Question about Sewing Machines
What is a bobbin - Sewing Machines
  • Sewing Machines Expert
  • 483 Answers
The bobbin is the reel that the lower thread is would on. It sits beneath the needle in a case
Posted on Apr 29, 2015
Bobbin is not feeding properly- didn't wind on evenly.
It is important that the bobbin be wound smoothly for the machine to operate properly. First, check that you are threading the machine correctly to wind the bobbin. There is a tensioner for the bobbin winder that helps wind the bobbin smoothly so incorrect threading will cause issues. Also, try to wind your bobbin slower. There is no advantage to winding the bobbin on high speed.
If you continue to have bobbin winding issues, there is a standalone bobbin winder (SideWinder) avlb at JoAnn's or even Amazon for ~$30,. They are electric or battery operated. Be sure to verify your machine bobbins will work on the SideWinder before purchasing as some bobbins are not compatible. The bobbin winder is a handy gadget since multiple bobbins can be wound quickly, plus bobbins can be wound without having to unthread the machine, not to mention reducing the wear and tear on your sewing machine.
Nov 10, 2017 | Sewing Machines
Pfaff quilting machine bobbin stuck
Is there is a wad of thread that is holding the bobbin captive? If so, you'll need to use small scissors and tweezers to snip away and pull out the threads. Patience!
If the bobbin is actually stuck in the bobbin case, it could be because it is the incorrect bobbin for the machine or the bobbin was over-filled with thread. You may just need to use force to remove the bobbin. It may damage the bobbin and, possibly, the bobbin case. They are both replaceable. Or you can pick up an additional bobbin case and bobbin and try the new ones in your machine.
Mar 10, 2017 | PfaFF Sewing Machines
My bobbin thread breaks too much. How do I fix it.
Be sure you are using the correct bobbin for your machine. Even though it appears to fit the bobbin case, if it is the wrong bobbin, it could cause major headaches.
Try a different bobbin. Try different thread.
Also check that the bobbin thread is wound smoothly and turning the correct direction in the bobbin case. Make sure the thread is threaded through the bobbin tension properly.
AVOID old and inexpensive, bargain bin thread!
There could be a nick or burr somewhere that is catching the bobbin thread and breaking it.
Try loosening the bobbin tension a bit. It could be too tight, especially if the bobbin thread is pulling the upper thread down to the underside of the fabric.
There could also be something wrong with the bobbin case itself that may be resolved by trying a new bobbin case (or borrow one from a friend, etc.)
Dealing with Lower Thread Breaking Sewing
Bobbin Thread Breaking How to Loosen Bobbin Tension
Nov 10, 2016 | Sewing Machines
Bobbin not working.
The symptoms sound like it could be the incorrect bobbin. Even if it is tiny bit different, it may not work properly. If it is not an authentic bobbin for your machine, but rather a clone from another source, it may not be suitable. Some machines are very finicky.
If it is in fact the correct bobbin, then there may be a problem with how the thread is wound on the bobbin or how the bobbin has been inserted and threaded in the bobbin case. Be sure the thread is wound very smoothly on the bobbin and that the thread does not extend beyond the outer edge of the bobbin or that no loose threads are poking out from the bobbin. Also verify that it is inserted (and turns the right direction) in the bobbin case and that the bobbin case is threaded properly.
Feb 24, 2016 | Sewing Machines
How to thread a bobbin,sears Kenmore model 158.17031
Place both the bobbin case and the bobbin on the table in front of you. Have the open side of the bobbin case facing up and the bobbin with the thread of the bobbin unwinding clockwise. Drop the bobbin in the bobbin case. Pull the thread tail up through the notch in the bobbin case and then to the left under the thin metal plate until the thread appears to be coming out through the hole in the side of the bobbin case. (When you pull the bobbin thread, the bobbin should turn clockwise in the bobbin case.)
Kenmore 158 17550 Sewing Machine Tutorial
Feb 07, 2016 | Kenmore Sewing Machines
I have a faithful 730 Bernina and currently the bobbin thread keeps breaking. Please advise what may be causing this. Thanking you.
