Question about Radio Communications
How do I turn a 4 meter two way radio into a vhf tv transmitter?
  • Bogomil Bunja
    Bogomil Bunja Aug 14, 2016
    Hi. Mr. Millett can I use radio shack's vhf tv modulator with my 4 meter handheld two way radio? Thank you very much.
    Novelist:
  • 217 Answers
Depending on the frequency you want to transmit video on, you would have to modify the synthesizer to produce RF on that frequency. That may or may not be easy. Then, you have to build a wide band modulator (DC to 6MHz) that can modulate the DC voltage to the final RF stage. If you want audio as well, you would have to build another modulator at 4.5 MHZ (or whatever your audio carrier frequency is for your TV standard) and add this to the video signal.
Check the ARRL or the RSGB HAM Handbook for more information.
Doing this modification will not be easy!
Posted on May 02, 2015
  • Andrew Taylor
    Andrew Taylor Apr 29, 2016
    message from this nutter a year on!
    Chris Millett I want to know. If I want to turn a 4 meter handheld two way radio into a vhf tv transmitter, can I use radio shack's tv modulator?
3 Suggested Answers
  • 773 Answers
SOURCE: my cobra 29ltd cb radio will power on and recieve
I am assuming you have called out for a radio check and not gotten a reply, or even better tested it with friends radio. Just because the meter doesn't mover doesn't mean that its not transmitting.
So as long as you tested it with another radio, and it is not transmitting it could be any number of things. If you have never had antenna tuned so the swr is low, or your swr was high for a long time, your final transistor is most likely blown.
TX switching transistor could be blown, trace could be gummed up.
If your ant light is coming on, the is a problem with your antenna. Could be disconnected, and that can lead to a blown final.
At any rate, your problem most likely requires a tech. Take it to a repair shop.
Posted on Oct 01, 2009
  • 607 Answers
SOURCE: I have an Icom v-8000 radio.The TX is very good with 75 watts out-put. But have nothing in RX.No signal and no audio.
What you have is an amateur band radio, which requires you to be a licensed operator to use it. It is possible that the frequencies have been removed from the eeprom prior to your purchasing same.
You can have Rx only frequencies programmed by an authorised 2-way workshop, but until you become a qualified amateur operator, you will not be able to get Tx frequencies programmed.
For licensing info for Amateur operators visit www.vk6wia.org.
Regards,
Peter
Posted on Mar 04, 2013
How do I turn a Wouxun kg-699e 5 watt 4 meter handheld two way radio into a vhf tv transmitter?
You cannot.. The transmitter wont take that much of a band spread that a television signal needs, there are issues with feeding video into a circuit tuned for audio and the IF section wont handle it.
Jun 04, 2016 | Radio Communications
It can't be done. You can't turn an audio receiver / transmitter into a video transmitter. Give your head a shake!
Plus if you want to transmit anything especially video over air, you have to be fully licensed and registered.
Apr 29, 2016 | Radio Communications
? new bp 200 replacment for bp 199 will not operate my ic t8e radio
The IC-T8E is the Icom VHF / UHF Amateur (or "Ham") transceiver capable of wide-band AM & FM receive and 6 meter (50Mhz - 54Mhz) , 2 (144Mhz - 148Mhz) meter and 70 centimeter (430Mhz - 450Mhz) FM only transmit - when appropriately licensed by your country's communications authority.
RigPix Database Icom IC T8E
Any FM transmitter operating in those frequency ranges will be received and played thru the speaker - unless they are encoded with a squelch decode sub-audible tone or digitally encoded squelch control that does not match the one set to the IC-T8E. Program the squelch to be open or to match that of the transmitter so that the radio will play only when that particular transmitter is transmitting.
An FM transmitter operating in APCO25, DSTAR, etc. will not be decoded as these are digital signals that the ICT82 is not capable of decoding.
I was unable to locate any "BP200" radio you mentioned, so I can't comment on their capabilities or if they have an incompatibility in encoding, frequency, etc.
Mar 11, 2015 | Radio Communications
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
How can I make the 19DXIV VHF capable
There is no way to make that radio VHF capable, CB radio's operate in the AM band, and most, if not all VHF radio's operate in the FM band. CB radio's are not capable of VHF frequencies either, VHF is considered around 40MHz and above, CB radio's operate between 26.965 MHz and 27.405MHz that is considered 11 meter band HF. CB radio's are not broadbanded enough to cover anything that far away, expecially the newer radio's, as most of them are controlled via a microcontroller and PLL tuning circuit. the 19DXIV is a great little radio, but will never be able to operate in or even around VHF. sorry.
Oct 21, 2012 | Cobra 19DXIV 40 Channel Mobile Compact CB...
My radio will not transmitt but it receives just fine
Most problems with radios that receive but do not transmit are antenna or antenna wire/connector issues. It's easy to receive with a marginal antenna but transmitting requires a good working antenna. If you have a SWR meter or can get your hands on one, install it in line with the antenna and test for reflected power. Of course, make sure your TX light comes on when you depress the mic switch. If not, switch mic and try again.
Hope this is helpful! Reply if u can.
Oct 06, 2012 | Uniden Solara DSC VHF Marine Radio
Can this SWR be accurately be used for a boat VHF radio antenna? I have tied it and it seem to work but do not know if the reading are good.
Standing wave ratio is standing wave ratio. This meter is not reading based on frequency. It is reading based on the measurement of electrical energy. I see no reason why it wouldn't work.
Jun 22, 2011 | Astatic (PDC7) CB Radio
VHF transmit power
Hi, It is not typical but neither is there a problem with the radio. Transmit Power output is loosely dependent on the: 1. Frequency or channel you are transmitting. Normally, Marine Band VHF are calibrated for max (25 in your radio) at Ch16 or 156.800Mhz; 2. If the SWR of the antenna is not a flat 1.0, power tends to go down; 3. After some time, the TX side of the radio needs to be re-calibrated; 4. Power Supply - some radios will push max output only when powered with 13.8 and tends to go down when used with 12 volts. Hope this be of some help/idea. Post back should you need additional information. Good luck and kind regards.
Oct 04, 2007 | Garmin VHF-725 2-Way Radio
Radio Communications Logo
369 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
