Question about RTO Ho Herpa Freightliner Truck Tractor
I have a frightliner 2007 century classic with c15 cat eng its throwing inatmitting eng open 128s290 05 please advise
Throwing code eng open 128s290 05
    Master:
  • 495 Answers
Are you sure that is the code? Its engine "128", but the rest isnt adding up.
Here are the all the C15 engine codes.http://world-engine-blog.blogspot.com/2013/09/c13-c15-and-c18-engines-diagnostic_23.html ENGINES AND MORE
Posted on Apr 29, 2015
Testimonial: "Its a 2007 freight with c15 try dash code 128 290 05"
2003 Buick Century just quits running going down the road. Keeps throwing a code for the MAF sensor. We have replaced this several times. It will run fine for a couple months then it does it again.
Why would you think the issue is with the MAF, did you do the diagnostic testing? What was the fault code? MAF sensors seldom fail. I would look for loss of fuel pressure or spark maybe. I think the MAF fault is due to the other problem and it is not the cause of it but a symptom.
Oct 31, 2016 | 2003 Buick Century
04 Altima 2.5 s w 150k changed cat 2014 1 yr later p0420 code again what r normal reads for 02 sensors? reads @ idle fluctuate @ .3V b1 sensor & .8V b2 sensor.anyone had p0420 that wasnt a bad cat
Those cars are notorious for engine problems unfortunately. The exhaust valves tend to warp from heat after around 200k miles. Therefore throwing the O2 codes. Best outcome and cost effective thing I can recommend is replacing the engine with a new or low mileage engine.
Feb 18, 2015 | Cars & Trucks
2004 SUZUKI VERONA THROWING P1902 MASS AIR FLOW
Check intake manifold vacuum with a vacuum gauge. Should be 17-21 inches. Low vacuum 10-15 inches would indicate a bad cat. Or you can remove the oxygen sensor and drive it. If the power is better you have a bad cat. Misfires can melt the cat converter.
Dec 19, 2013 | Cars & Trucks
Starter replacement 2007 Harley Davidson flstc Heritage Softail
Hi Anonymous, before you start throwing big money away start by throwing small money away. First make sure your battery is fully charged, then do a load test anything below 9 volts replace the battery. Second replace the starter relay cheap $6. Third remove the back cover of the solenoid and de-arc/refurbish the contact plate and shoes making sure they are tight. Fourth make sure the starter drive/clutch only spins one way. If everything checks out ok then you can start throwing big money at it. Good luck
Aug 09, 2012 | 2007 Harley Davidson FLSTC Heritage...
Freightliner code 128 s254 07
on 2006 freightliner century with 12.7 detroit 60 Error code
eng contreller no resp. 128s254 07.
Apr 26, 2012 | RTO Ho Herpa Freightliner Truck Tractor
Fuel injector system fault on dashbaord. please advise what fault could be
if its showing the electric zigzag thingy then most likely fault is the O2 sensor ,its flashing this fault as its getting too much fuel ,but it could also be a coil fault somewhere or ignition module as well as this will misfire and allow to unburnt fuel into cat throwing the light on ,also a fuel injector is staying open throwing too much unburnt fuel into cat
Mar 18, 2011 | BMW X5 Series Cars & Trucks
HOw do you clear the Diagnostic Codes
u mite disconnect the positive battery cable,,for 5 minuets,,,but u will have to reprogram your radio & clock,,,,
Apr 25, 2010 | 1999 Buick Century
Continuous code for cat. seems to plug up
hard to say i would like to look at it did you check the map & maf sensor are they with in limits
Aug 07, 2008 | 2001 Chevrolet Monte Carlo
RTO Ho Herpa Freightliner Truck Tractor Logo
239 people viewed this question
Top RTO Toys Experts
Timllfixit
The Scrivener
Pete Bruk
Are you a RTO Toy Expert? Answer questions, earn points and help others
