Question about Bosch Saws
How do I change the blade on my Bosch jigsaw, model 1587?
    Master:
  • 495 Answers
Here is the manualhttp://mdm.boschwebservices.com/MDMCache/English%20%5BUS%5D/t10/0000000/r00995v-1.pdf http://mdm.boschwebservices.com/MDMCache/English%20%5BUS%5D/t10/0000000/r00995v-1.pdf
Posted on Apr 29, 2015
Does any one out there know how to put a blade in a Bosch 1581VS jig saw?
video here
How to Replace a Bosch Jigsaw Blade - YouTube
? 1:30
https://www.youtube.com/watch?v=YzpExustLD0
Sep 8, 2011 - Uploaded by toolsandmachinery
Mike will show you the simplicity of changing a blade with the Bosch twist-lock Jigsaw
here is the manual for the 1584
Bosch 1584VS Manuals
Apr 19, 2017 | Bosch Saws
I have a bosch 1587 vs jig saw i got used. I don't know how to install a blade. I have never had one like this. I turned the top handle the way the diagram showed but I don't think something is working.
In most models at the blade shuck holder is a screw that thigh the blade,unscrew it and change your new balde .
Also Go to this LINK and find the part/diagram that can help you.
Please thumbs back if help is fine,thanks!.
Nov 02, 2010 | Bosch 1587avsp Vs Orbital Jigsaw
How do I change the blades on a Bosch PST 2000 jigsaw
I couldn't find that specific model number Bosch saw, but here is the link to get user manuals from Bosch in case you mistyped it. (It's a long link that wouldn't all fit here, so I had to put a carriage return in it)
http://www.boschtools.com/Service/ProductServices/Pages/ManualsandPartsDefault.aspx
Or they may have a similar saw under a new model number. Here's the current model number of a very popular saw that has a less-than-obvious blade changing method 1587avsk
Mar 05, 2010 | Bosch Saws
Change blade 1587 Bosch avs
are you using the "T" shank blades and also are you loosening the spindle enough to allow the blade to turn, sometimes you have to push up a little to turn it and also pull away from the roller guide. Let me know and also there is a TINY spring in the top of the spindle that has a nasty habit of breaking and winding around itself not allowing proper operation.
Oct 06, 2009 | Bosch Saws
Replace the blade on jigsaw Bosch # 1587 AVS item # 0 061 587 683
YOu can download the user manual in the following links
http://mdm.boschwebservices.com/MDMCache/English%20[US]/t10/0000000/r00061v-1.pdf
https://www.boschtoolsservice.com/Order/IPL/IPLDetails.aspx?tn=0601587651&mn=1587AVS&init=1
The blade can be replaced by unscrewing the screw found on the shaft.
Jul 28, 2009 | Bosch 1581AVSK Top Handle Jig Saw Kit
Blade wander
a jigsaw is for cutting wavy lines if u want a straight cut use a rip saw with fine blade but you still can use a jigsaw must have sharp blade there is a blade u can get now from screwfix with a triangle spine on the back off the blade to prevent it twisting works fine (also do not push hard on the powertool let the blade do the cutting less likely to wander hope this is of help
May 30, 2009 | Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
Instruction manual for Bosch Jig Saw 1587AVS
This is the Owner's Manual for the Bosch 1587AVS Jigsaw.
Mar 31, 2009 | Saws
Blade won't stay in jigsaw
It sounds like you need to replace the shaft.
Feb 22, 2009 | Bosch Saws
I have a bosch jigsaw I purchased at auction.I can't figure out how to change the blade
There are two types of "quick release" mechanisms on the new Bosch jigsaws, the twist-top handle found on 1587 models, and the lower-lever found on the 1590's.
The "twist-top" is the black cap on the 1587 at the front of the saw. You must first put the orbiting control ( on the side of the saw ) to position number III. This releases pressure on the blade. Then you lift the black cap, rotate three or more turns counter-clockwise ( as seen from the top ) to release the locking mechanism. If the saw blade is cool, you can carefully remove it with a single one-quarter turn using your fingers. If the blade is still hot from sawing, use a pair of pliers, but be gentle. Hot blades can bend easily and jam.
The 1590 models are quite a bit easier. You still want to put the orbit control to position III to release pressure. But the quick-release is a simple flick of the black switch on the front face of the saw.
I still have my 30 year old Bosch with the screw-in blade holder. It still works and the saw still runs smooth as a sewing machine. If you are doing a lot of production work where you need to change blades frequently, the Bosch 1590 is the clear choice for quality and value. In thirty years of using Bosch tools, I have only had to do normal maintenance and had only one minor failure, which was the blade changing mechanism on the 1587 model. I broke it by tightening too far. SO, if you have a 1587 model, DO NOT OVER TIGHTEN. As it is, this non-warrantee repair only cost $16 bucks and took two days.
It should go without saying, but just to be safe I'll say it anyway... OBVIOUSLY, you should UNPLUG the tool when you are changing blades. Good luck!
Aug 03, 2008 | Computers & Internet
Saws Logo
742 people viewed this question
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
