Question about Health & Beauty
Can i get a manual for my oximeter and a strap to go with it
Change battery in OxyWatch oximeter
First off, figure out what model of oximeter you have. There seem to be about 6 different ones.
Email the manufacturer at;
support@choicemmedamerica.com
Ask them for a service manual for the model that you have. And also for explicit instructions on how to change the batter, and what type of replacement battery it uses.
Mar 02, 2015 | Health & Beauty
What does a pulse oximeter measure?
the pulse oximeter measures the oxygen saturation of your blood without having to take a blood sample
Jan 30, 2013 | Health & Beauty
What exactly is a pulse oximeter?
A pulse oximeter is a medical device that indirectly monitors the oxygen saturation of a patient's blood (as opposed to measuring oxygen saturation directly through a blood sample) and changes in blood volume in the skin, producing a photoplethysmogram.
My mother has a Digit Pulse Oxymeter and I was wondering how one knows if the %oxygen is reading correctly. Lately all her readings are always 97%. Very little variation.
The normal oxygen saturation in the body read by the any pulse oximeter whether it is portable or built in type is 95%-100%. If ***********'s oxygen reading as you have said is 97% definitely it is within the normal range. You can also check and make sure that your oximeter is working by placing the oximeter to your finger. If the pulse read by the oximeter is the same with your heartbeat it means that is working alright and the oxygen reading would fall between 95-100%. I hope my answers will help you.
Aug 26, 2010 | Probasics Digit-Ox Finger Pulse Oximeter
User's manual for a Contec Pulse Oximeter CMS50
Here is a link where you should be able to download the appropriate manual for your product.
http://www.contec-oximeter.com/sdp/499627/4/home-2955239/0/Brochure_Download.html
You did not mention which version of the cms-50 that you own and apparently there are several. But the link includes different versions so you should be able to download what you need.
Hope it helps. Please let me know
Thanks
Apr 22, 2010 | Contec ECG Monitor & pulse oximeter
Directions on replacing battery
Found manual online and found page with replacing batteries instruction
Feb 04, 2010 | Probasics Digit-Ox Finger Pulse Oximeter
I need a Battery SPO Medical 903036 Mate Pulse
I am doing the same thing. Found the 903036 on Amazon, and scrolled down to "Frequently Bought Together" and found a lithium battery. Am thinking that is the one. http://www.amazon.com/SPO-Medical-903036-Check-Oximeter/dp/B000BQKH9W
Oct 08, 2009 | NRS SPO Medical 903036 Check Mate Pulse...
No reading for the blood oxygen level
OK - I had the exact same problem. I cleaned the inside of the oximeter with a cotton swab and denatured alcohol. Then tried it. It did not work. Darn. But I tried it an hour later, and suddenly, it started to work perfectly. I do not know what went wrong, and why it did not work immediately after cleaning. Maybe it was still damp from the alcohol? Unlikely, but I cannot figure out anything else. Anyway, try that and see if it solves the problem for you, and if the oximeter does not work for the first hour or so after cleaning, don't give up on it. Good luck.
Feb 05, 2009 | NRS SPO Medical 903036 Check Mate Pulse...
Health & Beauty Logo
551 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
