Question about Ovens
My wall oven is making a constant unusual noise
At first i thought it was something to do with the timer- that i do not use.... It is a constant clicking or whirring type maybe timer like noise that is loud enough to hear throughout the house. It is driving me crazy! What could it be or what to do?
  • 30 Answers
Without a model number its hard to be exact. If your oven is older it will have a clock timer motor that turns the dials or flips the clock display cards. This timer has gears and bushings that will be annoying as they wear and start a vibrating hum or clicking-usually not worth tinkering with..it can be taken out and checked or replaced. Electronic timers of course don't have any moving parts to the timer, but have relays in the circuit to turn the oven on and off. They do not 'whir'. This is the likely issue.
Repost..let us know.
Posted on Apr 29, 2015
It is making a loud noise as if it is catching onto something it comes and goes sometimes louder than first time it started
I'm guessing your problem is the fan in the oven. To fix: 1. with oven cold, remove back wall fan cover in oven. 2. remove fan. 3. clean and lubricate. 4. install fan. 5. install fan cover making sure fan is not touching. If cover does touch fan, gently bend cover away from fan and install.
May 15, 2016 | Ovens
Constant beep beep beeb from Maytag
forum.appliancepartspros.com/oven...ranges-cooktops/5209-maytag-ove...
https://www.maytag.com/product-help
Jun 30, 2014 | Maytag 30" Built-In Single Electric Wall...
Replaced EOU43002X element, clock/timer now dead
Make sure there is power to the timer. Should be a fuse somewhere.
Mar 19, 2014 | Electrolux Ovens
De dietrich range cooker very noisy when oven on?
Have you checked the exhaust fans within the oven? These can make a lot of noise if something has come lose. They should be located at the top of your oven or on the back. I would check that.
Good luck
Dec 05, 2013 | De Dietrich Ovens
GE JBP45G oven display module keeps on showing ''PF'', whether I turn oven on or off.Have to constantly reset clock to make the ''PF'' message dissapear. My broiler element is not working,but why is ''PF''...
I can easily explain the "PF". It means your EOC or electronic oven control/timer is losing power for some reason, hence the "PF", for power failure.
I`d suspect the control itself is defective or at fault as they have built in transformer`s that can become faulty.
I would first insure your power supply cord is secure and in good condition in the wall or you don`t have loose wires going to the timer.
Hope that help`s move you forward, let me know if I can assist you further.
Good luck.
macmarkus :)
Feb 10, 2010 | GE Ovens
Kenmore electric wall oven will not increase in heat after the setting has been selected. The display is held at a constant 100 degrees; which normally increases as the oven heats up. There is a clicking...
the most common is the control board.you may have to contact the manufacturer for a new board,my supplier does not have a replacement board listed
Jan 23, 2010 | Ovens
The electric power to my house was temporarily interrupted, and since it was restored my Modern Maid wall oven has not worked. The timer and griller work, but the wall oven does not. Does the oven need to...
The timer is 110 volt, and the grill may also be . The oven, however, is 220 volt. Suggest you check your main circuit breaker box and reset the breaker set marked "oven" or something similar. This would be the exterior breaker box where power comes into the home.
Nov 14, 2009 | Ovens
Kenmore gas oven
after the gas stove have been on a while a loud whoosh that is a constant thing comes on. I thought it was getting ready to explode. I took seconds after we turned the gas off for the noise to stop. Any ideas what this coud be
Jan 09, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Oven makes a noise when I turn it on.
If it is a fan assisted oven , then it sounds like a noisy oven fan.
It could be a worn or dry bearing in the fan motor. if you open the oven door , you should be able to tell if it is the fan by listening to it carefully.
The other possibility is if it has a cooling fan in the back or on the top of the oven, it could also be that causing the prob, these are about the only things that could be making a noise, as there are no other moving parts that could make a noise.
PLz rate my solution.
Thanks.
Jan 08, 2009 | GE JKP30WMWW 27" Built-in Single Electric...
Oven Makes large bang sound when on
Hello it is time to have a tech out to change the glow bar for bake. When these parts start to fail they dont get hot enough quick enough.
Dec 23, 2008 | Kenmore 33169 Gas Single Oven
Ovens Logo
102 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
