Question about Brother MFC 7360N - Multifunction fax / copier / - MFC-7360N-US
How do i fix faded lines on copies
Copies are coming out with fading words on one side of paper
5 Suggested Answers
  • 58 Answers
SOURCE: black line on paper
There is either something on your cid/ccd unit under the glass.You may have something on the glass,or there could be a sratch on the thermal print head.Inspect each unit, it is usualy something easy.
Posted on Oct 18, 2007
  • 56 Answers
SOURCE: faded prints about 2" in from the margin
Greetings!
{You used the term "drum". This may indicate a roll type of toner rather than a cartridge style of toner. The following tip is for a cartridge style.}
I get much the same symptom when my HP laser cartridge is running low, and no, it doesn't have a "low toner" indicator either. I get by a little longer with mine, long enough to get out and buy a new one that is, by removing it, holding it over a garbage can at an angle and firmly tapping on it to loosen any compacted toner. I then turn it back horizontally and gently shake it back and forth to evenly distribute the remaining toner through the cartridge and reinsert it into the printer. This usually gets me nice, even prints back and extends the life of the cartridge. I can usually get a few extra weeks out of it by doing this two or three times.
Rob
Posted on Jan 14, 2009
SOURCE: black line down one side of paper
Lift the auto feeder cover and clean the narrow glass that the originals are scanned across...sounds like you have some dirt there -maybe correction fluid? That's the most common.
Please rate me :)
Posted on Jun 23, 2009
  • 105 Answers
SOURCE: faded strip down length of paper
CLEAN DRUM UNIT AS PER MANUAL . IF THAT DOSN''T WORK TRY REPLACING DRUM AND/OR TONER
Posted on Aug 26, 2009
Faded print on right side of page. When I copy/print in black, why is the black print faded on the right side of the paper?
Your toner cartridge may be the culprit.
Take the cartridge out and shake sideways and up/down. Reinstall it and try again.
If it's still printing faded side, replace the cartridge.
Jul 30, 2014 | Brother MFC-9840CDW Laser Printer
Dell 1110 faded print left side
If you have trid a different toner cartridge, then I would first try a new drum (not sure if toner & drum are in same cartridge, some are so you will have to check that) If not that, then I would suggest the transfer roller bar would be my next suspect if the printer has a lot of copies done on it.
Jan 13, 2013 | Dell 1110 Laser Printer
Copies Still Faded After Changing Toner
can be the wiper blade, worn out drum, is there a black faint line down the side of the page as well?
May 30, 2012 | Ricoh Aficio Mp 4000...
I can't get my Konica Minolta PagePro 1350W printer to print a Word document. The printer was working a couple of days ago. There is an "error" in the Control Panel window & the print window...
I take a picture using a screen capture program/app then print the picture. It also make it possible to overlay things such as the (faded) word (COPY) on top or underneath it, if you want. When I use the COPY method, I print the faded word COPY first then re-run the paper through to print the rest
Jun 05, 2017 | Konica Minolta PagePro 1350W Laser Printer
I have a HP 7590 printer and it sometimes skips line or some of the lines are faded when printing black .
Perform the following steps to reduce or eliminate faded or grainy lines:
  1. Print at a higher quality setting.
  2. Verify that the paper you are printing on will lay flat. Paper that is not laying flat can cause banding when the paper transitions over the rollers or cause the print cartridges to scrape across the surface of the page. Check the top sheet of paper by removing it from the all-in-one and placing it on a flat surface. If the paper does not lie flat, bend it in the opposite direction to straighten it. Figure 3: Faded or grainy bands in print caused by paper that is not flatc00178858.gif 1 - Faded or grainy bands due to roller transition with paper that is not flat. 2 - Faded or grainy bands due to print cartridge scrape on paper that is not flat
Jan 06, 2011 | HP Officejet Pro L7590 All-in-One InkJet...
It will copy but the it will light and faded. Hard to read.
Too much moisture in the paper will cause blotchy, light and faded print. Run the copy through a second time on the reverse side. If the second side is good you have a paper moisture problem. (Usually happens in non-airconditioned spaces during humid periods if the paper has been stored in the open.) Hope this helps.
Sep 08, 2010 | Sharp AL 1631 Copier
When 2-sided copies are made using the feeder,
hi just clean the paper path to solve the problem
thanks
May 11, 2010 | Canon imageRUNNER 5000 Copier
Making a clean copy of an old fainted typed document
I installed paint.net and adjusted the contrast level of the document. Excellent.
Jan 02, 2010 | Office Equipment & Supplies
Toshiba e 650 Copier was working and copies were fading so we
When you changed the toner did you remove the strip on the new toner to release the toner
Jun 12, 2009 | Toshiba E-STUDIO 650 Copier
Brother MFC 7360N - Multifunction  fax / copier / - MFC-7360N-US Logo
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
