I need help with my roku. Can you help me get ip address from seriAL number
  • 3,957 Answers
You cannot get an Roku IP address from a serial number - they have not relationship.
This should help you:
http://www.scottallen.com/2013/04/how-to-fix-a-roku-that-wont-connect-to-the-internet/
Posted on Apr 29, 2015
4 Suggested Answers
battlesmith
  • 382 Answers
SOURCE: cisco router 1841 connected to serial interface
Theres no need to setup for the nat but please check the wan interface and subnet mask ip it has to something else and not 255.255.255.252..Try 255.255.255.240 it must work...
Posted on Jul 29, 2008
  • 73 Answers
SOURCE: need IP address on a pc i have serial number can i
If you need to run ipconfig from command promt to see Ip address asigned to your PC
Posted on Sep 23, 2009
rossmarc
  • 4 Answers
SOURCE: nedd ip address from my hd streaming router roku
http://forums.roku.com/viewtopic.php?f=28&t=46648&start=0
Posted on Nov 17, 2012
I'm needing a ip number for my roku stick help
I'm guessing that what you want is to connect to your network. To achieve that you must have a router, and the router will give you the IP. You can set it from the Roku's settings.
May 09, 2016 | Roku Televison & Video
Where do I find the IP adress so I may connect manually.
https://wwwimg.roku.com/static/oldlib/roku_player_documents/rokuplayerug.pdf
page 23 change network settings
then page 14 on wi fi settings
if new service provider gave you the encyrption key and has dhcp on then this should start Roku working on Wi FI.
New service provider would have installed a wi fi router this is most likely on 192.168.0.1 or 10.0.0.1 go to cmd prompt type in
ipconfig
then press enter key
Not the default ip address
the router should have a wi fi security option that tells you if the wi fi is encrypted and what ssid is being broadcasted.
DCHP should be enabled Roku will use this to assign itself an ip address once connected to Wi FI.
you need to know routers admin user name and password as well
Apr 18, 2016 | Roku 1
Ive had a Roku installed I my living room for several years now without any problems. I recently purchased a new roku 2 for my bedroom and installed it everything works great on the new Roku 2 but the old...
Check the IP addresses of the units. They may have the same IP number. If they do assign each of the items in your network a static IP and it should work.
Jan 01, 2015 | Televison & Video
Just installed roku. How do I find password for Home_B698
You will need to login to your wireless router on your computer to get, or set, your network password for "Home_B698". A typical default router IP address is 192.168.0.1, but there can be any number of possibilities depending on router type, and network configuration, and who set it up... Some routers will put their default IP Address, and password on a sticker, located somewhere on the router. If this is the case, type the default IP Address into a browser on your computer, and hit enter, or return. A web page should appear asking for login information... User name, and password. Again this information varies... Typically the default user name is "Admin" or "admin" you can also try leaving this field blank, and just entering the password found on the router. In some cases the password is actually "admin" while leaving the user name blank.
If your successful at loging-in, you need to look at your wireless settings, under one of the sub-tabs you should find a password field indicating your network password. This is what should allow you to login to your network with your Roku device.
Nov 15, 2014 | Roku Streaming Stick
Had to get a new router now my roku says my network is not shown
Sir,
The quick fix: make sure your router's DNS settings are properly set to an External IP address. If DNS1 or DNS2 show up as internal IPs such as: 192.168.1.x, then your Roku won't connect to the Internet.
Here is the detailed fix:
  • Login to your router. (typically this is done through an internal ip address like 192.168.1.100). You enter this IP address directly into your web browser same as you would a website. **NOTE some people actually enter web addresses into Google, and then navigate that way. This won't work. Enter the IP address directly into the browser's Location or Navigation bar at the top. This will take you to your router's login screen. *NOTE sometimes the router's default password is "password". But it's possible that your password was changed during installation. If you don't have your router's password, contact your Internet provider.
  • Once logged into your router, navigate to its DNS settings. My guess is that if your Roku isn't working, it's because rather than an external IP address being used for your DNS, the router is set to use an internal IP address. (Your computer is able to overcome this because it has built-in DNS settings, but the Roku looks to the router for this information.)
  • Replace the internal DNS address with a public DNS address. What worked for us was using Google's public DNS. So set DNS1 to 8.8.8.8 and DNS2 to 8.8.4.4 .
  • Save your settings.
  • Run the Roku setup again. If you still aren't able to connect to the Internet, then bounce (unplug) the router. Leave it unplugged for 15 seconds. Then power it back up. Try again with the Roku. If that doesn't work, bounce the Roku. Leave it unplugged for 15 seconds, plug the power back in. The 15-second rule with computers and hardware is surprisingly effective.
  • If you've set the DNS properly, your Roku should now (finally) connect to the Internet. When this happens, it will complete its setup process and you should be good to go.
In case You Still having Belkin Basic Wireless Router Issue Then Visit
How to Fix Roku that Wont Connect to the Internet
Or Follow Us For online Belkin Wireless Support On: Belkin Support
Feb 28, 2014 | Belkin Basic Wireless Router
Roku trouble
A default IP address for any device is 198.161.1.1 but you can set it to whatever as long as you leave the second number at 255.255.0.0
Like the IP can be 198.161.1.2 for example to keep devices from interfering with each other.
Jan 23, 2014 | Televison & Video
My laptop was stolen, the police said they can track it if i gave them an IP address, I dont know what the IP address is but I do have the serial number, how can I get the Ip address using the serial...
Stolen laptop can only be recovered if you have MAC address of laptop. IP adress are temporary and can be changed or altered, its not worthy to find IP instead try to get MAC adress.
If you have registerd your laptop with its Manufacturing Site like Lg, DELL etc then you can contact them and probably by providing them serial no. you can get MAC address. Every machine ha different MAC address and I am sure with your serial no. you can get this information from your dealer or manufacturer. GOOD LUCK
Feb 05, 2011 | Computers & Internet
Computers & Internet Logo
95 people viewed this question
David Payne
David Payne
