problem by putting a 1 second delay circuit between the receiver startup and the amplifier startup. A simple RC delay on the remote input to the amplifier solved the problem.
Sep 03, 2009 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
Diamond Audio amplifier 1200W
If the speaker wires touched and the protection circuit didn't engage quickly enough, the output transistors may have failed. This is the most common cause for an amplifier to go into protect mode.
If you disconnect the speaker wires from the amp and the B+ and remote voltage are above ~11 volts (place black meter lead on ground terminal of the amp when checking the voltage), and the protect light still comes on, the amplifier will need to be repaired.
Nov 25, 2007 | Car Audio & Video
Amp in protection mode
Disconnect all speaker wires and signal cables from the amp. If it powers up normally (doesn't go into protection), the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Nov 11, 2007 | AudioBahn A4401Q Car Audio Amplifier
41 people viewed this question
 Grubhead
Grubhead
