Question about Royal Alpha 1000ML Cash Register
What does sec,next code mean - Royal Alpha 1000ML Cash Register
  • Royal Master
  • 1,780 Answers
The 1000ML is quite rare. Royal don't give out this info. I ended up sending my last few customers to this site:
https://the-checkout-tech.com/manuals/cashregisters/Royal_Alpha-1000ML_operation_and_programming_manual.html
Hope it helps.
Posted on May 02, 2015
What does diagnostic code lf mean
1blink/sec---normal, 2blink/sec--blown fuse--3bliks/sec--replace evaporator sensor,4blinks/sec--mode switch failure, replace board,5blinks/sec--pot. failure,replace board;6blinks/sec--bad thermostat input; 7blinks/sec--factory only;8blinks/sec--bad room thermostat. The blink pattern repeats every 5 seconds.
Jan 13, 2013 | Amana PTC153B35AJ Air Conditioner
I have voltage between the brushes for a sec. what does that mean, and what's next?
Hi:
You directed this question at me, but unfortunately this isn't my expertise and I am unable to provide you with a real solution at this time.
Hopefully one of other experts will be able to provide you with a real solution.
Thank you for using FixYa.
Jan 08, 2012 | Coleman Electrical Supplies
Select as master
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
IDE-0 means Pri master
IDE-1 means Pri slave
IDE-2 means Sec master
IDE-3 means Sec slave
single or master :::::
master with slave ::'::
slave :::':
black line between dots is plastic jumper
note the plastic jumper is ' located at the rear of the hard drive between the EIDE and electrical lead/s
Nov 14, 2011 | Samsung (SP0411N) 40 GB Hard Drive
EPIC MODEL MHWZ600TW00...no display, no power up. Have tested outlet and electricity is fine. Would love to have an error code to help, however, without display I am lost.
diagnostic test -- the washer must be empty and the control must be in the OFF state before pressing the touch-pad sequence to start the test. 1) close the door 2) select any one key (except PAUSE/CANCEL) and follow the steps below, using the same key): a) press/hold 4 sec b) release for 4 sec c) press/hold 4 sec d) release for 4 sec e) press/hold 4 sec 3) upon release, all console LED lights will turn on for 5 sec 4) if there are any failure codes, they will be displayed in the Estimated Time Remaining display. NOTE: This program recalls the most recent failure code first. 1) press the same key to advance to the next failure code. (if the console doesn't change then the same failure code was stored multiple times.) 2) if there aren't any more failure codes all the lights on the console will turn on for 5 sec 3) next the washer begins the diagnostic test 4) to cancel out of service mode press PAUSE/CANCEL. this exits you out of the program. **Hope this helps; got it off the manual for service technicians.... most likely you'll get an F28 code (Serial Communication Error -- the communication between the central control unit (CCU) and the motor control unit (MCU) cannot be sent correctly). We are having this problem now and just replaced the CCU to a tune of around $300 ($120-$150 for CCU part & repairman labor cost + call/diagnostic cost)... it still is not working so I guess we'll replace the MCU next. If that doesn't work then we'll have to get a new washer that's not a frontload. What a nightmare; wished we had done research on frontloaders. Good luck!
Oct 02, 2011 | Maytag EPIC MFW9700S Front Load Washer
How do I set the jumpers to make it a slave?
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to IDE-1 means Pri slave escape then press f10 to save to cmos to restart
you will have to have master with slave set up
slave :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
Sep 10, 2011 | Hitachi Computers & Internet
How do you connect the cables or jumpers?
the leads from your ((motherboard to your hard drive)) they might have a 40 pin on the hard drive or a sata they just push on to make a connection make sure they have a secure connection
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
? single or master :::::
???????????????? slave? :::':
hope this helps
?don't forget to vote
Feb 08, 2011 | Western Digital Caviar SE WD3200JS...
Is there a slave or master switch on the hard drive want to hook up a external hard drive enclosure
hope this helps
Jan 29, 2011 | Hitachi Deskstar 7K500 500 GB Hard Drive
What is the position of the link do I need to change to master/ slave etc
hope this helps
Jan 28, 2011 | BenQ CRW-5232W 52X32X52 IDE CD-ReWriter...
Hd western digital wd800jd - preciso do manual do hd. e tambem configurar jumpers. grato!
hope this helps
hope this helps
Dec 10, 2010 | Western Digital Caviar SE WD800JD SATA...
Need jumper settings for slave drive WD1600JS
slave :::':
hope this helps
Dec 10, 2010 | Western Digital Caviar SE WD1600JS...
Royal Alpha 1000ML Cash Register Logo
Top Royal Retail Supplies Experts
Patrick Tinashe...
Electroboy
Electroboy
Kevin.
Are you a Royal Retail Supply Expert? Answer questions, earn points and help others
