Why does it indicate error: ink box full and won't detect the black ink cartridge even when the cartridge is full?
  • Emmanuel Yco
    Emmanuel Yco Apr 29, 2015
    it doesnt print because the error ink box full appears on the screen of the printer...
  • 5,160 Answers
The ink box full message on an ink jet printer means that the waste ink absorber counter has reached the preset limit. When the printer does a cleaning cycle or recharges the nozzles when a new cartridge is installed, the excess ink is left on these sponges. Using the printer after this point may lead to ink spilling out of the printer. The ink absorbers are usually at the bottom of the printer and difficult to reach. (They can be cleaned if the printer is disassembled. However, this is messy and you have to make sure to reassemble the printer correctly. Then there may be a way to reset the counter.) Unless the printer is still under warranty, it is probably better to replace the unit.
The printer probably can't run the cleaning step to flush the ink from the new cartridge to the nozzles unless the waste ink counter is reset. That's why it doesn't register that there is a new black cartridge.
I wish that I had better news for you.
Posted on Apr 30, 2015
I have enough black ink to print a few pages in black, but the printer won't print. What do I do?
I had a Epson printer that would not print or even allow me to use the scanner because the colored ink was out. Even though I had full black ink, it still would not let me print until i replaced the colored ink.
Sep 25, 2012 | Lexmark 90T6005 Prospect Pro205 All-in-One...
Error 6000
This is the error code printer Canon IP1200, IP1300, etc. light blink Indicator:
3x orange 1x Green = mechanical error
if you dont have any knowlegde about printers, better bring your printer to Canon service center.
4x orange 1x green = printer absorber full
reset your printer using software ressetter or try using manual reset. different printers have different manual reset.
5x orange 1x green = black cartridge/color cartridge error
can be chip error or connector is dirty.
7x orange 1x green = black cartridge/color cartridge error
8x orange 1x green = printer absorber full
12x - 17x orange 1x green = cartridge detection error
How to Reset waste ink counter Manually 1. Unplug power and USB cable. 2. Open door and hold power button. 3. Connect power. 4. Close door, then release power button.
How to Reset waste ink counter using Resetter
1. Download software for Canon iP1200 printer. DOWNLOAD 2. Unzip downloaded file to any location using, 7ZIp, WinRAR, Winzip, etc 3. Run GeneralTool.exe 4. select connected USB port number from USB port 5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION 6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. the selected waste ink counter will be reset.
Thank you for posting. Hope this helps.
Jul 06, 2011 | Canon PIXMA iP1200 Photo Printer
Caution lite flashing over cartridge of hp deskjet 940c. error message says that there is not color ink cartridge in printer. There is and the interface says the tank is full. It won't print...
Even though the interface says the cartridge is full, if the printer detects it being empty, odds are you will have to replace the color cartridge, even though you are only printing black.
You can try taking the cartridge out and cleaning the contacts with a pencil eraser and reseat the color cartridge. If no change, replace the cartridge.
Jun 30, 2011 | Computers & Internet
Please, I want to know error code no. 00010014 EPSON Stylus Pro 9800.
00010014 - Ink System Pressurization Error (The Pressure Sensor does not indicate pressure) CClick HERE to view full detail on troubleshooting process.
EXPLANATION:
The error codes in the table below relate to a faulty ink cartridge or detection of the cartridge when installed in the printer. These errors only occur when an ink cartridge is changed. Whilst you may be unable to quickly identify which ink cartridge may be at fault, the steps below provide a process of elimination.
    Feb 15, 2011 | Epson Stylus Pro 9800 InkJet Printer
    Missing color ink cartridge...have full black cartridge...Printer won't print.
    Hello, this is to be expected . You will need to have all cartridges installed and with ink in, even if you only want to print in black, or the printer will detect an error and won't work.
    Regards,
    nicam49
    Jan 26, 2011 | HP Photosmart 3180 All-In-One Printer
    MP140 can't recognise the black cartridge that I've just installed. Error code 4 - any ideas? I've tried the manual - nothing, and not much luck online - Thanks
    Error code 4 normally indicates that there is no unk, and the solution is by installing a genuine cartridge, Try to use Black PG40 remanufactured Canon printer ink cartridge. This cartridge is a high capacity cartridge which has been filled with 23ml of ink compared with the 16ml (Black) that you get with the originals. Compatible with: Canon Pixma MP140. if this error still occur it is better that you try the following procedure below:-
    When you insert a refilled ink cartridge into your Pixma MP140 printer you should get a warning about the refilled cartridge. You should also be prompted, asking if you wish to disable ink level detecting. Agree to do so, and you won’t get the warnings again because the ink levels won’t be monitored by the printer.
    Thanks
    Oct 12, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
    Canon MX850 Large Black Ink Cartridge - PGI-5BK problem
    Just bought new MX318 one chamber gets finished after a few pages. No indicator for finished ink. One compartment of Ink cartridge looks empty the other still full. Tried cleening process but no improvement. Replaced Cartridge but it seems to behave the same as the first after a few prints.
    Aug 03, 2009 | Canon PIXMA MX850 Multifunction Printer
    Dell printer model# A940 50c error
    Test your cartridges.
    Remove the color ink cartridge then lower the cover of your printer. If the error message displays again, replace the black cartridge with a new one (or return the new one). Reinstall the color cartridge and remove the black ink cartridge then lower the cover. If the error message displays again, replace the color cartridge with a new color cartridge.
    Note: My manual indicated that the printer might have detected a short circuit in a cartridge. I returned a month old black cartridge got a new one and my printer is working fine now. Good luck.
    Nov 10, 2008 | Dell A940 All-In-One InkJet Printer
    Paper jam error message
    hi dear
    this the error code
    E9 The connected digital camera / video camera does not support Camera
    Direct Printing
    E14 The Ink cartridges whose destination are wrong
    E15 Ink cartridge is not installed E16 - Ink remaining is unknown
    E16 -E19 Failed to scan head alignment sheet
    E22 Carriage error
    E23 Paper feed error
    E24 Purge unit error
    E25 ASF(cam) sensor error
    E26 Internal temperature rise error
    E27 Waste ink absorber full or platen waste ink absorber full
    E28 Ink cartridge temperature rise error -
    E29 EEPROM error
    E33 Paper feed position error
    E35 15 USB Host VBUD overcurrent error - USB
    E37 17 Abnormal motor driver error
    E40 20 Other hardware error
    E42 22 Scanner error
    E2-2 No paper (ASF)
    E3-3 Paper jam
    E4 No ink
    E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
    or the ink cartridges are not installed properly
    E8 Waste ink absorber full, or platen waste ink absorber full
    First, download the software at http://www.box.net/shared/4yblbn34kg
    Secondly, to run the software your printer has to be in service mode. Do that by
    - unplug cable
    - press and hold "power" button
    - plug cable
    - press "resume" and release
    - release the "power" button
    At this stage, your computer will detect a new hardware
    Run the software.
    oke
    Apr 21, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
    Cartridge
    hi dear
    this the error code
    Direct Printing
    E22 Carriage error
    E29 EEPROM error
    E2-2 No paper (ASF)
    E3-3 Paper jam
    E4 No ink
    - unplug cable
    - plug cable
    Run the software.
    oke
    Oct 02, 2007 | Canon PIXMA MP160 All-In-One Printer
    55 people viewed this question
    jasbo
    jasbo
