Question about Sharper Image Drink-O-Matic
I NEED A 12 VOLT CORD - Sharper Image Drink-O-Matic
2011 keystone cougar 27rls. How to switch from battery to electric.
you shouldn't have to switch if it has a generator there is a switch or plug to plug shore cord into but otherwise shore cord will run converter for 12 volts if inverter 12 volts runs but inverter only feeds certain outlets
Aug 26, 2017 | RVs
Can I use a 12 volt DC power supply with the Meade 4504 scope? I have a missing battery pack...and the input power says 15 volts Mant thanks
Yes you can just make sure that the power cord has the CORRECT pin polarity- you can order the 12 volt cigarette lighter style cord from Meade.
http://www.meade.com/support/index.html
Jun 27, 2011 | Meade 114EQDH4 (36 x 114mm) Telescope
Toro 8" 12 volt trimmer.
Look at this tip, an oldie but a goodie:
http://www.fixya.com/support/r2827867-winding_line_trimmers
Should be what you need.
Best regards, --W/D--
Jun 03, 2011 | Toro 13" Corded Trimmer - 51358
Craig High Definition LCD TV (15.6 in) power cord
The power source is a 12 volt transformer so you can use a standard universal power supply. A 12 volt DC Power Cord with Auto Cigarette Lighter type Adapter will work in an auto.
Nov 03, 2009 | Televison & Video
Missing power cord 12v
go to radio shack get a 12 volt 1500ma power supply with I belive it is a N% plug end but any how 800 ma to 1500 ma should run this and the plug end is standard plug with plus 12 volts on the inner side and negitive on the outer case side look at the back of the TV or the old power supply it sould have info on voltags and amprage, and the plug as to inner voltage and outer voltage on the plug any old time radio shack or electronics shop should be able to help you bring in the flat screen if need be as if you know its 12 volts then It wont mater weather you use a 1000ma 1500ma 12 volt ubnaversale power pack as the tv will only use the current needed so more MA is good the only concrn you have is the right mini barrle plug and the right side of +/- voltage on that mini plug being most use + voltage in the inner most circle and - 12 volts on thje outer
Apr 05, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
13" sansui AC/DC 12 volt use
Did you check the fuse inside the plug on the 12volt cord?
Feb 01, 2009 | Sansui COM312AD 13" TV/VCR Combo
Whistler 35R just quit. fuse and pwer cord is fine.
Orginal whistler power cords do not have LEDs lights in them and there is no electronics in the plug - 12 volts in, 12 volts out. Sounds like you have a bad cord or a cord that is meant for a GPS unit or other 5 volt device.
Sep 02, 2008 | SRT-35R Radar Detector
Sharper Image Drink-O-Matic Logo
66 people viewed this question
Top Sharper Image Retail Supplies Experts
Fix-o-Matic
Level 1 Expert
Are you a Sharper Image Retail Supply Expert? Answer questions, earn points and help others
