Question about SumacLife Brand Sony Cyber-shot DSC-HX5V Cybershot DSC HX-5V Digital Camera Case - Red 6 inch Mini Tripod Adjustable mount angle Screen Protector
Why isn't the shutter fully closing and the zoom is making a grinding noise?
Liftgate will not stay open. When you push button it opens fully, but then immediately closes
HilAry when the lift gate goes to the open position does it make a grinding noise when it reaches the fully opened position and then closes, If so the gear driven assembly may have had a tooth broken on one of the gears and has striped out causing the gate to fall back down. If this is not the case meaning there is no grinding noises coming from the gate then you have a ecm module that operates the functions of the gear driven unit telling it when to stop and go down. If this is the problem you might want to take it to the dealership to program the new unit. I hope this helps.
Sep 20, 2011 | 2007 Lincoln MKX AWD
Zoom error on fujifilm finepix J30/35 how can i fix it?
If this is a brand new camera, it should be under warranty...why do you say yours is not?
May 25, 2010 | Cameras
My Olympus C-470 zoom thing won't close or open for some reason and the zoom is now stuck halfway in and out. I can't take pictures as it won't focus properly. The motor makes the usual noise it does when...
Your zooming funtion is damaged. so I suggest you please visit service center for repair. But please confirm me before that your battery are fully charged . If not then charged that fully then then try to use. Follow the picture of damaged place of zooming funtion.
Thank you and waiting for your feedback.
Feb 03, 2010 | Olympus Camedia D-590 / C-470 Digital...
It's making a grinding noise.
It's the zoom mechanism. You either have dirt / sand trapped in there or the gears have broken.
Nov 26, 2009 | Sony Cybershot DSC-T200 Digital Camera
I bought a brand new 580 ex 11 flash unit. When I turn it on it makes a grinding type of noise and then the zoom in the upper right coner continues to flash. I can't test fire it but the pilot light is...
The grinding noise is the zoom head trying to match the focal length of your lens. A brand new one should NOT grind. It should be silent. It sounds like you got the one that fell off the pallet during shipping. Exchange it for another one.
Oct 28, 2009 | Canon Speedlite 580EX II TTL Flash
Lens makes grinding noise
yes dust in mechanism or broken gear but ti not easy
Oct 12, 2009 | Panasonic Lumix DMC-FZ5 Digital Camera
Shutter not opening fully while taking snap
Hi there
Try spraying the shutter with WD-40 and keep on opening and closing it until it works properly
Good luck and regards
Jan 07, 2009 | Canon PowerShot A470 Digital Camera
'zoom error' on olympus sp-560 uz
I had this problem and managed to fix it. The camera was dropped on a stone floor and the zoom error was present every time it was turned on. A ring or other piece of the lens was bent or damaged, in my non professional opinion. A profesional repair is my advice. However you may try my fix at YOUR OWN RISK.
Switch camera on, when zoom extends, but before it closes down due to zoom error, gently but firmly push lens back in. Drop batteries for camera to reset itself. Repeat, if necessary.
My camera now operates fully and when the lens extends it now no longer makes the slight grinding noise.
Good luck and remember at your own risk.
Jul 30, 2008 | Cameras
Zoom mechanism making noise
well i had the same issue and i just slammed it (carefully of course) on the desk and it started working.... does it still zoom or does it just click and grind? also try zooming in and turning the lens faster outward or the oppsite direction to see if you can jump it back into the correct place on the gears.... my best guess is that it got dropped or the kids sat on it... and it made the gears slip into a bad place....
Lee
Founder Of Free Tech Associates
www.whypayforhelp.org
May 27, 2008 | Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX...
Noise while zooming with sb-600
sb-600/800 make a distinct motor-spinning noise when zooming, this is normal. Any grinding/clicking noises are not normal.
Jan 25, 2008 | Nikon Speedlight SB-600 TTL Flash
SumacLife Brand Sony Cyber-shot DSC-HX5V Cybershot DSC HX-5V Digital Camera Case - Red 6 inch Mini Tripod Adjustable mount angle Screen Protector Logo
192 people viewed this question
Top SumacLife Photography Experts
pontelemon
pontelemon
Tony
Are you a SumacLife Photography Expert? Answer questions, earn points and help others
