Question about Garden
Why does the engine shut off when I engage the mower blades?
STARTS AND RUNS FINE UNTIL TRYING TO ENGAGE THE BLADES. BRAKE, SEAT, REVERSE SAFETY SWITCHES APPEAR TO BE WORKING FINE.
  • 3,519 Answers
Hi Btcret93:
If you're sure the shutdown is not elecrical safety initiated, Then it's probably mechanical.
Try running it up on a ramp so you can see under the deck. With the engine off, check to make sure that the blades are free to rotate and that there is nothing jammed between them and the underside of the deck. This would be an opportune time to give it a really good hosing out to make sure that it's not built up with dried grass or other stuff.
Hope this helps.
Posted on Apr 29, 2015
Testimonial: "THANK YOU FOR THE INSITE, WILL CHECK THAT ALSO."
I have a Husqvarna GT54LS riding mower with a B&S engine. It starts and runs well. When I engage either the mower deck or the differential lock, the engine stalls. What can be the problem?
occupant switch on seat thinks there's no operator in seat with blades engaged , so safety ckt shuts engine off
seat switches go bad sometimes
Sep 14, 2016 | Husqvarna Garden
While I was cutting grass the Engine shut down. Pulled the brake up. Push the PTO back down to shut the blades down. I started the engine, engine runs perfect.
try replacing the battery most with an electric clutch PTO have to have a really strong battery as the alternator system is not strong enough by itself
Jun 16, 2015 | Garden
Why does engine stop when clutch released or blades engaged?
Make sure have a good battery when you start the blades on any lawnmower it need lots of power to get it going
Jul 17, 2014 | Murray Garden
Dies when try to engage blade
there is a switch underneath seat that shuts blades off if not pushed down or there is another one on the reverse that shuts off blades off when mowing one could have went bad hope it helps
Apr 16, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My craftsman mower shuts off every time the blades are engaged. What is the problem?
you most likely have a shorted or open safety switch. you did not mention year or model # so I can only guess what configuration you have, but typically there are the following safety switches on a riding lawn mower: clutch/brake on switch (under floorboard at clutch, this allows you to get off the tractor with engine running if brake is applied), Reverse gear safety switch (will shut engine off if attempting to go in reverse with blades on...follow the gear handle rod down to transmission, may be internal or external of differential), there is also usually a disable switch to allow blade operation in Reverse and this is usually relay operated via a button or turn of the key position, Seat safety switch (under seat and usually is disabled via engaging the clutch/brake switch, this switch will kill the motor if you come off of the seat unless brake is applied), and of course a switch that is tied in to tell when blades are engaged (engage handle or PTO switch). It is actually simpler than it sounds and you dont' need to be an electrician to figure it out. start out with a visual inspection of the switches that you can see. I would suspect the transmission position (reverse) switch first, do you have an override? if so, turn it on and see if engine stays running with blades engaged. hope this helps and here is a link to a company that deals mower parts and has alot of great parts breakdown illustrations online. A craftsman is pretty much the same as a MTD or White Outdoor model, so look those up and it will show you the areas where switches are.
http://www.superxpower.com/pages/parts/viewbybrand/55/HusqvarnaPowerEquipment.aspx
Apr 18, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
When I engage the mower blades, the tractor tries to stall
Hi..my name is Keith..and the newer mowers have all kinds of safety switches..and the mowers will shut off..if you put the mower in reverse with the blades on..so i would suspect you have a bad reverse safety switch..i hope this will help..if not please write me back
Jul 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower blades engages but when I stop to empty grass they will not
yes it is there is one under the seat & under the dash & there is also one connected to the clutch/ brake peddle which is more than likely the one giving you problems is the clutch/brake peddle switch
Jun 22, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
May 14, 2009 | Mtd Garden
Blades will not operate
Hi..my name is Keith..i dont know how new your mower is..but on the fairly new to new ones..there is a safety switch on the reverse that will shut the engine off if your try to mow in reverse...and thats the one that sounds like its at fault..i hope this has helped
Apr 11, 2009 | Garden
Garden Logo
53 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
