Question about Initial IDM-1731 Portable DVD Player with Screen
How can I get picture? I just have blue screen with a very small circle with diagonal line thru it
It has a red circle with a lock in it.so what am i suppose to do
Cannot use public WiFi networks. ' Android Forums
androidforums.com > Android Phones > Nexus 5Aug 23, 2015 - If you cannot see the Emoji it is the red circle with the line diagonally over it. Then last .... Similar problem for me and same padlock screen.
images for red circle with a lock in it
Sep 30, 2015 | Computers & Internet
White lines across tv screen
Without seeing the lines I can't be sure what your set has wrong, but here are a some possibilities:
If the lines are lines are confined to the top inch or two of the screen and the picture looks otherwise normal, the trouble is bad capacitors in the vertical output circuit. Fixable by replacing the bad parts.
If diagonal lines are across the entire face of the picture tube and the picture looks washed out, the trouble is often a bad capacitor on the 200-volt line to the picture tube. This may be on the main circuit board near the horizontal output transformer, or on the small circuit board plugged onto the end of the picture tube. Again, replacing the bad capacitor can fix this.
If your TV is actually an RCA, someone may have bumped a rear-panel adjustment. On the back of the TV near the bottom right are two small knobs. RCA left these adjustments exposed inside of putting them inside the set like other manufacturers. These sometimes get bumped if someone was behind the set cleaning, or if a pet got back there and hit them with a tail. The top knob adjusts focus, and the bottom knob adjusts something called G2 or screen voltage. If this gets turned up too high it can cause the faded picture and diagonal white lines. Turn the adjustment down until a black screen looks black instead of gray.
A bad picture tube or horizontal output transformer can also cause lines through the picture. If this is the case with your set, it's time for a new TV. The transformer is relatively inexpensive but labor costs aren't, and the repair bill may exceed $200. If the tube is bad, there's no point even considering repair. The tube cost alone exceeds the cost of new TV.
Hopefully your lines are easy and cheap to fix. Good luck, and thanks for using Fixya!
Jul 22, 2011 | RCA F35673MB 35" TV
Prevent 'flash' on Samsung ES20 camera?
If you press the button with the lightning bolt repeatedly, watch the screen for a picture of a lightning bolt in a circle with a diagonal line through it.
Dec 07, 2009 | Cameras
Sony 65" Rear Projection loses picture, then gets diagonal lines
This is common problem on this tv, picture tube is bad. Blue and green is more % bad.
Thank you
Aug 07, 2009 | Hitachi 51F59 51" HDTV Projection...
Red,green and blue lines across screen
I f these lines are slightly diagonal and they all showed up at the same time. you probaly have an open resistor in the ABL circuit. since your set is 13 yrs old, I would not put a penny into it.
You might take the front grill cover off and the panel behind it and find the little black box with 6 little controls 3 are for focus 3 are for screen turn the screen ones ever so slightly counter clock wise. the control in the middle is the green screen adjustment. If the green line goes away try the one labeled r for red and b for blue.
Mar 31, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Undo flash
On the back of the camera you should see a little picture of a lightning bolt. Click this multiple times and it will cycle thru the different flash settings. Look for the one where the bolt is in a circle and there's a diagonal line going across it. This means NO FLASH. Once you have set that it will prevent the camera from firing the flash.
Dec 30, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
Sony 65 inch screen tv
The lines you saw, i;m sure they are the ones called retrace lines but know the failure could be located on the red CRT board. Most likely the video amplifier is defective and not necessarily the CRT.
What is the model number of your TV?
Jun 17, 2008 | Televison & Video
Blue circle across top of tv screen & maybe some yellow
Good Day,
Does the blue spot have tin white lines?? Is there a picture behind the 'circle'? You may a blue crt (tube) problem.
Jun 06, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Largan chameleon
With the camera on, push the mode button 5 times. The window will show a square with a dark circle in it, and a diagonal line through. Hold the shutter button (that you take a picture with) down until the camera "beeps". This will erase all the pics in the camera. To erase the last pic taken, push the mode button 4 times. This gives you a square with a lighter circle and diagonal line - hold the shutter button until it beeps.
May 18, 2008 | Largan Chameleon Digital Camera
TV Comes On But No Picture
check for bad solder connections on the pc board and a posible leaky cap
Dec 06, 2006 | Philips Magnavox 20MS233S 20" TV
Initial IDM-1731 Portable DVD Player with Screen Logo
Top Initial Televison & Video Experts
mega_mind
Are you an Initial Televison and Video Expert? Answer questions, earn points and help others