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
here's a free manual
http://www.bernina.com/getdoc/48e8d09f-98f7-40ab-8663-a23663df4fae/Bernette_715_730_740E_manual
Sep 17, 2012 | Bernina Sewing Machines
What's your problem?
if the bobbin thread is winding around the bobbin winder spindle then
the bobbin is not sitting correctly on the bobbin winder spindle,,
the bobbin (metal or plastic) should lock in on the bobbin winder spindle
& the the thread should be around the bobbin tension guide
Apr 04, 2012 | Sewing Machines
I own a "Lena" machine
Hello
Make sure your feeddogs are up. That is the little jagged looking plate under the pressure foot. There should be a setting on your machine that will move it up and down.
If they are up then the bobbin is not in correctly. If it is a normal round bobbin that fits in a bobbin case, hold the bobbin in front of you so that the thread end is on top and the thread is going away from you, and slide it into the bobbin case. Feed the thread through the right openings in the bobbin case. When you pull the thread end the bobbin should turn clockwise.
Never hand-wind bobbins. Instead, use the accompanying bobbin winder which is attached to most machines,bobbin casings must be oiled regularly to prevent problems with the bobbin turning properly. The bobbin, when inserted properly into the bobbin casing, should spin counter-clockwise when thread is pulled.
Check the way your machine is threaded. Completely un-thread your sewing machine and re-thread it. Remember to always thread your machine with the presser foot up.
Check the bobbin and be sure the bobbin is threaded correctly and that the bobbin case is correctly threaded. Be sure the bobbin is in the bobbin case in the correct direction.
Always watch for bobbin wear, especially on the plastic type of bobbins. If the edges of the plastic are showing abrasions, the size of the bobbin has changed and may be the culprit. Although the size change is minute, it allows the bobbin to wobble in the case and changes the tension.
Dec 19, 2010 | Husqvarna Sewing Machines
How do you load the bobbin properly?
Well you may please follow the steps below -
1. Remove the bobbin from the sewing machine. Note: whether you have a drop-in, front or side-loading bobbin on your sewing machine. A drop in bobbin will load from the top, may be via a removable bobbin case cover near the machine-fed dogs. A side or front loading bobbin needs to be loaded into a removable bobbin case under the machine.
2. Choose the right size bobbin for the sewing machine.
3. Wind thread onto your bobbin. Your sewing machine should have a standard thread spool to hold the thread and a short, squat post wide enough for a bobbin.
4. Put the thread and empty bobbin into position on your sewing machine. Wrap the thread around the bobbin to start it. On most machines, disengage the needle by turning the smaller hand-wheel on the machine toward you. Push the bobbin post into position, securing the bobbin into place. Press gently down. Thread should begin to wind neatly onto your bobbin.
5. Break the thread, push the bobbin post back into an inactive position and remove the bobbin. Tighten the hand-wheel. Thread your sewing machine again if necessary before loading the bobbin.
6. Remove the bobbin case cover and put the bobbin into position. The thread should slide through a catch on the bobbin case and up through the cover.
7. Access the bobbin case for a front or side mount bobbin. Lift the catch and remove the removable bobbin holder. Put the bobbin into the holder and run the thread through the holder, bringing it to the front. Lift the catch and slide the bobbin holder back into the case. Hold your needle thread gently forward with your left hand and turn the hand-wheel. The needle thread will pass down into the machine and catch a loop of the bobbin thread. Pull this loop up and slide both threads to the back before beginning to sew.
Good Luck!!
Thanks for using FixYa!!
Sep 22, 2010 | Euro-Pro Shark 60 - 384
I have Brother LX-3125. I am using it for the first time. How can I take the bobbin out of the bobbin case. The case has an empty bobbin snapped in.
the lx 3125 has a front loading bobbin case which must be removed by pulling the latch on the bobbin case and thereby pulling the bobbin case from the shuttle.
once you have the bobbin case in your hand, let go of the latch and the bobbin will drop out of the case. you can now wind the bobbin or replace it with a wound bobbin - make sure that the bobbin thread is threaded down the slot in the case and behind the tension spring, also the bobbin should turn clockwise when you pull the bobbin thread when loking at the bobbin in the case.
scott
Jul 26, 2009 | Brother Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
