Question about Emerson Pool & Spa
I need the through bolts for the wet end of a emerson R63 mwena 4727 pump
  • Emerson Master
  • 1,631 Answers
I do not believe that thru bolts have a part number? Which means, they are something you can not purchase separately?
But...
Try an electric motor shop in your area. They may have some junk motors laying around?
Or...
Try a pool and spa repair service company in your area, they too may have junk motors laying around, that they can remove the thru bolts from. I know I have many of them in my junk pile.
And by the way... Emerson does not make a Pump! They just manufacture the Motor as a third party vendor to a pump manufacturer. To know the type of thru bolt, we will need the name and model of the PUMP.
Posted on Apr 29, 2015
Have an Emerson model # R63MWENA-4727 on my Hot Tub. Runs continuesly fine. But when I turn the jets on I hear a " click" and it won't run.
It is a problem in the relay of that one motor in your spa electronic control most likely. If you have many jets buttons, you can unplug 1 pump from the control and plug in another relay see if the motor works.. if it doesnt work it your motor if it does work then its the relay in the controle system.
Sep 04, 2015 | Emerson Pool & Spa
I am trying to find a replacement basket for a emerson pump model T55CXCLL-1386 Cat EQC1072 HP 3/4
Emerson does not make pumps. They produce a motor, as a third-party vendor, and a pump manufacturerer will use their motor.
so, the information you provided, is for the motor, we cannot assist you to locate a basket for your pump, with those numbers. Provide us a make and model of the pump. If you can't, take a picture of it, and upload that.
Some information... Or terminology, that might make things a little more clear:
A motor is the electrical component that is attached to a Wet End.
The Wet End or the Liquid End houses the impeller which is what moves the water when the motor begins to turn.
The two together make a Pump.
The Motor by itself, is not a pump. The wet end, is not a pump by itself. Again, the two together make the pump.
Common names/brands of pumps: WaterWay; Hayward; Pentair; Sta-Rite (now Pentair), Jandy, among others.
Apr 02, 2015 | Emerson Pool & Spa
Show picture how to replace pot gasket in emerson pump s55nxnpk-7243
Emerson - to my knowledge, does not make pool/spa Pumps!
Just motors.
Then pump manufacturers utilize Emerson as a 3rd party vendor to supply them with a motor for their Wet End. Then when their Wet End is installed onto a motor, like Emersons, then is it called a Pump!
make and model of your pump?
Feb 26, 2014 | Emerson Pool & Spa
How many orings
Emerson does not make the pump, they only make the motor. You need to find out the manufacturer and model of your pumps volute,(wet end or "plastic part")..., before I can help.
oskopoolnspa.com
Nov 30, 2013 | Emerson Pool & Spa
Emerson 1081 1563 R63MWENA-4727
should tell on old motor if tag is gone contact manufacturer
Oct 30, 2013 | Pool & Spa
Emerson R63mwena-4727 is Leaking
From where?
possibly from under neath near the motor shaft
If so, then you have a failed shaft seal!
you will then need the information for the pump: Mike make and model. Emerson is not the manufacturer of the pump and any information off of the motor label will be of no use. You need information off of the pump.
Sep 23, 2013 | Emerson Pool & Spa
How do I get old motor off pump to install my new motor?
The front of the wet end must be removed to access the impeller. Then remove the rear electrical covering to expose the rear end of the motor shaft. Look closely at the shaft. It has two flat sides. A 12mm open face wrench will fit onto the shaft. Lock the shaft in place with the wrench and unscrew the impeller. The rear housing behind the impeller pops off to reveal four 9/16 bolts. Remove them and the motor is free. Reverse the process with the new motor.
Apr 22, 2010 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
Brand new pump that i bought it from store and i installed myself but it makes a distinctiv noise. emerson 230 v 1 hp.
is it the water going through the wet end or is the motor making the funny sound?
If the motor is sounding funny then you may have a bad motor. if the wet end is sounding really noisy then the motor may not be matching the size of the wet end as far as the HP. make sense? if your motor is bigger than the rating on the wet end it is pushing way too much water it is will be very noisy.
Jan 02, 2009 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
Pool & Spa Logo
61 people viewed this question
Top Emerson Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Ian Kime
Ian Kime
Are you an Emerson Pool and Spa Expert? Answer questions, earn points and help others
