Question about Tablets & eReaders
Need installation files and instructions for 10.1" Laude tablet D101 Mt65xx
I have a tablet - X11 Irulu...I need to know how to delete unwanted files and pictures?
you can install ccleaner in tablet to clear unwanted files and pictures or folders
Go to Play store and search for Ccleaner and get it installed on your tablet..
after it is installed run the app and scan for unwanted files
it will help you in clearing the junk files or temporary unwanted files
Nov 12, 2016 | Tablets & eReaders
I am trying to fix a friend's digital2 tablet the s/n is m961gpl1312 and every time it starts up it goes to the Android recovery page and I've tried to factory reset it and then restart it but it still...
you probably will need to update the firmware
D2_961 Firmware Update Instruction:
1. Download the D2_Firmware in the link below
2. Use an archiving software (Winzip, WinRar, 7 zip etc.) to extract the Firmware Update package and export it to your computer's local disk (ex. C:\)
3. Open up the zip file and there will be 3 folders as shown in image
4. Open "Pad Product Tool 1.05_02" folder and click on "setup.exe" to install update tool.3-284x233.png4-284x233.png5-284x177.png
Click "Next" all the way until the program starts installing. Click "Close" when the software has done installing.
6. Click the 7.png icon and choose the firmware file "jellybean_atm7029_m2909_131216.fw" from the "FW_m2909_961_1115_1216" folder.
7. When the firmware file loads, it will show up on the PAD Product tool.
8. Now, click and hold down the "Volume - "key on the tablet.
9. While holding down "Volume - " key, connect the tablet to a PC using the USB cable.
10. Still holding down "Volume - "key, use a paper clip (or a small pin) and press the "Reset" button on the back of the tablet ONCE (and let go)
11. The 9.png icon will turn into 10.png . Click it to start the firmware update.
12. After the update is complete, remove the USB cable first, then turn on the tablet.11.png
13. The initial start up time may take up to 50+ seconds.
14. After initial start up, tablet will require a reset. Please press and hold the reset button for 10-15 seconds to reset the unit.
http://cloud.d3reaction.com/public.php?service=files&t=2ff2083703cca9cfa4050bd47a793864&download
Jan 19, 2015 | Digital2 Tablets & eReaders
Keeps freezing
shut down running apps in background
Mar 25, 2014 | Digix TAB-840 Android 4.1 OS Tablet PC
How to unlock tablet proscan PLT7223G
Download the firmware update PRO_PLT7223G_FIRMWARE.ZIP
Download the RockusbDrivers from https://docs.google.com/file/d/0B_keThrKc71iYkZXMHNxZWdVT0U/edit
Save these files to a new folder on your desktop.
Unzip the FIRMWARE file and follow the instructions. When you need the tablet drivers, manually install the drivers from the RockUSBDrivers files in the new folder you created.
Jul 19, 2013 | Tablets & eReaders
CURTIS LT7052 TABLET
1.Go to curtis website and get the new firmware package for your device.
2.Google and download TopNotchTablets_Wopadi7_Firmware_Tools_Package because the driver needed is missing from the Curtis website file
3.get windows to NOT recognize your plugged in via USB tablet via the instructions on the curtis firmware instructions
4.point the installer to the correct driver in TopNotchTablets_Wopadi7_Firmware_Tools_Package
5.open and point the firmware application to the unzipped location of the firmware
6. when you see green in #1 then click update firmware,
Jul 18, 2012 | Tablets & eReaders
How do I install my Win XP whn I have changed my harddisk ?
plz follow the steps...
1. Insert windows xp bootable cd into the drive
2. Power on the machine
3. When the logo displays, press F12 to show the boot menu
4. Select the CD/DVD
5. System will start the job
6. After showing Setup is starting windows, it'll shows the install option
7. Press ENTER
8. It'll show the drive but the drive is not partitioned
9. You can easily understand by reading the instructions
10. While creating it'll ask for drive space
11. Put 50000
12. Press ENTER
13. It'll ask for type of file system that you have needed, select the 1st one (Quick using NTFS)
14. It'll ask 4 format the specific drive. for that you have to press 'F'
15. It'll format and copy the needed files
16. System will restart. After restarting it'll start the job. plz wait.....!!! (system restart many times to complete its job)
17. While working it'll ask for the product key, time, etc.
18. Sit infront relax and give the needed information that you can understand easily
thanks & regards
Anas K A
May 28, 2011 | Fujitsu Lifebook T1010 Tablet PC
Tablets & eReaders Logo
63 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
