Question about Dell Latitude D600 Notebook
Dell Latitude D600. Locks up while loading windows XP
My son laptop is freezing up everytime. Once it gets turned on and windows XP loads and goes to desktop. If you try to click any link on the desktop it locks up. I also notice that the intel wireless icon is not found
in its usual place. I tryed starting it in safe mode and it seems the computer doesn't lock up when you run it in safe mode but I can't get online
to get support in safe mode. Anybody have any Ideas what I can do?????? I tried to restore setting to an earlier date and that didn't fix the problem.
  • 31 Answers
Re: Dell Latitude D600. Locks up while loading windows XP
Yeah run a good online trojan , spyware and antivirus check
you can start in safemode with network support and do those scan assuming you are on cable or dsl via a lan card
I would run all 3 if it was me
Hope that is helpful
Posted on Nov 14, 2007
Hey my dell latitude d600 wont turn on .. it flashes when i press on button but then only flashes the locked buttons ? please help me
Posted on Jul 08, 2008
  • 58 Answers
Hijackthis is a first line tool to examine certain areas of the computer. It does not show everything and lots of malware is hidden from it
To download Hijackthis
go to and download 'Hijack This!' self installer. Save it to the desktop or other suitable place. DO NOT just press run from the website Double click on the file and it will install to C:\program files\hijackthis and create an entry in the start menu.
Click on the entry in start menu to run HijackThis
Click the "Scan" button, when the scan is finished the scan button will become "Save Log" click that and save the log.
Go to where you saved the log and click on "Edit > Select All" then click on "Edit > Copy" then Paste the log back here in a reply.
It will possibly show issues deserving our attention, but most of what it lists will be harmless or even required,
so do NOT fix anything yet.
Someone here will be happy to help you analyze the results.
Thank you Ian C.
Posted on May 11, 2008
0 characters
3 Points
Dell latitude D830 will boot up to windows XP screen and then will freeze. reboot and comes up with gray screen. F2 during booting does nothing. What could it be?
Turn on the Laptop and as soon as you see the Dell screen click F8. Then click on Safe Mode Networking. Once you log into your account you will then go and download the portable version. Then run a complete scan. Then remove any viruses it picks up
Feb 05, 2013 | Dell Latitude D600 Notebook
When I turn on my Dell Latitude D600 PC, the windows xp loading page appears. After it has loaded the screen turns black and does not make any further progress.
It appears that your display works fine until Windows XP loads. Try tapping the key when powering on the laptop. Select boot in safe mode and see if the laptop works.Here's a description of safe mode by Microsoft.
Safe mode is a troubleshooting option for Windows that starts your computer in a limited state. Only the basic files and drivers necessary to run Windows are started. The words "Safe Mode" appear in the corners of the display to identify which Windows mode you are using. If an existing problem does not reappear when you start in safe mode, you can eliminate the default settings and basic device drivers as possible causes.
If you don't know the cause of the problem, you can use the process of elimination to help you find the problem. Try starting all of the programs you commonly use, including the programs in your Startup folder, one by one, to see if a program might be the cause of the problem.
If your display works in safe mode then you have a video driver issue or virus or software issue.
Jun 20, 2011 | Dell Latitude D600 Notebook
My latitude d600 wont start up!
hi, your windows explorer is corrupted. to solve this, simply insert the xp installation cd and boot from it. then run repair to fix the os. note your files will not be lost
Jan 24, 2010 | Dell Latitude D600: Pentium M 1.6GHz,...
Blue screen on a dell d600
did you install the correct driver of your video card?
is your machine was preloaded with vista then re-format to xp? there are some complications if the machine is loaded with vista then change to xp.
i suggested you put it back to windows vista.
Jul 01, 2009 | Dell Latitude D600 Notebook
Please Help! My Laptop keeps freezing
even if u hav a tried a full format and the hard drive freezes then it is a bad a diagnostic of hdd by pressing F12 at good thing i want to tell u is tat even if the diagnostic test on the hdd passes,,then also u call up dell tech support and get ur hadd replaced,,because sooner or later u might face a problem with ur hadd again..keep me posted
May 14, 2009 | Dell Latitude D600 Notebook
Locks up and screen freezes. Will work after I push on it.
I think 6 flashes means memory issue. You might want to try and remove and re-insert the memory. Usually found underneath in a compartment held in with 1 screw. If this don't work, I would try and purchase new memory. This would be the cheapest and first thing to eliminate.
Mar 12, 2009 | Dell Latitude D600 Notebook
You need your Windows XP cd for this fix.
Boot from the Windows XP CD and at the first prompt, press "r" for repair. Press 1 when asked to choose windows installation and then enter the admnistrator password. If you don;t have one, just press "enter" and it should show you "c:\windows>"
At this prompt, type the following
chkdsk /r
THis should take quite sometime but will fix the problem at the end. when you get the c:\windows prompt again, type the word "exit" and your system will reboot and load windows XP normally
Mar 07, 2009 | Dell Latitude D600 Notebook
Can't load windows xp onto my dell c610
when you are trying to install xp what method are you using
how are you doing it
Jan 20, 2009 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
793 people viewed this question
Top Dell PC Laptops Experts
Sudeep Chatterjee
Sudeep Chatterjee
Donna Sander
Are you a Dell PC Laptop Expert? Answer questions, earn points and help others
