Question about Samsung Dishwashers
Samsung dishwasher code no. DD81-01549A_EN lights on front panel flash then lights on top flash then washer does not work
SOURCE: asko dishwasher model 1475
Have the same problem with our asko 1475. In the past, we would disconnect the dishwasher and when we reconnected the power, it ran fine. This time it isn't helping!
Posted on Jul 12, 2008
SOURCE: whirlpool dishwasher reset code
Yup, found it on another site..I had the same issue today.
Reset code: Push 1. Heat Dry 2. Normal 3. Heat Dry 4. Normal
wait about 2 minutes as the controller resets itself. You should see all the leds flash on and then wash and rinse leds stay on for about 30 seconds. A minute or so later ..presto, my machine worked again.
My machine is not the GU3200XTP, but in the same Whirlpool tall tub series (same manual) so leds may not have the same name.
Mark
Posted on Oct 21, 2008
SOURCE: DISHWASHER WON'T START,ALL LIGHTS ON PANEL FLASH RED
how to download the game gat4 (i don't know ENGlish )
Posted on Feb 15, 2009
SOURCE: lock on light flashing
I finally decided to calm down and use my head and managed to solve the problem. I read the instructions that are on the top of the dishwasher door. ( Smart move on my part HUH!) It said that when the door lock light is on everything is disabled. Hold the air/dry button down for 4 seconds and the lock light will go out. Guess what, IT WORKED. Here is what I learned from this. Always read all instructions. I spent $9.95 for an answer that was right in front of me. Humans can be so dumb I am!!!!
Posted on May 28, 2009
SOURCE: Maytag Jetclean Dishwasher EQ Plus - Lights flashing
either the control board or the control panel needs replacement. Most likely the latter. There is a possibility that both parts failed also. Usually water gets inside the touchpad, corroding and shorting the touchpad. Good luck
Posted on Mar 03, 2010
Haier dishwasher HDW9WHT beeps 5 times and won't wash what is wrong with it can I fix it or should I get someone in
7 results (0.54 seconds) Search Results
    Haier HDW100WH / HDW100SS - ProductReview.com.au
    www.productreview.com.au > ... > Dishwashers > Freestanding > Haier
    Rating: 1.7 - ‎30 votes
    Haier HDW100WH / HDW100SS: 30 customer reviews on Australia's largest ... 1.7 out of 5 stars for Haier HDW100WH / HDW100SS in Freestanding Dishwashers. ... I putthis review in to do my part for what I think is a great consumer service you ... it it keeps beeping 10 times telling me doors open??and won't begin cycle.
    Haier Dishwasher Error Fault Codes - Lights Flashing ...
    removeandreplace.com/.../haier-dishwasher-error-fault-codes-lights-flash...
    Dec 21, 2015 - Haier dishwasher error codes - flashing lights - beeping ...Dishwasher keep filling water and draining at the same time ... Fix Washing Machine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note 5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The Refrigerator ...
    Dishwasher Has Beeping Sounds Blinking Lights - How To ...
    removeandreplace.com/.../dishwasher-has-beeping-sounds-blinking-light...
    Dec 21, 2015 - At times your dishwasher may need to be reset. ... Haier DishwasherError Fault Codes - Lights Flashing Beeping Sounds My Haier ... Fix WashingMachine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The ...
    How to Troubleshoot & Repair a Dishwasher ' HomeTips
    www.hometips.com/repair-fix/dishwasher.html
Jan 19, 2016 | Haier Dishwashers
Kenmore dishwasher clean button constantly flashing ,washer has been unplugged ???maybe reset itself did not work. 2 yrs old
please follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 09, 2013 | Dishwashers
Replaced the whole top panel. now start lights only flash wont start washer
You might have blown a fuse on the circuit board or fried a transistor on the board
Oct 07, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Error codes flashing
Hi, This is mainly due to control panel failure. This unit does not ventfrom the front like most do, so there needs to be some clearance above the top of the tub to avoid blocking the vent fan, otherwise moisture gets trapped in the machine and works it's way into the control panel eventually..
Apr 13, 2010 | Frigidaire PLD4375RFC Dishwasher
Lock on light flashing
Jan 28, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishwasher stopped working
You have a board problem it came from a power surge.
Nov 11, 2007 | Maytag 24 in. MDB5600A Jetclean II...
Kenmore elite HE3t
I am getting an F35 code on the washer has anyone had this problem
Sep 21, 2007 | Kenmore Elite 45986 Front Load Washer
Clean light on dishwasher won't stop flashing
yust reset press heated dry-normal-heated dry normal-and it will work 100% remember that code it is reset code for wirpool quiet partner and many other models
Jul 02, 2007 | Whirlpool 24 in. GU3200XTP Built-in...
Flashing LEDs
When doing some floor work, I had taken off the front bottom panel of the dishwasher and there was a pamphlet which had electronic information. Dummy me threw it away, but I remember it had code information on it. I am now having this flashing light problem. So check behind the front bottom panel (remove the 4 screws to get behind it) and the piece of paper should be in there. Please let me know if you find it!
Jan 20, 2007 | Maytag 24 in. MDB6100A Built-in Dishwasher
Dishwashers Logo
1,296 people viewed this question
Top Samsung Dishwashers Experts
Dale Copeland
Dale Copeland
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
