Question about Craftsman YT 4000 42" Briggs Stratton 24 hp Gas Powered Riding Lawn Tract
YT4000 blades not turning
YT4000 Model 917.288573 We did a tune-up over the weekend and installed a new Primary motor belt on the mower deck. Now the blades do not engage, the belt is loose on the engine pulley. We leveled the deck, and the front to back adjustment was off by almost 2 inches higher in the back. I am wondering if the distance that we pulled up the deck in the front was enough to make the belt loose.
  • Craftsman Master
  • 2,321 Answers
I am wondering if you have the right belt for that machine. or possible its not installed properly.The belt should be tight when engaged. The tightener may not be working as well. These are things to check. Does the belt try to tighten up when you engage it?
I am wondering if the wrong belt was the reason why some one lowered the deck too low.
Posted on Dec 20, 2016
  • 5 Answers
SOURCE: i need belt diagram for 42 in deck
You can go to the Sears website an download a free owners manual that shows what you need.
Posted on Apr 25, 2009
  • 57 Answers
SOURCE: craftsman 42 inch deck won't run
Check proper belt routing. These models are a little tricky. Also check tensioner spring.
Posted on May 18, 2009
  • 57 Answers
SOURCE: Craftsman 42" mower deck won't disengage
Try pulling on the cable coming down to deck. This cable might be your problem. Also check that the spring on the end of this cable is present and functional.
Posted on May 19, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
  • 32 Answers
SOURCE: How do I get my mower deck set properly? Any tricks?
check your front tire air pressures
Posted on Jul 26, 2009
How do I determine why the blades will not engage on my mower
With the mower turned off and the deck at its lowest setting, check the top of the deck for any debris like rocks or sticks. Then watch the top of the deck while you move the engage lever. If nothing is moving, you either need to adjust the cable, reattach the cable, or install a new cable. If you see the lever with the pulley on it moving, when the engage lever is locked on, check the tightness of the belt. If it's loose, that is your problem and it could be a stretched belt.
Sep 18, 2014 | Craftsman Garden
What part adds the tension for deck drive belt?
I BET YOU HAVE THE WRONG BELT GET ANOTHER BELT SHORTER OR GET RIGHT SIZE BELT FOR TRACTOR
Sep 01, 2014 | Garden
Dont know wheter to get primary mower belt or secondary mower belt for craftsman gt3000 48 inch deck mower...?
primary belt goes from the engine to the deck the secondary goes on the deck and connects the blades together
Aug 24, 2012 | Craftsman 48" Cut Riding Lawn Mower Deck...
Our indestructible deck has made mowing impossible, it clogs all the time and then "coughs" like it's dying. We have to stop mowing and turn off the blades and turn them on again to shoot the...
Hi and welcome to FixYa I am Kelly.
Maybe I am missing the obvious but I have had a couple of people that had this problem with since new use of a mower. One of them had the wrong blades with the deck and the 2nd one the baldes were installed with the air foil side DOWN. If you have Air-flow problems under your deck the above is possible or your blade deck drive belt is routed incorrectly. The decal for the blade deck belt routing should still be on your deck. Look at the decal drawing vs the actual routing of the deck belt. It is highly possible that one or more of your blades is driving backward.
If you can not find your decal (would be hard not to find it on a deck not 1 year old!), I will try and look it up but I need the model number of mower and the DECK (2 ea model numbers 1 for mower 1 for deck)
Thanks for choosing FixYa,
Kelly
Apr 22, 2011 | Garden
Need a drive belt diagram for a murray lawn mower model 465306x8
Please find attached a "amateur" drawing of the belt routing for the 37x89MA primary deck drive belt. Hope this helps.wefixem.jpg
Mar 03, 2011 | Murray 46 Primary Lawn Mower Blade Belt...
Craftsman 18hp riding mower runs & stalls when engage the blades
motor off= deck engaed turn blade should turn motor and belt fairly easy, NO remove the belt from the motor pulley with deck engaged blades should turn freely.
most decks have breaks on the pullies so if the deck is not engaged the break will be on
May 27, 2017 | Craftsman Garden
My john deere lt 133 mower with a double blade mulching deck, 1 blade stopped working and only 1 blade cuts now, how do i fix this. Thanks Patrick
This model mulching deck uses a flat/ribbed serpentine belt that is set at very high tension.When belt breaks under the cover only one blade will turn due to IT being driven from PTO clutch as the other blade being turned from serpentine belt.This deck was Deere's first and last shot at making a true mulching deck and only made it a couple years.When you buy the VERY expensive belt it will come with detailed instructions on how to install it.Goog luck.
Aug 07, 2009 | Garden
How do I change out the primary belt on a Craftsman 17.5 hp 42" mower? The new belt is around the pulleys but it is very loose.
This belt is easist to install with the deck all the way down. Make sure there are no burrs on any of the pulleys, (will eat up your new belt in short order), also make sure that the 2 drive pulleys for the blades turn freely, (may have grass impacted around them, you may need to remove the 2 guards on top of the deck to clean, (if they do not spin eaisly). Triple check to make sure the belt is properly routed, one mistake and your belt is broken as soon as you engage. With the engine OFF, engage blades to check tension. If the belt is still loose, you likely have it routed incorrectly.
Jun 16, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman YT 4000 42" Briggs Stratton 24 hp Gas Powered Riding Lawn Tract Logo
66 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
