Question about Mitsubishi Tv Dlp Lamp 915p061010 For Wd-57733, Wd-57734, Wd-57833, Wd-65733
Dlp chip after replacing
I replaced the dlp chip and the white dots were gone but know the screen has vertical thin white lines and thick grays horizontal bars
    Master:
  • Mitsubishi Master
  • 687 Answers
You will need to pull the chip out & clean out the dust & other foreign particles that were allowed to fall in & lightly brush off the chip (with a very soft brush, again to remove dust & foreign particles.
Posted on Apr 29, 2015
Need dplclipfor mitsubishitv
I saw a video for this once. The problem is the DLP chip. It has to be replaced. Replacement DLP chips can be found online. The screen has white dots because some of the mirrors on the chip are bad. Be sure to have someone competent replace it. No soldering is involved. Book and manual will come with replacement. The DLP chip is delicate.
Mar 28, 2014 | Mitsubishi WD65737 65" DLP TV
White dots appear across the screen
if you have a samsung, mitsubishi, toshiba etc DLP the white dots are caused by stuck mirrors on the dlp chip. so the dlp chip will need replacement
Apr 04, 2013 | Televison & Video
After replacing the dlp chip in my mitsubishi tv there are vertical lines on the screen. any ideas?
i had the same lines on my 65' mitsubishi tv after replacing the DLP chip. after going back over everything i realized that the casinf that holds the chip in was not in the lock position. i took the chip out and replaced it then turned the little locking mechanism to the locked position. now my screen is perfect. hope this helps.
Nov 21, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
White vertical lines after changing dlp chip and lamp on Mitsubishi WD-65833. good picture in background.
had white dots on mine as well i changed the dlp chip and put it back together and got the white vertical lines i decided to check all connections and make sure the chip was locked in correctly
it was not locked in securely i reassembled and now problem solved picture looks brand new so always check connections before assuming its the dmd board
Aug 25, 2012 | Mitsubishi WD-65833 65" HDTV
White death DLP TV
White dots on your RPTV television are the result of the DLP chip being worn out. You can replace it very easily by buying a new DLP chip for just under $190 and installing the new chip. There is a very good forum over at fixyourDLP that offers tutorials for replacing the DLP.
http://www.fixyourdlp.com/2012/10/11/banish-white-dots-from-the-samsung-hl56a650c1-with-a-new-4719-001997-dlp-chip/
or for Mitsubishi
http://www.fixyourdlp.com/2012/10/02/install-a-new-4719-001997-dlp-chip-and-banish-white-dots-on-the-mitsubishi-wd-82737/
Jun 04, 2012 | Mitsubishi Televison & Video
Rca 61 inch dlp has vertical lines accross the screen , they come and go by themselves
Hi,If you are experimenting vertical lines ,color distortion,pixilation,or white dots on the screen you might be having an issue with the Dmd chip.This is how the DMD chip works: http://electronics.howstuffworks.com/dlp1.htm Basically the dmd chip is composed of around 2 million pixels that create the image on the screen.You will need to replace in order to fix your problem.Have a blessed one!
Feb 06, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
I have white dots on the screen of my hsl4266wx/xaa?
If these dots are only seen when the picture is on I would look for the Optical Block to be causing it. Are the dots in the same place each time you turn it on?
Jul 17, 2009 | Samsung HLS4266 TV
Mitsubishi Tv Dlp Lamp 915p061010 For Wd-57733, Wd-57734, Wd-57833, Wd-65733 Logo
198 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
