Question about Car Audio & Video
The stereo's volume goes up and down on its and I cannot control it. Loose wire connection?
This is dirt and the tactile switches and soft touch pads
if its a face off then replace the face
or get it cleaned or repaired {replace the switches if you can}
touch pad types can be repaired quite easy just with a careful clean
you could try to clean with a 'gold cloth' or a glass fiber pen
http://www.ebay.co.uk/sch/i.html?_odkw=burnish+pencil&_from=R40'R40&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR7.TRC2.A0.H0.Xglass+fibre+pen.TRS0&_nkw=glass+fibre+pen&_sacat=0
Posted on Apr 29, 2015
3 Suggested Answers
MonsterG
  • 52 Answers
SOURCE: car stereo
if u got an amplifier, make sure u replace the fuse with a higher amp fuse, If the face for the detatchable deck got some kinda liquid, use compressed air to clean it a little bit, make sure alternator is charging and if ur car is not running then make it run to keep the battery chargin, :)
Posted on Feb 11, 2008
bcfr820
SOURCE: pioneer DEH-17 wiring diagram or pinout connection
the groung wire was torn out of my deh1700 pin connector where does it go back
Posted on Aug 25, 2011
Volume controller wire
Look for "stereo audio cable", they are relatively inexpensive
Mar 14, 2014 | Creative Labs INSPIRE 2.1 Computer...
Stereo shorts out not all speakers work turn volume up to get them to work
May be just bad volume control switch, or loose connection at speaker. You can try using electronic contact cleaner sparying down the shaft of the control after removing the knob. If this helps, you need new switch (or better still, new radio). If you can access the speaker that fails, you may inspect the wires which actually run from the voice coil to the speaker cone. If loose, it may be possible to re-solder them.
Feb 25, 2014 | 1999 Chevrolet Tahoe
My 2006 Toyota Solara convertible radio volume goes in and out, what can I do
Sit in back seat passenger side. Remove panel which is on top which is below rear window, same panel where seat belt goes into panel at top. You will need to remove #2 Phillips screws which hold panel in place. Screws are hiding behind seat belt front cover where belt goes down in panel, under cup holder which allows arm rest cover to lift off and one more right on left side of head rest in corner. Remove panel. You will see switch which is in vertical position. If for any reason you want to by-pass switch, just unplug switch. Radio will still work in standard mode. The amp sound will not increase in performance when top is down and sound will not be as sharp.
Jan 20, 2013 | 2005 Toyota Camry Solara
My stereo sysytem is a mini stereo: serial number 10200055. It currently says "protect", what is this and how do we return our system to normal operations?
When the word PROTECT appears on this display, this means the unit has detected a critical fault which could potentially cause harm to your stereo system.
The most common cause is a short circuit somewhere - something even as simple as loose speaker wiring could cause a short, triggering the Protect message.
You will need to determine if there is a possible short somewhere, so I recommend you start by firstly turning power OFF, disconnecting all speaker wires, then turn unit back ON.
Operate the stereo (without speakers) and turn volume up:
  • If Protect message appears when turning volume up, then stereo unit itself has an internal fault
  • If no Protect message appears, then suspect the speakers may be causing the issue.
  • Reduce volume and turn unit OFF
Re-connect speakers (ensure the connections are secure), turn unit ON:
  • If turning volume up triggers the Protect message again, there is an issue with the speakers or connections
Hope this helps.....
Sep 04, 2011 | Kenwood Audio Players & Recorders
The sound in the left speaker goes on and off on rough road. turn the volume up to max it works. Turn down 2-3 and no sound
IS A LOOSE WIRE CONNECTION TO THIS SPEAKER ---- WHEN ON FULL VOLUME THE HIGHER CURRENT COMING TO THE SPEAKER KEEPS IT PLAYING .......
CHECK THE CONNECTION ON THE BACK OF THE SPEAKER ---- MAYBE UNHOOK AND RECONNECT AGAIN ......... IF NOTHING CHECK THIS SPEAKER CONNECTION AT THE
STEREO REAR .............. YOU WILL FIX THIS
Jun 29, 2011 | Car Audio & Video
When i turn up the volume the deck turns off then turns back on
What kind of car do you have the stereo in? It sound exactly like a bad ground wire. To trouble shoot this, simply find a good clean ground point to hook the black wire from the radio to. you can usualy find somewhere behind the dash that the factory has grounded things to. I asked what kind of car, because some fords, and nissans do not have a ground wire in the factory radio harness, even though the adtor harness you may have used will have one. Hope this helps.
Aug 17, 2009 | JVC AM FM CD DET FACE CAR STEREO
Headset volume adjustment
if connected to a pc right click on the speaker icon on the right side of the main toolbar in windows then click on playback devices and adjust the volume there.
Jan 21, 2009 | Logitech Premium Stereo Consumer Headset
Car Stereo Volume Goes Up and Down Erratically
prolly buy a truck and a amp from this century
Oct 05, 2007 | Car Audio & Video
Volume turned up, kenwood shuts off briefly...
I had this same exact problem when my last older Kenwood Marine stereo cooked itself while I had it up loud for a few weekends on the lake. (smelled like it had burned inside). I went out and bought a new Kenwood KMR-550u stereo deck. (I do not have an additional amp). I hooked it up to the exact connections where my older Kenwood stereo unit had been hooked up, as I never had a problem with this for the past three years until it failed after smelling of burning elelectrical. I had chalked the problem up to heavy rain we had one day. Every time I turned up the volume, sometimes up to 27 out of 35 possible, or 29, or 32, the stereo would suddenly shut off as if I had turned it off. After a few seconds the stereo would come back on, but unless I was quick enough to turn down the volume it would do it again right away. Of course on a boat, we were beached in a cove and the engine was not running when I encountered this. I searched the internet finding hundreds of similar complaints and several dozen theories of all types, but only a couple that pointed me towards the power (voltage) idea as the problem. I put a volt meter on the positive & negative wires powering the stereo. I watched as I gradually turned up the volume, the voltage on the power wire gradually decreased from 12.5 volts, down into the 11 range, and as it hit 10.9 or 10.8 volts it shut off typically around a volume of 32. The red power wire in my boat that never seemed to have an issue with my old stereo until it fried was determined to actually be inadequate for the power flow for the new Kenwood, and probably was the culprit of my failed older unit. I offer this sound advice: Run a new pair of positive & negative wires directly from the battery (with an appropriate fuse of course (the deck has a 10 amp fuse in it's back so I would use that at the battery) to the stereo. Check the voltage as you turn the volume up into the high 20's and low 30's to ensure you are still getting voltage in the mid to high 11-12 volt range. The stereo is designed to require a minimum of 10.8 volts to operate, and when it drops below that it protects itself and shuts down.
Mar 24, 2007 | Kenwood Sirius KDC-MP522 CD Player
Volume knob
Normal Aiwa compact shelf units use what is called a jog switch for the volume. Usually you can tell the difference if when you you turn the volume up or down. It goes a short distance and seems to spring back. In this case there are two momentary contact switches. One for up one for down. With a plastic lever on the back of the knob that bumps the approriate switch whether turning down or up. If the lever is broken it will bump up against one but not the other. If it is broken plastic you know how good gluing plastic goes it never seems to hold.
Aug 02, 2006 | Aiwa NSX-A777 Shelf System
Car Audio & Video Logo
54 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
