Question about Memmert UN 30 PLUS - Oven, Natural Circulation, Class E
The oven cannot maintain the temp at setting temperature. How to troubleshoot ?
Why does my oven thermometer read less than the temperature the oven is set at?
An oven doesn't go to the temp selected. That is the average temp. If you set it to 350, it may drop to 300, then to 400, but will maintain an average of 350. Without knowing your model #, it is hard to say. Some have anticipator (that anticipates the temp and controls the heater and the thermocouple that is trying to keep the temp steady. Some models have an adjustment at the oven switch (rear) that can be adjusted for temp up or down.
Oct 20, 2014 | Ovens
We have an electrolux E30EW85GPSS double oven. The lower oven appears to work properly. However, the upper oven will bring itself up to the set temperature but after reaching it, does not stay on and...
Hi
This means a loose/broken wire on the oven temp sensor or the sensor is bad and should be replaced. To solve this issue start by checking the oven temp. sensor for 1100 ohms, if the rating is more then that then check the control board however, as the issue is only with upper oven it is most likely that the temperature sensor is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jun 17, 2011 | Electrolux E30EW85GSS Oven
Oven won't maintain temperature
Replace the oven temperature sensor.
Apr 05, 2009 | Ovens
GE JKP26GOP1BG Electric Oven won't maintain temperature
You will need to replace the temp probe Call704-891-6557 we'll tell you how to do it safely.
Mar 14, 2009 | Ovens
Oven temperature control intermittent
gas oven?? i would replacethe bake ignitor, the most common issue with unit not holding temp.
Nov 22, 2008 | Kitchen Ranges
GE Spectra XL Oven does not maintain oven temperature
I have the exact problem. We had the ignitor replaced 2 already and it works for 18 months and stops. Occasionally, it the oven won't even start to heat. I am ready to throw it out.
Sep 14, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Memmert UN 30 PLUS - Oven, Natural Circulation, Class E Logo
291 people viewed this question
Top Memmert Home Experts
Donni Steen
Tom Chichester
Are you a Memmert Home Expert? Answer questions, earn points and help others
