Question about Bang and Olufsen Beosound 2000 Shelf System
CD Player The CD well spin for 5 second and then stops.
  • jen123 Nov 15, 2007
    Same problem with my BeoSound2000. CD player begins to spin, then stops suddenly. Anyone out there with suggestions, advice? Estimated costs of repairs?
  • Anonymous Dec 13, 2007
    I have exactly the same problem, the system's been hanging on the wall unused for about a year or 18 months now because of this
Thank you for your reply.
BeoSound 2000 - The CD won't even spin now. The cover closes, the Number 1 for the track appears in the display, then the cover immediately reopens showing what looks to be something like this [ ] in the display.
Posted on Nov 15, 2007
Cd will spin for about 5 seconds and stop
The drive has failed. It can't read the disc.
Nov 20, 2014 | Audio Players & Recorders
How to fix a Sony 5-disc player that will continue to spin and not stop at any disc slot
There are opto's around the edge of the carousel so the machine can count it's position, maybe these are at fault
Sep 30, 2014 | Sony CDP-CE375 5-Disc CD Changer
My Craig ESP 60S Portable CD Player won't work. It starts spinning then stops. I have tried mode and program, but nothing helps. This is my second Craig CD player to do this.
sounds like it has a faulty laser and it wont read so the player stops the cd spin motor. try cleaning it and see if it works
Good Luck!
May 11, 2011 | Craig Personal CD Player
It appears CD ERROR every time i try to play a spins, but after 5-10 seconds it stops and the error is displayed.
If you've tried more than one cd that you KNOW works with other cd players, the sensor in the cd player could be dirty or damaged. If it's dirty, carefully clean it. If it's damaged, it will need to be professionally repaired (unless you're feeling very brave...).
Mar 03, 2011 | Blaupunkt San Remo CD31 CD Player
My 5 Disk CD player doesn't work. It wont read any kind of CD. The radio and Tape Decks still work though. How can I fix the CD player.
Hello Alison hi, we need to check two parts to see which is the problem section why your player wont read.
  1. Does your CD spins normally, check your player if the cd spins normally, if you can see the disk spinning, take note of the spin, is it to slow? An abnormal disk spin has problems with its spindle motor assembly.
  2. Does your CD spins and then slow down to a stops, did not read the disk. This is caused by two things, FIRST: your CD player lens needs cleaning, you can buy a CD lens cleaner and use it to clean the lens, SECOND: The lens has degraded or worn out due to use and time, this needs a replacement lens assembly.
This things are way beyond a normal user, I suggest you send it for service. Sorry, there are no user serviceable parts here.
Aug 19, 2010 | RCA RS1285 CD Shelf System
CD player won't read disc
If its on a computer then it may be the driver.
if its on a cd player then its hardware problem.
If its on a computer reinstall the driver.
if its on a cd player go to some expert.
or be more specific.
Apr 01, 2009 | Audio Players & Recorders
Cd player on RCA R52653
overheating or lens dirty in unit buy lens cleaner cd to clean it
Jan 27, 2008 | RCA 100-Watt Stereo System With 5-CD...
Cd player not working
first try play Lens Cleaner CD, if you are lucky ,it's done!!
Sep 07, 2007 | Aiwa CSD-ED27 Boombox
CD Changer spinning continually
i have the same exact problem with mine. what i did was manually pull open the cd deck, stop the disk carousel from spninning by holding it still, then push the deck closed. the cd deck will no longer work, but at least it stops spinning. the auxiliary works fine and so does the radio.
Feb 07, 2007 | RCA RS2652 5-CD BOOKSHELF SYSTEM Shelf...
1,393 people viewed this question
Top Bang and Olufsen Audio Players & Recorders Experts
Are you a Bang and Olufsen Audio Player and Recorder Expert? Answer questions, earn points and help others
