Question about Tablets & eReaders
How can my photos be saved my slate7 tablet charge part is damaged and I cannot get into it to charge the table
  • Tablets & eR... Master
  • 5,631 Answers
Are your photos on internal memory or SD? If it's SD, you can remove the memory. If it's intrnal, obvously the only way is repairing the connection. Presume it can be done without affecting memory
Posted on Apr 28, 2015
Charging and is not plugged in
You have a bad connection in your charging port. Sounds like you probably have some damage to it. You can use a small electronic pick and a flashlight to look and and move the connections around slightly on you tabled. Should be 3 to 5 small pins in your charging port.
Oct 16, 2015 | Tablets & eReaders
How do I move photos from my tablet to the SD card?
Download ES File Explorer. Locate the folder where the pictures are, long press each file or select all by default, copy and paste files from the table to the SD card within the tablet. Alternatively, you can connect your tablet to your PC and access it via the PCs file explorer in the same way you would enter files within your hard drive. Copy and paste the files or drag and drop from the table to your PC.
Sep 28, 2015 | Tablets & eReaders
The Tablet keeps shutting down, what can I do?
You probably have a loose connection at the power source on the tablet or your power supply is damaged. Have it serviced. If it is a cheap tablet try saving up also for a better tablet like a IPAD. IT IS VERY COMMON TO BREAK THE POWER CONNECTIONS ON TABLETS AND LAPTOPS. GOOD LUCK.
May 20, 2015 | Tablets & eReaders
How do I save facebook photo to my samsung tablet
Downloading photos from Facebook is pretty simple really. You should just long-press on the picture after which a menu will appear where you should be able to download it.
Another, bit longer way to save a photo is by taking a screenshot of the photo while it is full screen.
Oct 20, 2014 | Samsung Galaxy Tab 10.1 Wifi - Tablet -...
Why won't my table charge?
Will the charger fit any other device that you have? If so try to charge some other device. It appears that there are only two possible problems. 1 The charger is bad.- 2 The tablet is bad.
Read your manual regarding charging and how long the first charge should take.
Aug 15, 2014 | Irulu 7" 4gb Mid Google Android 2.3...
How to transfer pictures from tablet to pc?
use either the micro usb cable you use to charge it as a data cable (so basically your pc will think the tablet is an external hard drive or camera) or save your photo's onto a micro SD hard inside the tablet, then take it out and put it in a card reader attached/connected to the pc....or send all your photos (while online) to a 'cloud' or 'drop box' type account and then download from that account to your PC
Jul 16, 2014 | Hannspree T7 Series 13.3" Wi-Fi Black...
I replaced the screen on the Asus tf300 tablet. After reassembly it wouldn't charge. I replaced the internal charger cable because it had bad pins. Plugged in the charger and got two flashing orange...
Hi, it seems that battery is totally discharged, that could be the reason of dead table. It should be good if you could check the connectors where the internal charger cable is connected, maybe one or both are damaged too.
Oct 20, 2013 | ASUS Transformer Tf300t Tablet
My tablet wont charge unless turned on but battery is so low it wont turn on so cant charge it up.heeeeeelllllpppp
You Power Cord must be bad. If you cannot get on the laptop by using just the power cord, then the power cord is bad and needs to be replaced. Also it sounds like you've been operating off your battery since the power cord is bad, but now the battery is dead because the bad power cord was not charging it.
Get a new AC Adapter and Power Cord. Or it could be that the pin where you plug the power cord into the table is damaged or broken.
May 15, 2012 | Archos 101 Internet Tablet 16GB 10.1"...
Ipad will not power up
Does its battery is full or not? Try to charge it then turn on it, if not work, suggest you send it back to Apple , they will be helpful. Or get a new table pc if it was damaged.LOL
Jan 08, 2012 | Apple iPad 32 GB 3G Tablet PC
My HP Compaq 2710p will not charge
I PUT A HEAT SINK FROM A CPU AND ATTACHED COOLING FAN TO THE HEAT SINK
AND THAN ATTACH IT TO THE BLACK OBLONG LONG RECTANGLE BOX LIKE OBJECT AND IT WILL STAY VERY COOL AND ALSO SAVE THE BATTARY FROM OVER HEATING AND DAMAGING THE BATTERY.
RODGANDYSR
Mar 07, 2009 | Compaq 2710p Tablet PC
Tablets & eReaders Logo
26 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
