NOT A GOOD IDEA TO JUMPER THE THERMAL FUSE AS IT IS A SAFETY FEATURE. SOME OTHER THINGS U MIGHT TAKE A LOOK AT ARE:
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
SOURCE: location of thermal fuse on whirlpool estate gas dryer
if this is a gas dryer and the ignitor is working the thermal fuse is fine.need more info .dose the valve coils make any clicking noisecheck with ohm meter to see if coils open/also is gas on
SOURCE: Maytag Performa Pye2000ayw won't turn on-tried taping wires
If your dyrer has a thermal fuse, it will be on the blower housing (front), not on the heat element. It will be either white plastic os a button about half the size of other thermos. The fuse on the heat element will shut down the haet only. Hope this helps!
SOURCE: Thermal fuse in Maytag PYE2300AYW not plugged in
NO. YOU ARE OK YOUR DRYER SHOULD ONLY HAVE A HIGH-LIMIT AND A CYCLING THERMOSTAT. YOU CAN LOOK AT YOUR DRYER PARTS AT www.repairclinic.com ENTER MODEL NUMBER SCROLL DOWN ALL THE WAY CLICK THE RED 100 AND SEE ALL.
SOURCE: location of thermal fuse on leq9858 l dryer whirlpool
if this is a top load?if so remove the back panel and you will see the dryer heater box to your right,the fuse is on the left side of box top,the high temp thermostat is on the bootm left and should be replaced also,before you do thatmif you have a meter remove the 2 wires from the heating element and check it on omns,no meter?remove the 2 screws pull the element off and look to see if the coil is broke anywhere,let me know how you do-mkie
SOURCE: Thermal fuse in dryer keeps blowing out
Hi Janet Douglas
Check to make sure your vent is clear, this can cause the overheat problem and blow the thermal fuse.
Also check to make sure the blower is not full of lint also as this can cause the same problem you are having happen.
Another thought:
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element and thermal can burn out very quickly.
Please take time to rate me
Bud
