Question about Miscellaneous
I replaced battery in the remote, but it still doesn't work. Any ideas?
    Top Expert:
  • 75,571 Answers
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing each button on it at a time; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Posted on Apr 29, 2015
    Master:
  • 688 Answers
Clean the transmitter battery contacts real good, also tighten the connectors of the transmitter, you can do that by carefully bending them upward to where they will make a more firm contact with the battery.
    Master:
  • 996 Answers
Check battery connectors ,,,then micro switch
Vizio remote xrv1tv doesn' t work. it doesn't do nothing. i replaced batteries.what can i do? used to work perfect almost 2 years. do i need to set up the control? how? thanks
Check the remote control for its infrared emission. If found no infrared emission, check its battery compartment, and clean the battery contacts. If battery contacts have been accumulated with dust or dirt, the remote won't work, as there will be no supply to its internal circuit. http://electronicshelponline.blogspot.com/. Check this link. It has one post, that describes how to check and repair a remote control. Pull up older posts there.
May 05, 2013 | Televison & Video
Turn on but remote doesn't work
I would try new batteries first. If that doesn't help then replace the remote with a universal unit that you can program to work with your TV.
Nov 13, 2012 | LG 42LC2D 42 in. LCD HDTV
Just bought a Toshiba refurbished DVD/VCR player. The remote doesn't work at all. I've doublechecked the NEW batteries and tried a tip of pushing EVERY button with the batteries out. Any ideas
1) the batteries will be the same type and full charged
2) clean the contacts battery from dirty, dust, oxide or corrosion
3) retight the spring contacts battery with pliers for a GOOD contacts
4) open the remote.control and clean the keypads switch, from dirty, dust, oxide, Open contacts, or Bad contacts. they emite a good signal infrared from SYScon transmi vs Syscon receiver.
see the block diagram. If doesnot resolve the problem go to the repair shop TV for fix it.
God bless you
Jul 31, 2012 | Toshiba Televison & Video
Already replaced batteries still doesn't work?
Check the battery contacts for any rust or dust accumulated.
Mar 24, 2012 | Samsung BN59-00856A Remote Control
I cannot turn on my surround sound on my Philips MCD700 Stereo using the remote, any ideas???????
So are you saying the remote doesn't work or that the unit itself doesn't work? Walk over to it and press the power button.
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remotes", check the 'include description' box. Usually cheaper than the vendors.
Jun 28, 2011 | Philips (MCD700) System
My control remote doesn't work
Hi, first if remote doesn't work, try new batteries......
If new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
May 08, 2011 | LG 32LC7D Television
My remote wont work it says set 1
You can try this simple idea; to re-code the remote to your unit, press and hold 1 and ENTER/OK buttons together for 5 - 10 seconds, then release. This should restore the remote command to match the unit, and thus the remote should work. Failing that, replace the batteries in the remote with new ones, and repeat the above suggested procedure.
If the remote is triggering 'SET 1' on the unit's display, this simply means the remote code is different to the unit, and hence the remote requires a reset to restore control to it whenever the batteries are replaced. Easy enough to fix, doesn't take very long, and should not cost anything except some new batteries if required.
Apr 28, 2011 | Panasonic DMRES15 DVD Recorder
Miscellaneous Logo
43 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
