Question about Kenmore Ovens
Only "start" button not responding on the oven model 326b1230p002. Other buttons working fine.
Control panel Circuitry provided by Torisan Tottori Sanyo GE Model 164D4171P028
  • 213 Answers
SOURCE: GE JRS04BOW3BB Will not turn on.
turn the broil on high by itself wait a couple min. and see if it comes on. if it does the your bake element needs to be replaced or you may just have a burned wire where the bake element plugs in. just remember to turn the breaker off to the oven before trying to pull out the element
Posted on Nov 25, 2007
Sea Breeze
  • 4654 Answers
SOURCE: GE Profile JT952 Touch Pad Button Issue
Try this link
http://www.fixya.com/howto/h155060-dreaded_f7_error
Posted on Mar 28, 2009
localwonder
  • 6784 Answers
SOURCE: Kenmore gas Range -- Control Panel not working
Hi. your assessment is correct. when you have normal operations with the stove top and the control panel is blank or non operational, this will confirm either a wiring harness issue or a dead control circuit board. The wiring harness can sometimes become lose or the connectors can become corroded but, in this issue, i am sure its the ECB(electroninc control board). In this case, you will have to replace the board it self.
Please rate and god bless:)
Posted on Apr 16, 2009
localwonder
  • 6784 Answers
SOURCE: Control panel doesn't light up
HI, this issue concerns the touch pad(control board led). This will happen in certain models. it could be some minor corrosion within the wire contact clips that are not allowing the proper current to illuminate the led that is used to light the specific button or, it could be a minor circuit issue within the control board as well.
i recommend inspecting the control panels wire harness contact clips that are behind the actual control board. make sure they are not corroded or lose. if they are lose or corroded, i suggest replacing the entire wire harness. this could be the possible reason for some of the lights that are not illuminating during operations.
If the wires and contacts are in good condition and the harness is in good condition as well, this could be an internal control circuit board issue, concerning the LEd lights. they may have burned out due to the age or heavy usage.(heat related)..
Posted on Apr 20, 2009
localwonder
  • 6784 Answers
SOURCE: F1 error/touch panel not working on GE Monogram Dual Oven
Usually, the F1 means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be canceled, replace the oven control (also called clock or ERC), touch pad, or both.
I recommend a service call for this repair.
Posted on Jun 03, 2009
Cadco oven wont start ...give error code pre and por
It looks like the controller board is shot. Get on the web with Cadco and request a complete parts list for the controller circuits. Meanwhile, pull the cover off the stove controls and blow in clean, dry compressed air over the circuit boards. Chances are you have a short or two in the circuitry!
Dec 15, 2012 | Cadco Ovens
I just moved into a new apartment, I can't find the user guide for the whirlpool gold gas oven, don't know how to operate the oven, none of the button works on the control panel, not even the start...
You can go to whirpool.com then click on owner center and download a manual BUT YOU MUST HAVE COMPLETE model number which usually on inside of oven door or in storage drawer
Jul 27, 2011 | Ovens
Start button wont work on whirlpool oven control panel
If it's just this one button not working, or a group of buttons (depending on the model) it could be due to:
1. Door switch or temperature sensor problem preventing the oven from "starting" -acts like the button is bad but is being locked out by some other problem sensed by the control board.
2. Bad keypad
- We sometimes see a problem due to oxidation or corrosion on the keypad membrane connector. If you are comfortable working on such things, we posted a procedure that you can use to clean off the oxidation. Here's the link, check under the "Ovens" section:
http://fixyourboard.com/techzone.html
3. Control board problem.
We repair these at www.fixyourboard.com
If you want to email us the full model number at info@fixyourboard.com maybe we can help you pinpoint the problem.
Oct 05, 2009 | Stoves Ovens
Jun 02, 2009 | GE Monogram ZET3058SHSS Stainless Steel...
My start button on my kenmore built-in oven w/microwave won't wor
my kenmore model number 911-47699100 oven doesn't work. Everything except the oven and broil works--cleaning, all timers, start button, etc. All that happens when you push start is about every 30 seconds, two relays can be heard making and breaking kind of like a click then immediately a clack. No error codes appear. Replaced sensor but that didn't work. Any help would be appreciated.
Mar 30, 2009 | GE JKP30WMWW 27" Built-in Single Electric...
I need the squematic wiring GE 24" Built-In Gas Oven
I have the same problem -- did you ever get this question answered?
Feb 28, 2009 | GE 24" Built-In Single Gas Wall Oven
The upper oven door is locked shut and will not release. All lights are off on the display panel and the oven does not respond when any setting are pushed. I have reset the circuit breaker several times...
im to assume that this happened while self cleaning, sonds as if you have had a high limit thermostat go bad adn has shut down oven function( depending on model there is also a fuse inline with the main control panel to protect it from the heat/ power surge, unit will need to be pulled out to acess fuse behind the unit
Jul 09, 2008 | Whirlpool RBD245PDS Electric Double Oven
Double 27" oven Model No.911.48489 show F9,later beeping
The F9 error message usually means that the oven temperature is above 600 degrees F. Check that the fan is operating. Make sure that it is not blocked. Make sure the vent areas are not blocked. There could also be a welded relay contact or high resistance in the oven sensor leads or connections.
Oct 02, 2007 | GE JTP85 Electric Double Oven
F4
The F4 error code generally means a bad temperature sensor or a short in leads to the sensor. Under room temperature conditions the resistance should be approximately 1100 ohms. If you are not comfortable around electrical apparatus and/or don't have an ohmmeter, you will need to contact an appliance repair technician. GE typically places a trouble shooting guide in the top of their ovens behind the touchpanel. You will have to remove three screws in the bottom of the touchpanel to open the panel. Be sure and turn off the power before opening the touchpanel!!!
Aug 23, 2007 | GE JTP85 Electric Double Oven
Ovens Logo
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
