How do I fix woofer
I was using my self powered woofer for many years over 10 with the av cable inputs, then I learned to bridge it where my stereo turned it's gain / volume up as I turned up the stereo. Now all the sudden it doesn't work, like it went out, or the capacitor or something...I don't know anything about basic/simple electronics : = :' ...so, I'm just wondering if it may be a fuse or what? How do I test it process of elimination? to find out what's wrong and how to fix.....please help, it's been my baby for years.
2 Suggested Answers
  • 4234 Answers
SOURCE: Volume reduction with same input ( 4 years old),
What are you using to feed the sub? Are you sure that the signal level you are presenting to the sub is the same?
Dan
Posted on Jul 31, 2009
Why won't it power on .it just stays in standby mode .
Top 10 Mistakes When Hooking Up a Home Theater System
www.audiogurus.com > Learn: Home > Cables
You don't have to buy expensive cables to run wire for those surround sound ...Interconnect cables are important-in that your system won't work without them. .... If you use a rack or shelves for your AV gear, remember to put the amplifier or ... the projector remote; Power up the home theater system with the receiver remote ...
How to fix sony stereo protection - YouTube
? 1:31
https://www.youtube.com/watch?v=oG17QKiI_E8
Feb 28, 2014 - Uploaded by dallas1999fan
Step 1 take apart Step 2 spin the fan Step 3 unplug the powercable Step ... his fault that your system is not fixed. i have the same stereo system and it .... Sony MHC-EC909iP Shelf SystemFeatures & Review - Duration: ... Red Blinking Power Indicator Denon Receiver AVR-488 - shuts off - won't stay on etc.
Understanding Home Stereos, Amplifiers, Speakers, and ...
Dec 25, 2015 | Audio Players & Recorders
I have a Bose powered sub woofer, which I would like to connect to a pioneer receiver, the subwoofer (model 2683) connection has a four pronged connection (yellow white red blank) and the receiver has a...
Hi,sorry but you can not connect it directly like other sub-woofers..
Bose 2683 Powered Subwoofer is part of Bose Lifestyle 5 system, Please note that you will need the 5-pin DIN cable that connects the subwoofer to the base or "Music Center". and the 4 pronged connections for its own stereo speaker output not input from another stereo..
Sorry....but if you can arrange some handy man nearby ,he may get into the DIN cable to locate the subwoofer signal 2x input leads than you can use that leads for connecting into single sub woofer out let of your system...otherwise try to sell BOSE which can easily buy brand new up to date powered sub..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 21, 2011 | Audio Players & Recorders
How to hookup
hi,
if u want to hook up the sub with ur av receiver the connect the sub woofer output of ur AVR to any one (left or right) input of ur sub woofer. then connect its power . set the frequency range between 90 and 120Hz. set the volume of sub woofer to 40% of its total. also check the av receives speaker setting. goto speaker setup and make ON the sub woofer out.
if want to connect the sub to a stereo amp without sub out. then connect the amps speaker line to the speaker input of sub woofer and connect the speaker out of sub to left and right speaker ( make sure to connect the red to red and black to black). set the volume and frequency as above
ok
Jan 01, 2011 | Wharfedale PowerCube PC-10 Subwoofer
How it can be connected to a stereo amp
hi,
if ur amplifier have a pre out, then u can connect that to ur L/R input of ur sub woofer.
if not the only way is, connect ur amplifiers speaker output to sub woofers speaker input and then connect ur speaker to sub woofer speaker output terminal. remember don't inter change positive and negative wires.
if ur amplifier have speaker A,B connection then it is very easy. connect the speaker A to ur left and right speaker. then connect speaker B to ur sub woofer's left and right speaker input. be sure to make that speaker A and B switch is in on position. the power on both and check it. ( use good quality speaker cable to connect the sub woofer)
your sub woofer is designed to work , both at low level and high level input.
ok
Dec 17, 2010 | Yamaha YST-SW215 Subwoofer
I get no sound out of my sub woofer. I've triple checked the setup for speakers. I've had this unit for years so I'm familiar with the setup. I've taken the speaker to another stereo and it works fine....
check the cable for you sub woofer. If problem exists. Try another cable to verify. What kind of subwoofers are you using? Are you going through the LFE port or are you running speaker wires through the speaker inputs on the sub?
Dec 08, 2010 | Pioneer VSX-D908S Receiver
AV receiver single line output to two line input on sub woofer
You are trying to connect the powered sub output of the receiver to a standard (unpowered) subwoofer. Can't be done.
May 05, 2017 | JVC Audio Players & Recorders
It gets hot
What you need to check is the impedance that you are connecting at. If you are using for sub woofers... you need to check how you wire them up. If you are using bridge mode then make sure that you have a 4 ohm load. This is possible with a single coil woofer which has an impedance of 4 ohm.
If you have a single dvc woofer, then you would have to either wire it up in stereo with a 4 ohm coil to each channel. If you would like to run it in brifge mode then you would have to invest in a single dual 2 ohm sub woofer and connect it with the coils in series thus obtaining a 4 ohm load.
If you have multiple woofers then it becomes more tricky. You can use a channel amp in bridge mode by getting 2 dual 4 ohm dvc woofers. You would have to connect the woofers themselves in parrallel but to the amplifier, you MUST have the woofers in series with each other. Thus getting a 4 ohm bridged load on the amplifier.
Connecting this amplifier any other way can cause it to overheat and fail.
hope this helps you
Nov 06, 2009 | Power Acoustik LT-980/2 Car Audio...
