Question about Frigidaire Refrigerators
My light went off in refrigerator but not my freezer. Both are still running, but the controls on the front of feezer door are not working. cannot disperse water or ice. Breakers are fine
    Master:
  • Frigidaire Master
  • 495 Answers
Try unplugging it for a minute. If that does not work, then you need the internals checked.
Posted on Apr 29, 2015
Whirlpool refrigerator model WRX735SDBM00. FEEZER NOT WORKING?
1 This usually can be caused by the freezer failing to self-defrost, resulting in a frost build up on the freezer coils.
2. Circulating fan not running
3. Door switch failure not allowing fan to run
4. Compressor fan not running. possible blade jam by foreign object or fan failure.
See www.repairclinic.com for addt,l information if needed.
Sep 19, 2017 | Whirlpool Refrigerators
My LG refrigerator (LFC23760) gives three beeps every few seconds. Any ideas?
it seems like the icebox is picking up a problem with one of its sensors (maybe a door sensor has gone bad so its thinking a door is opened) if however it has a door alarm it can be disabled by the control panel on front of the refrigerator
Jan 05, 2017 | LG Refrigerators
Side by side ice maker won't stop letting ice out of dispencer unles you open freezer door
It sounds like a sticking actuator switch. the door light switch shuts off the auger motor when you open the door.
Aug 15, 2014 | Refrigerators
Feezer cold frig.warm
sounds like your freezer is not defrosting, causing lack of air flow to fresh food side
May 09, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Feezer COLD food compartment not cooling. It
the heat element or the thermostat IN YOUR FREEZER PART need to be check...they might went bad and when you defrost the unit it is working fine but only for period of time....:(
Dec 30, 2009 | Amana Easy Reach Plus ABL2037FESL...
The freezer freezes up and no air circulates to the refrigerator. The Fan motor is working.
is there frost on the inside back wall in the feezer you have a defrost problem. a bad door gasket will cause the duct from the freezer to fridge to fill with frost so the air cant get to the frige
Dec 25, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Model gss20iepcbb freezer side works fine ...fridge
on most units they have two controls refrigerator control is electric t-stat that runs compressor freezer control think of it as a door colder freezer door is barely open warmer freezer door all the way open all cooling coils are in the freezer and a fan moves the air to refrigerater side possible problem fan not running
door freezer control all the way closed
light switch broken light staying on door gasket not sealing tight find door switch press verify light shuts off and fan starts
look for torn or damaged door gasket can look from outside with light and see if gasket contacts case on all four sides
freezer is cold enough so compressor is ok hopr this helps good luck ron
Dec 10, 2009 | Refrigerators
No light in refer but works in freezer
Check the door switch to see if is working and try another light bulb or try the light bulb somewhere else to see if the light bulb is good. Check to if vent holes coming from the feezer are blocked by something in the fridge. This will make it feel like your fridge is not working.
John
Sep 28, 2009 | Smeg FAB32 Bottom Freezer Refrigerator
My Refrigerator and Feezer are not cooling. mff2557hes
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
we
Aug 01, 2009 | Maytag MFF2557HES Stainless Steel French...
Refrigerators Logo
52 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
