Polaris 2010 Sportsman 550 Logo
Justin Leppanen Posted on Apr 28, 2015
My 2010 polaris 550xp head lights won't turn on
Need help with my lights am trying to fix it but no luck can anybody help me I like riding at night
Zachary Messina
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 30, 2015
Zachary Messina
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
490
Points
Start by checking your fuses, andcheck wiring harness to make sure nothing came unplugged or any wires cut.
  • Justin Leppanen
    Justin Leppanen May 05, 2015
    well I found out why my lights won't turn on all 3 burnt out and I think it's weird why all 3 went out
My 2010 Polaris Ranger 400 has no power.
My Polaris 500 started quitting on me. It turned out to be corrosion on the left handle bar kill switch wiring. After repairing, I pulled apart many wiring connectors and filled them with dielectric (does not conduct electricity) grease to make them resistant to water and corrosion.
Sep 17, 2017 • Polaris ATV
I have a 2010 polaris iq touring 4 stroke turn the key and nothing happens not even a try what could it be
Dead battery .,? Pull charge,.,or replace.,.go from there .,. First Try jumping it to even see if it fires if it dose then you know u need new battery...
Dec 19, 2016 • Polaris ATV
The 4x4 isnt working on my 2010 polaris sportsman 500 ho.
Tony, sounds like a transfer case issue, have machine checked or scanned for error codes.
Check the attached links,Manuals and guides, Good luck with your Bike
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
ATV TROUBLESHOOTING AND MAINTENANCE
How to Diagnose Motorcycle Electrical Problems Dennis Kirk Inc
Service Manuals for Download in PDF
Why did lights go dim and battery died?
Search Results
    Battery Dead, runs but headlights dim - Polaris ATV Forum
    www.polarisatvforums.com > ... > Polaris Phoenix
    Jul 23, 2011 - Go Back · Polaris ATV Forum > Polaris Model Specific Discussions > Polaris Phoenix ... Two days later the battery was dead. ... run ok, but the lights weredim and they did not brighten with I rev'ed it up. ... Polaris ATV Legend. Polaris 2500 winch draining battery
    Jan 9, 2014
    No Electrical Power when Key is turned. New Battery
    Dec 18, 2013
    elctrical nightmare!!!
    Feb 19, 2011
    Slowly Losing Power Only when hot...
    Oct 13, 2010
    More results from www.polarisatvforums.com
    Headlights dimming - ATVConnection.com ATV Enthusiast Community
    atvconnection.com/forums/polaris/326484-headlights-dimming.html
    Apr 25, 2010 - The lights on my 99 Sportsman 500 go from bright to dim all the time and I ... did you check the voltage yet when they do thid to make sure it's still putting out ... The Rectifier is my guess, I rode my ATV with a dead battery for a ... Battery Help
    Sep 6, 2014
    dim lights at idle - Page 3
    Dec 6, 2012
    2001 400 4x4 (manual) electrical problem(voltage)
    Aug 17, 2005
    Rancher Ignition Problems
    Dec 10, 2003
    More results from atvconnection.com
    charging issues - Honda ATV Forum
    www.hondaatvforums.net > ... > Honda TRX
Feb 03, 2016 • ATVs
2answers
Just bought this bike had no manuals with it I need to know about checking and changing oil
PDF]Sportsman 400 H.O. Sportsman 500 H.O. - Polaris
cdn.polarisindustries.com/polaris/.../parts-manuals/9923420r01_lo_res.p...
... parts and acces- sories, available through our online store at www.purepolaris.com. Have ... 2012 SPORTSMAN 400/500 HO Owner's Manual. P/N 9923420 ...
Polaris Sportsman 500 HO Owner's Manual - ManualsLib
www.manualslib.com > ... > Offroad Vehicle > Sportsman 500 H.O.
View and Download Polaris Sportsman 500 HO owner's manual online. PolarisIndustries All-Terrain Vehicles Owner's Manual. Sportsman 500 HO Offroad ...
2011 Sportsman 400/500 Service Manual - Polaris ATV Forum
www.polarisatvforums.com > ... > ATV Repair and Maintenance
Apr 11, 2011 - Indy Red 2011 Sportsman 500 H.O. -Polaris rear rack extender -Ricochet a-arm guards -Polaris fender bag -Koplin hand guards w/mirrors Owners, Service, and Parts Manuals
Sep 14, 2012
2005 Polaris 500 H.O. ATP service manual
Aug 12, 2011
Service manuals
Nov 29, 2010
Service Manual
Sep 23, 2010
My 2010 polaris 500 ho dies when i let off the gas
Turn idle adjustment up, if stalling persist remove and clean carburetor.
ATV Service and Repair Manuals
2010 polaris 550 xp blows fuse when 4x4 is activated any suggestions on how to fix this
Check to make sure the proper rated fuse is installed. If so, then sounds like you have a dead short and I'm not a Polaris or electrical expert to really show how to troubleshoot that far into it. Good luck!
2answers
2010 polaris sportsman 800 efi 67 miles on machine ran fine for 65 miles now when i push snow for 10 to 20 minutes it acts like it is runing on 1 cyclinder after i shut it off for while it runs fine my...
something is overheating, remove one sparkplug at a time and check for spark, be careful not to burn your self. Try 2 new plugs good luck
Jan 05, 2018 • Polaris ATV
7helpful
4answers
2004 polaris sportsman 700, shuts off while riding.
I have a 2004 700 carb that shut off while riding and then would start up 3-5 minutes later after many nights working on it Ifinally figured it out no help from any dealer. There are 2 circuit breakers under the front rack mine were very rusted, Replaced both never had the problem again. My situation was always only when the lights were on.
Hope this helps
Aug 07, 2009 • Polaris ATV
Top Polaris ATVs Experts
john h
Sean Wright
Sean Wright
ZJ Limited
ZJ Limited
Are you a Polaris ATV Expert? Answer questions, earn points and help others
