Question about Pioneer VSX-405 Receiver
Is there a way to brighten up the LED display?
Unit works great but LED is very dim
2 Suggested Answers
crazyhcris82
  • 34 Answers
SOURCE: I have a DEH-P-4800MP installed in my boat. The
Hello
I cannot help you brighten the screen but I have a similar problem with my camera when I tape graduations and ball games. I have come up with a solution for me that can work for you as well. What I did was I made a small shade to put over it that works like an umbrella and makes it easy to read. See below \/
side view
} l l----Radio---------l l
} l l
} Shade ---->l l
If done so that the top and sides cast shade on the radio, you can clearly see the screen even in the sun.
Hope this helps
-Chris
Posted on May 03, 2009
Buick Rendezvous Head Up Display
not sure about that one but there is a dimmer wheel by the light switch. move it up and down to dim and brighten the dask lights/cluster. wheel may need replacing. also work the lights on and off switch manually to see if there every thing works smooth or hopes from dim to brite.
Feb 16, 2014 | Cars & Trucks
Display is dim
Hello Friends! This dimming vacuum display is either caused by a power supply failure with the control board, or a the filaments of the display themselves have started to wear-- similar to that of a bad light bulb. Either way, FixYourBoard.com can solve this problem. Contact them 512-355-1108 for more information. The photo below is from a double oven, but we repair single oven displays too.
Jan 16, 2013 | DCS WOS-227 Electric Double Oven
The display screen does not light up. You can see and use the icons.
1) The power supply for screen starting to fail 2) You must go to the repair shop
God bless you
May 09, 2012 | Zebra MC9060-G Handheld Barcode Scanner
LED on my Sony ICFC218 is dim
i found that if I repeatedly press snooze/date/sleep off (big button) it will change the dim setting 3 levels... dunno how many times but I press it like 20-30 times and it works
Dec 02, 2011 | Sony ICFC218 Clock Radio
Led display shut down when the detector detect an alert
You have the unit in dark mode. Press the Dim/Dark button again to get the unit to full brightness. THe unit has 3 levels of DIM. First the unit is at its full brightness, pressing the dim/dark button will dim the display and the unit functions normally. Press the Dim/Dark button again will futher darken the display but when the unit alarms the display is turned off and remain off during the alert. After the alert is over the unit waits 20 seconds of no alert to turn the display back on.
Mar 09, 2011 | DE-1740 Radar Detector
Dim LED display
As far as I recall, there is no adjustment. Typically the display area can be cleaned as smoke and dust collects on the plate. Remove the front panel and clean the inner surface of the plate. You may find that sufficient to resolve the problem. If not, then check the power supply for 5V and 12V. If the supply is low, the unit will still work properly, but the display can be dim.
Dan
Jan 22, 2010 | Nakamichi Audio Players & Recorders
Dim radio/cd player display
The Bulbs have blown you can get special bulbs from the renault dealer have to pull off to of dash to fit
Dec 04, 2009 | Aiwa CDC-MP32 CD Player
Front panel with the clock settings is dim.
The only way to brighten is to replace the ERC or computer
May 04, 2008 | GE JKP45 Electric Double Oven
I can't get the led read out to brighten?
Does the dimmer switch in your truck make nthe light in the radio go up and down? if not the instalation was not done properly and someone left off the dimmer wire. If that does work and the brightness does go up and down, you may have an LED or Two out on the radio. Good Luck
Mar 23, 2007 | Sony CDX-5090 CD Changer
59 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
