Question about ViewSonic VT2430 24"" LCD TV"
How to remove back cover of viewsonic VT2430
I have a viewsonic VT2430, how do I remove the back cover, I already removed all screws on the back, no other screws are visible, I removed big and small screws, all corners and in the middle, I still cannot remove the back cover, I tried a bit of force from the bottom corners and still no go...is there any trick to remove the back cover ?
  • ViewSonic Master
  • 3,957 Answers
Download the service manual from here:
http://elektrotanya.com/viewsonic_vt2430-1m_vs12335-1m.pdf/download.html
Posted on Apr 29, 2015
Testimonial: "thanks, I downloaded the manual... as described in the manual is where I am stuck, following the manual direction I will damage the cover cause I need to really force the cover out and it will bear the tear... not friendly design... but thanks for the link"
Im Electronic tech onboard one of princess cruises line. IHas problem regarding Viewsonic VT2430.. when switch on it goes off in slpit seconds and continuesly by itself, give me the solution for this..
First check the power outlet, try connecting the TV to a different power outlet. Check for any jammed buttons on the remote. If it does not work still, this might need attention by a qualified service technician.
Jul 15, 2012 | ViewSonic VT2430 LCD TV
HOW DO I AUTO SCAN CHANNELS ON VIEWSONIC VY2430
Do you mean the VT2430? Viewsonic doesn't list a VY2430.
For my Viewsonic TV, first make sure that your input is TV. (Press the Input button on the remote (upper left) or the TV (furthest right). Use the arrow keys or multiple presses of Input to change the current input.) Next press Menu. Use the up/down arrows to navigate to the TV menu (the icon looks like a TV). Press Enter. Set the type of incoming TV signal (Cable or Air or let the tv figure it out with Auto). Then go down to the line labeled AutoScan and press Enter. You may be prompted to begin the scan or to select the type of channels to scan. Press Enter again after making the selection.
Viewsonic has the manual for the VT2430 available on their site: http://www.viewsonic.com/products/vt2430.htm#tabbox_downloads . The direct link is http://www.viewsonic.com/assets/041/11502.pdf .
I hope this helps.
Sep 02, 2011 | ViewSonic NextVision HD12 HDTV DTV...
Viewsonic vt2430. when i want to connect the tv to my pc the screen come in blue. i can see my desktop on it but everythings blue
I have the same problem it just started happening today and I have yet to find a solution so please post anything you find out thanks!
Aug 18, 2011 | ViewSonic VT2430 LCD TV
Why my viewsonic lcd tv keeps on restarting
An internal component is most likely heat sensitive, shutting off, cooling of slightly, and then turning back on. The unit will have to be troubleshot. Call the store it was purchased from for options of repair. You can also contact Viewsonic suport here:
http://www.viewsonic.com/support/customer-service/
Some loca TV repair shops have mobile services, where they will fix it at your place. Look in the Yellow Pages for TV Repair.
Good luck, and hope this helps.
Feb 23, 2011 | ViewSonic VT2430 LCD TV
I have a viewsonic VT2430 everytime i press a key on the remote and on the tv it says "button locked" how do i unlock it?
Hold down the volume buttons on the tv itself and it should display "unlocking buttons". Hold them down until it says ""unlocked".
Jan 27, 2010 | ViewSonic VT2430 LCD TV
Button lock is on (I don't know how); now tv says
Nov 20, 2009 | ViewSonic VT2430 LCD TV
How to remove back panel
there might be screws behind the foot. remove the foot base first...then look to see. alot of these screens are pressure tab case fasteners.they use screws to lock in the cover. after that a smakk flat screwdriver along the lower sides will reveal is the cover is tab fixed .\
good luck
May 18, 2009 | ViewSonic VX922 19" Monitor Flat Panel
Remove back panel
You have to remove the base at the bottom (4 screws), all the screws on the back, then use a thin flat-head screwdriver or other thin brybar and work around the back panel unlatching the snaps that are in place.
After the back cover is off, the metal cover over the board and power supply can be removed by removing the screws around the outside lip of the cover, along with the screws on the bottom and right hand lip of the raised area in the back.
Hope this helps.
Dec 06, 2007 | ViewSonic N3251w 32 in. LCD HDTV
Vx800 flickers when cold
I have repaired several Viewsonic VX800 monitors. The symptoms include a power light that flickers or flashed on and off or a screen that flashes on briefly or stays off. The problem is bad electrolytic capacitors on the power supply board. These bad capacitors do not look bad and do not swell but they do develop a high ESR (Equivalent Series Resistance). You need a ESR meter to check them. But if you have these problems, you should assume the capacitors are bad and just go ahead and replace them.
First you must open the monitor and gain access to the power supply board.
1. Remove the stand: It is held with 6 screws on the back. Also on the back are 2 black screws that must also be removed.
2. Remove the button bar from the front, bottom: It is pried off. This will expose the 2 screws holding the front plastic bezel.
3. Remove the silver plastic bezel from the front: First remove the 2 screws holding it, then you can pry the rest off. This will expose the 2 screws holding the screen to the plastic back.
4. Remove the screen and electronics from the plastic back: Remove the 2 screws holding it. The 2 speakers are glued to the plastic case. Cut the glue with a knife. The screen and electronics and speakers should lift out of the plastic back.
5. Remove the metal cover to expose the electronics: There are 2 screws holding the VGA connector and 2 screws holding the DMI connector. There are 9 screws holding the cover. These must all be removed. There is a black plastic sheet glued to the lower edge of the cover. It must be lifted. The cover should now come off.
6. Replace the bad capacitors. The power supply and signal processor are on the same board. It is marked VG800-2. The bad capacitors are surfaced mounted 100UF 25V. The bad capacitors are CM16, CM17, CM2 and CM165. The two most critical are CM16 and CM17, but they all read high ESR, so I just replace them all as long as I have them exposed.
Reassemble in reverse order.
Oct 18, 2007 | ViewSonic VX800 18" Flat Panel LCD Monitor
ViewSonic VT2430 24"" LCD TV" Logo
183 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
