Question about Kenmore Washing Machines
Have a Kenmore washer/dryer combo. Model 96802/96804. How do I remove front washer cabinet? Investigating a leak.
Will be a coin or 5 has bashed around the pump
and cracked the housings
Posted on Apr 28, 2015
How do I disable dryer on a Kenmore washer/dryer combo model number 417.99160110 only washer works
You have to start by removing the top first then remove he front console which allows you access to the dryer drum etc
Feb 04, 2016 | Kenmore Washing Machines
I Have a combo kenmore washer/dryer model # 417.94712400 and I need to open the washer to inspect a water leak. how do I open this washing mashine.
Remove the 2 screws at the base first
If ya run a load with the front off to look for leaks remember there are moving parts
I recently worked on a dryer portion and took these photos
Jul 25, 2011 | Washing Machines
Kenmore Washer model # 11082692120 is Leaking as it is filling the tub with water. It is leaking at the base of the machine on both sides and in the front bottom. it was gradual at first now it is leaking...
The leak is likely coming from a broken drain pump or detached pressure hose. Remove the machine cabinet to access and look at these areas.
Unplug the machine then release the console from the top of the cabinet. Remove the screws securing the console then pull forward and up and lay it back on the hinges.
Disconnect the lid switch h
arness connector by pressing on the tab located in the middle and pulling it up.
The cabinet is attached to the rear of the washer
by two brass-colored retaining clips. Insert a flat blade screwdriver into the turned-up edge of the clip, located on both sides, and then pry back to release the clip from the slot in the cabinet.
Open and hold the lid while grabbing
the cabinet front opening then tilt the top of the cabinet toward you by pulling the cabinet away from the base. This releases the front and back slots of the cabinet from the tabs in the front and back of the base
Using the side of your leg and/or body
as a support for the front of the cabinet, carefully lift up the cabinet and set it aside.
Replace the drain pump(part number
3363394) if it's leaking. Pry the clips securing the pump to the motor off and remove the pump.
Remove the hoses from the pump and connect it to the new pump and install it back in place in reverse order of the removal steps.
Bring the cabinet to the front of the washer then slide the front bottom rail of the cabinet under the rail at the base of the machine then lay down the cabinet into position. Make sure the slots in the cabinet sit into the tabs at the base of machine. Reconnect the lid switch harness then push the retaining clips back down into position to secure the cabinet to the rear of the machine. Reinstall and secure the console to complete the repair.
Jul 16, 2011 | Kenmore Washing Machines
DRYER PROBLEM
When the pads on the front wear, it will make noise when running. They can be replaced. There is one on the top and one on the bottom rim where the drum turns. You remove the front to access them by removing the screws on the top. Post your model number for diagrams. It's usually stamped on a small tag in a visible location on your appliance.
Washer-Dryer- behind or on top of the control panel. Behind the door. On the lower front or side of the cabinet.
Mar 21, 2010 | Kenmore 94702 Front Load Stacked Washer /...
Leaks water
Probably a bad water pump. That is were the Kenmore usually leaks.
2 screws on the top panel right and left sides.
Remove these screws, tilt the control head backwards.
Remove the wiring harhess connector.
Remove 2 clips holding the cabinet to the back panel.
Remove the cabinet by pulling forward.
Pump is attached to front of motor.
Feb 21, 2009 | Kenmore 24642 Top Load Washer
Kenmore washer/dryer combo (Model# 41792702200)
I cannot remove the dryer drum from my Kenmore washer/dryer combo in order to remove the bearing, how do I do this???
Jan 31, 2009 | Kenmore 24032\24036 Top Load Washer
Removal of front cabinet panel of washer section
Should be two screws on each side of the bottom of the front panel. Takes those out and push the panel up and out. (There are two "tabs?" in the middle of the front panel that lock into the side panels, so you have to push up and then pull out.)
Jan 08, 2009 | Kenmore 98702 Stacked Washer/Dryer
Washer leaks from rear. The hoses are perfect.
Hi .If you look, the tub is leaning towards the front . Theres a counter balance spring that has fallen off. remove the cabinet, to gain access, and replace the spring
Dec 23, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore washer dryer combo " Washer drum leans to one side "
If this is a small combo the problem is probably one or more of the suspension springs has become detached. You need to get the washer cabinet off. take the panel between the washer and dryer off. then there are 2 clamps holding the washer top on. they are in rear right and left. Once you get the top off you will be able to take the front of the washer off. At that point you should be able to see the problem under the tub. In most cases you can reinstall the plastic shaft back into the spring by screwing them back in.. This is not easy but can be done.
Mar 03, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
54 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
