Why can't I get hot water to fill?
I believe the filter is clogged and can see calcium build up. Can this be removed and cleaned?
  • Washing Mach... Master
  • 5,323 Answers
Try that and also checking ur water inlet valve and WATER temperature control switch with a meter for continuity OHMS
Posted on Apr 29, 2015
Dishwasher not cleaning
Remove the panel at the base of unit below door you should find the tech sheet which will tell you how to place unit into diagnostic, on the spray arms make sure the small holes are clean below the lower spray arm is a screen make sure it is clean not covered or cake with calcium build up if it clogged water cannot pass thru to enter the wash pump you can also remove the screws to take the upper halve apart to inspect the wash pump for any obstruction it is possible you could have a bad motor control or both you didn't mention after the unit fills do you hear the wash pump hum or click
Feb 07, 2014 | KitchenAid 24 in. KUDK02CRBS Stainless...
Wascomat w630
Try taking your fill hoses off and clean the screen filters in the ends of them, They will build up with calcium and clog up.
Dec 19, 2013 | Washing Machines
Dishwasher not cleaning dishes; water not coming out of top spray arm
You are right to go to the inlet filters. If they are clogged you would lose pressure, but not that much...The pressure pump is probably not outputting any longer. Locate it and see if it is moving freely.
Jan 14, 2013 | Dishwashers
Can I use tap water with the S3101WT model
Yes, you can use tap water - either hot or cold.
It's recommended that you fill with clean cold water, but if you fill it with hot water, it will generate steam faster from startup. The most important thing is not to overfill it beyond the MAX mark on the tank.
Mar 07, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My dishwasher spray arms were clogged with calcium buildup so I cleaned one and replaced the other. I also removed the fixed disc-shaped device underneath the lower spray arm and found the particle filter...
you may want to check your hot water tank. It may need drained and cleaned, Or you may have the rod in the tank disintegrating. Also check you water faucet areators to see if they have calcium pieces too.
Feb 10, 2011 | Maytag Dishwashers
I only used my machine for just about two weeks (only in the evenings)with a brand new filter and already the top of the filter has turned yellow/brown and brittle. Is it normal to go through a filter so...
how long the filter will last depends on your water .. if your water has a high mineral content then that is left behind as the water evaporates from the filter/wick ... the yellow brown sounds like calcium deposits .. calcium is often added to water to give it a good taste .. that may be beneficial for you but will build up on the filter .. it doesn't hurt much until it starts to clog the voids in the filter material .. as long as air gets thru then the deposits will be ok .. normally the filter should last about 3 months .. if you use distilled water (with no calcium added) then much longer .. if you have hard water then less .. there is a tablet that you can add to the water to reduce the calcium buildup .. the manufacturer of your humidifier will likely recommend that .. thats often available from hardware stores also ..
so your choices are:
1. don't worry about it until the filter becomes clogged
2. use the anti calcium tablet or something like ProTec PC-1 Humidifier Tank Cleaning Cartridge
3. use distilled water for really long filter life
4. plan on replacing the filter every 3 months
other types of humidifiers have other problems .. the hot water type gets calcium deposits on the heating element requiring cleaning a couple times a year, usually with vinegar or a calcium solvent .. that takes awhile..
the Ultrasonic type doesn't generally have problems with internal deposits because it blows moist air out including the calcium .. that produces a fine dust on surfaces in your house ..
of those types the filter system like yours is easier to maintain than the hot water type and doesn't leave dust behind like the ultrasonic all work better and longer if the water is pure .. distilled water doesn't cost much but you have to be careful .. read the small print .. some of it will say "calcium added" .. you don't want that .. if you use only distilled water then the filter should last the whole year ..
Sep 26, 2010 | Vicks Cool Mist V3500 Humidifier
The water is not clear any more we have white residue in the kettle. We did change the filter and emptied the tank 3 times before insulting the new filters.
I don't believe that any filtration system is capable of removing dissolved calcium from water and that is what causes the white deposits. Water softeners will, but I don't like the idea of dissolved salts in our tap water.
Oct 24, 2009 | General Electric GE SmartWater Household...
Dishes all cloudy and spotty. Maytag Intellisense plus 1996 dishwasher. I have real hard water that leave white calcium build up. I can remove and clean all of the lower spray arms and filter. How do I...
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Mar 11, 2009 | Danby 22 in. DDW399 Free-standing...
Humidifier filter clogged in one month with white residue
thanks for you question,
the residue that you are seeing is Calcium, it is a natural mineral that is found in all water, the easiest way to remove the calcium build up from your humidifier screen is to use (CLR) it is a calcium, lime and rust remover, a simple diluted mixture with water, then soak the screen for about half an hour, rinse the screen then reinstall, a soft water system would help with the calcium build up as well, but tend to be alittle on the spendy side, your could try inline mineral filters that need replacing yearly, I really hope that helped ansewr your question, let us know with some feed back, thanks again for your question, mr.grzz
Jan 21, 2009 | Honeywell HE220A1019 Whole House...
Whirlpool built in dishwasher. not aware of model number
Putting vinegar in the bottom of the dishwasher is not going to help because it has nothing to do with the FILL cycle. The bottom (or sump) actually is used during the WASH and DRAIN cycles. I would check the fill port where the water inlet hose goes into the side of the wash tub. You will need to pull the unit out and locate the inlet hose on the SIDE of the dishwasher. The hose should be a black rubber hose located on the left-hand side of the machine. I had a very similar problem that turned out to be calcium deposits clogging the fill port BEFORE it got to the fill valve. With the unit turned off, I removed the rubber hose and used a small screwdriver to poke straight down into the fill port and break up a bunch of calcium. The unit worked fine after that. It is normal for some dishwasher models to drain if they do not detect enough fill water, or if they detect a leak. Usually when the fill port becomes restricted or clogged you will find puddles of water forming under the dishwasher. You might want to remove the bottom panel and check for leaks as well (if you haven't done so already). If you check the fill port and it is clear, the fill valve could be a possibility as well. However, you mentioned you could hear water running which leads me to believe that you have a simple clog somewhere...but, the valve could have accumulated some deposits as well. Check the fill hose and let me know. Good luck and I hope this helps you. PS Another common mistake people make is to put drain cleaner in their dishwashers. This can damage the pump and chopper assembly. Not to mention, it could be harsh on the some of the rubber seals. Not a good idea.
Jul 30, 2007 | Whirlpool 24 in. DU1055XTP Built-in...
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
