My washing Machine has suddenly stopped filling with water when turned on;the cycle continues and even spins but still no after.Any suggestions?thank you
The water intake valve may have failed
some machines have hot and cold some cold only
a few things can cause this
you need too first isolate the water supply and remove the two or one intake pipes from the machine
inside the valve {outside at the pipe screw on}
is a plastic screen
you need to use a pair of plyers and pull it or them out and clean them
if this fails them perhaps the valve solenoid coils or coil have failed
or worst case is the controller board drive circuit for the solenoid and perhaps the solenoid also has failed
so using a multimeter set too 20K ohm range
you can unclip the wires from the valves and check the coils
are a circuit should show something between 5K and 15K
ohms
so...
my guess is the solenoid intake has gone open circuit {common issue}
or the bad one is both the valve and driver on the control board both have failed caused by shorted turns on the valves solenoid
good luck and lets see
please post the result
and remember if you need parts get them from ebay
fixer guy charge way over the odds for spares
Posted on Apr 28, 2015
AMD 121 won't shut off, or change cycles. Continuously "hums".
Did you try just unplugging from the wall outlet, and let sit for 15 seconds and plugging back in. Sort of like a re-boot on the computer? Just a suggestion.
Jun 30, 2014 | Ariston Technologies AWD 121
My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Hi, my washing machine isn't working in cold/cold mode but will work in hot/cold and warm/cold. Meaning that water will not come out at all. I even started it in warm/cold and tried to switch it over to...
    My bet is that your cold water screen is plugged...
    If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
    Washing Machine Problems No Water
    Washing Machine Fix Washing Machine No Water
    heatman101
    Aug 31, 2010 | Frigidaire Washing Machines
    Won't stop filling. When I go through the cycles it continues to fill until I reach the final spin cycle then it will start draining and spin out.
    Two common problems for this simptom:
    If water stops filling when you disconnect the washer:
    Change the pressure switch.
    If water keeps coming in after you disconnect the washer:
    Change the water valve.
    GOOD LUCK MY FRIEND
    Aug 30, 2009 | GE Washing Machines
    Washer will fill fill with water but doesn't start wash cycle
    it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
    Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
    Whirlpool AWO3761 stuck mid-cycle
    The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Simpson esprit washing machine
    put a new pressure switch in it
    Mar 25, 2008 | Washing Machines
    Asko Frontload wont stop running water
    you need a new inlet valve take off the top panel then you see the inlet valve follow the inlet hose
    Mar 17, 2008 | Asko W6441 Front Load Washer
    Washer continues to work even if water is not filled to top and even if i try to stop continues to spin
    A defective pressure switch can interfere with the cycles that depend upon the switch to indicate when water has filled or emptied from the tub. It can also result in underfilling or overfilling of the tub. The switch routes current from the timer control to the temperature switch and the water inlet valve when the tub needs to be filled. Once full, the pressure switch cuts the current and reroutes it to the motor on the timer control to continue the cycle.
    Dec 07, 2007 | GE WBSR3140DW Top Load Washer
    Washing Machines Logo
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
