Question about Flotec 1 - 1/2 Sprinkler Pump Composite Quick Priming High - Capacity 115/230v
How do I fix a sprinkler pump - Flotec 1 - 1/2 Sprinkler Pump Composite Quick Priming High - Capacity 115/230v
Why does my pump loose pressure
Sounds like your not using enough water, and or your pipes to sprinkler is to to small, causing pump to build up to cut off head. I cant lay my hands on a performance chart for your pump, but 60 psi cut off and 20 on sounds about right. Try running another tap when your sprinkler is running, and see if this keeps your pump running
Mar 25, 2015 | Utilitech 1-HP Cast Iron Convertible Jet...
Not putting out enough pressure or flow to pop up sprinkler heads
Have you fixed this problem?
Q? Did you replace an existing pump. And what was the model and did it work.
Q? If its the same size as the fp4032, has anything else changed? Is there a filter that needs checking.
hydraulically to work it out I need the distance from pump to water, height and size of pipe. Distance you are pumping too, height and size of pipe. And what the "four heads are"? Nozzle size etc. To work out a flow/pressure rate.
May 10, 2013 | Flotec Pump FP4032-10MK
Sprinkler pump will not turn off when timer is turned to off new timer, new relay
go back to the drawing board re read instuctions,or go to there web site a simple fix im sure.
Aug 12, 2012 | Flotec 1 - 1/2 Sprinkler Pump Composite...
I have a one hp AO Smith electric pump motor for my sprinkler system which is approximately 5 years old. Well point is clean and all sprinkler heads have been replaced. I am not able to get distance from...
If you replaced your sprinklers, did you use the same size nozzles as the original heads?
I need more information and I can help you with a well/sprinkler system problem.
Gary
Jun 18, 2011 | A O Smith Motors A O Smith 1hp 115/230v Ur...
I have an aquamate pump and when i connect it to a continuous sprinkler it stops and starts contiuously
The pump is putting out too much water for the sprinkler.
You can raise the pump shut off pressure at the switch until it is higher than the pressure that the pump runs at with the sprinkler operating. You should have a surge tank connected to the system to give the pump time to balance with the sprinkler.
You can use more water with the sprinkler. This could mean adding another sprinkler or increasing the nozzle size of the existing sprinkler.
Dec 05, 2010 | Garden
I have 1 and 1/2 horsepower sprinkler pump that wont prime. As soon as the end piece fills, it will empty if I open the end to the sprinkler.
I don't know what is your system set up. However, the system set up should be the following;
1. Your 1-1/2HP sprinkler pump must be installed at
a fix location nearest the water source. (Complete
with power and plumbing lines.)
2. At the end of the suction line is a vertical check
valve with strainer.
3. The suction pipeline must be connected to the
suction port of the pump.
4. At the discharge port, a flow control valve tee must
be installed. The flow control valve tee top is
covered with a plug, which serves as the priming
port when opened.
5. After the flow control valve, connect a short nipple
so that you can put a gate valve to stop the water
flow or allow the water to flow. You may connect
a pressure tank at this point or you may connect
the pressure hose going to the sprinkler.
6. To prime the pump, open the plug at the flow
control top. Fill it full with water, replace the
priming port plug.
7. Turn the flow control valve to full closed position.
8. From full close position, switch the power on.
9. The pump now run on and off due the pressure
switch setting. Slowly open the flow control valve
such that the water pressure remains steady.
10. Take note of the pressure.
11. Shut the power off, and connect the sprinkler
pump hose.
12. Put the power back on, and allow the pump to
run with the sprinkler.
Under this set up, you can run the sprinklers when your pump is running. Hope this will solve problem.
Dec 08, 2009 | Plumbing
Sprinkler pump quits after 30 seconds?
call the company you purchased it through...that would be a warranty issue...sounds like it is overheating.
Jun 11, 2009 | Flotec 1 - 1/2 Sprinkler Pump Composite...
Flotec Sprinkler Pump not priming
it might be that the pump is prewired at 230 volt and you are running a 115 power supply to it, if motor just humms and little water comes out this might be your fix
Mar 13, 2009 | Flotec 1 - 1/2 Sprinkler Pump Composite...
Flotec 1 - 1/2 Sprinkler Pump Composite Quick Priming High - Capacity 115/230v Logo
130 people viewed this question
Top Flotec Garden Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Ryan Ross
Level 1 Expert
Are you a Flotec Garden Expert? Answer questions, earn points and help others