Amps on woofers are fine just won't hit
your probably making your amp run to low ohms if its a 2 channel amp bridged to one channel you can probably only run it at four ohms
Also seeing as your subs are 2ohm dvc you can't wire them individually to 2ohm and use each channel separately. So i'd recommend buying a 2ohm stable monoblock or running it at four ohms. a 1400 watt amp'll still pound at 4ohms and it'll extend your amp's life span
Aug 29, 2009 | Pioneer GM-7200M Car Audio Amplifier
No stereo signal out from yamaha p 2500 s
It's unclear what type of connectors are on the end of the cables(s) coming from your computer.
This amp only works with mono 1/4" TRS and XLR connectors, not standard RCA connectors.
Did you try the Right one in the Left Channel to see if the Left Channel worked?
Refer to the following manual and read up on the connectors (page 7) and the use of the Stereo/Parallel/Bridge Switch (page 8). When it is NOT in Stereo Mode the unit only uses the Right Channel controls and input.
http://img3.musiciansfriend.com/dbase/pdf/man/m_480824.pdf
STEREO/PARALLEL/BRIDGE switch
Use this switch to select the operating mode.
• STEREO mode
Channels A and B operate independently (as with a conventional
stereo amplifier). The Channel A input goes to the Channel
A output jacks, and the Channel B input goes to the
Channel B output jacks.
• PARALLEL mode
The Channel A input signal is output through both the Channel
A and Channel B output jacks. The Channel B input jacks do
not function. Channel A and B volumes can be independently
adjusted.
• BRIDGE mode
The Channel A input signal is output from the BRIDGE output
jacks. To adjust the volume, you must use the Channel A volume
control knob.
Apr 03, 2009 | Yamaha P-2500 Amplifier
Subwoofer probelm
I suspect you have a bad cable, a poor ground or a bad
power supply inside the speaker amplifier. The amplifier
(inside the sub-woofer) could also be defective.
1) Bad cable or connector:
If the (braided shield/outer tube) of the coaxial input cable is
not grounded, the cable will pickup line frequency "hum"
from surrounding power lines, house wires, lights and
appliances.
This hum is then amplified by the speaker's amplifier
causing the constant bass sound you speak of.
Because the hum frequency fundamental is 60 Hertz in
North America, 50 Hertz in Europe, you hear it coming
mostly out of the sub-woofer, because the midrange and
high speaker circuits filter it out.
Check the input connectors, cable at both ends, wiggle
the jacks at a low volume setting to see if it changes.
Make sure that you are indeed using a properly shielded
coaxial cable.
A coaxial cable consists of a thin inner conductor, surrounded
by a flexible tube made up of a braided metal shield, which
must be grounded. This prevents hum from being picked up
by the sensitive amplifier inputs.
2) If the power supply within the sub-woofer's internal amplifier
is defective, the the power supply hum will also get coupled
into the amplifier and speaker with same results as above.
Power supply hum is typically twice the line frequency,
i.e. 120 Hertz, but not always, depending on what
component failed: Rectifier diode, filter capacitor, or
the voltage regulator.
3) Ground loops:
When you run very long cables between the source and
destination of an audio signal, multiple ground paths (must)
exist between the two points in space, creating complete
loop circuits.
Power line hum from the environment can (will) induce
heavy AC currents around these loops, creating a voltage
gradient across these cables, and in-between the end
devices.
Once again, this AC hum is coupled into the amplifier inputs.
Ground loops become a problem with cables over 10
feet long, and an astronomical problem for stage audio
engineers. To avoid ground loops, they must break
the circuit's continuity by using isolation transformers,
optical isolators, and/or differential input amplifiers.
So how long are your cables?
Most house stereo components are only designed to
handle 6 to 10 feet of cabling max.
30 feet is already asking for major trouble.
4) Feed back oscillation: This occurs when the output of
an amplifier is fed back to the inputs with a round trip
gain greater or equal to unity. The tiniest little electrical
disturbance is then amplified and re-amplified, over and
over again, usually at one preferred frequency, causing
the typical (ear-splitting) microphone squeal or howl.
In your situation feedback and/ loss of original signal
could be the result of mis-wiring the input cables.
Note that this is NOT as silly nor as unlikely as it sounds,
because many computer audio cards and even some
home stereo systems have re-configurable inputs and
outputs.
SOFTWARE configuration decides which jack at the
back does what !!!!
On my computer, for example, the Realtek audio driver
tries to automatically figure out what cable is connected
to each jack (usually it gets it wrong)
Using the Realtek control panel applet, I can then
manually re-configure the gray jack as input,
the green jack as bass, pink jack as center.... etc.
If this situation also applies to your system, please check
the software configuration. Connecting an output cable to
an input jack will certainly cause a lot of HUM and not
much music.
5) Finally, don't rule out internal sub-woofer failure. Unlike
the passive stereo/hi-fi speakers of days gone by, modern
multi-channel theater systems with front, center, rear and
sub-woofer speakers are internally amplified, with active
frequency cross-over filters and special effect/ surround
sound capabilities.
Usually, the large sub-woofer contains most of the
electronics, amplifiers and filters.
It feeds the other speakers, and it is controlled by
an external volume control module which can be separate
or built into one of the tweeters.
These sub-woofer electronics are prone to poor design,
overheating and early failure. (Even fresh out of the box
like yours)
If you cannot get it working, take it back to the store,
and make the NICE salesmen **** with it.
Good luck
Please rate my answers
Martin.
Jul 20, 2008 | Yamaha 5.1-Ch. Surround Sound Home Theater...
44 people viewed this question
 Grubhead
Grubhead
