My radio has an antenna which has been broken, and I would like to purchase another AM & FM antenna.
Allan Ruprecht (Michigan) allanruprecht@hotmail.com (248) 345-6977
    Top Expert:
  • Audio Player... Master
  • 45,245 Answers
Check with radio shack.com
Posted on Apr 29, 2015
2008 subaru tribeca radio station won't play.
all stations, AM and FM?
is the antenna , broken? or unplugged from rear of radio?
past 90.?
that is FM. and FM must have an antenna to work
or are you saying the button fails to advance the stations.
if yes, that is a bad radio.
May 03, 2014 | 2008 Subaru B9 Tribeca
My Saturn factory AM/FM radio on my 1996 SL gets some FM reception but no AM reception. I am trying to determine whether I need to repair the antenna or the radio.
You will need to pull the radio out of the dash and make sure the antenna is still pluged into the unit. If the antenna is in the windshield make sure the glass is not broken, and the wire broken. If there is an external antenn, you need to check the connection at the bottom of the antenna, and the wire is good between the antenna and the radio. Has any new items been mounted recently, the screws could have damaged the coax.
Rian
Aug 31, 2011 | 1996 Saturn SC
Grundig YB400PE broken antenna
Unfortunately, your description of the problem means that your radio must be taken apart to be fixed. Replacement antennas can be found purchased. It would require installing the new antenna and most likely soldering it to the broken wire. Do you have a picture?
Apr 05, 2009 | Grundig YB 400PE AM/FM/SW Radio
Antenna on radio broke
Radio Shack can get you an antenna, or a long wire (or wire coat hanger actually works too)
Jan 06, 2009 | Tivoli (PAL) AM/FM Radio
Pioneer DEH 1900 MP receiver - cannot pick up AM stations
normally the problem you are describing means that your antenna is bad. typically, if you have no am good fm bad antenna if you had good am and no fm the fm section of your radio would be bad.
you can test this but you will need an antenna (this can be purchased at most car parts stores for about $10.00) pull out the radio unplug the black round plug from the back of the radio and plug in the new one ( the antenna plug is a universal fit) you will probably need to ground the base of the antenna for the test then turn your radio I'm sure this will fix your problem but if not you can e-mail me at merle840@aol.com
good luck'
Merle
Sep 29, 2008 | Car Audio & Video
Better fm reception
Is it just a single wire?
If so, purchase a cheap FM antena. It looks like a "T" when spread out (4' to 5'). That should help.
You can purchase an "amplified" antenna, but if your area reception is really bad (such as in a valley) the antenna would just amplify the noise as well. Look for web based radio in this case or if you have cable there are stations on it.
Jeff
Jan 11, 2008 | GPX HM3817DT Shelf System
The antenna is broken at the base eye, and repeated attempts to re-attach the eye have failed.  How can I purchase a replacement antenna?
It's possible to get the same antenna on ebay...
You can check here:
http://item.express.ebay.com/Consumer-Electronics_MP3-Players-Portable-Audio_Boomboxes_Boombox-Radio-Replacement-Antenna-12-Inches-Boom-Box_W0QQitemZ120194279381QQihZ002QQptdnZBoomboxesQQddnZConsumerQ20ElectronicsQQadnZMP3Q20PlayersQ20Q26Q20PortableQ20AudioQQptdiZ493QQddiZ945QQadiZ500QQcmdZExpressItem
or here
http://item.express.ebay.com/Consumer-Electronics_MP3-Players-Portable-Audio_Boomboxes_Boombox-Radio-Replacement-Antenna-12-Inch-Sony-RCA-Coby_W0QQitemZ120194280040QQihZ002QQptdnZBoomboxesQQddnZConsumerQ20ElectronicsQQadnZMP3Q20PlayersQ20Q26Q20PortableQ20AudioQQptdiZ493QQddiZ945QQadiZ500QQcmdZExpressItem
Dec 02, 2007 | Jwin (JX-CD512D) Sports Portable CD Player...
AM reception
If the internal antenna is broken that means the ferrite bar is broken,that does imply that the wiring around it is cut. If the two parts are not removed, the antenna may still be able to perform correctly (just as two magnets put end to end). You can try to put it in the vicinity of another radio to see if there is any resonance effect.
Hope it helps.
Oct 30, 2007 | Grundig G4000A FM/AM Radio
157 people viewed this question
 Grubhead
Grubhead
