Question about Health & Beauty
Jazzy Jazz 1120. Dead battery. How do I unlock the wheels?
kmhabdullah
SOURCE: Wiring Diagram Pride Jazzy 1120
mso 9]> Normal 0 false false false MicrosoftInternetExplorer4 mso 9]> mso 10]> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} There are two levers just under the seat at the front. Pull the forward and to right to lock position, which will release the gear so that the wheelchair can be move about without any electric power. Bear in mind though that releases the gear, still too heavy to push as normal wheelchair. Give a go, to find out for yourself.
Posted on Aug 28, 2009
  • 103 Answers
SOURCE: Jazzy wheel chair
When a chair sits for a long period of time ( four weeks or more) without being charged, the batteries die. To help you with the freewheel mode I would have to know what model of Jazzy it is.
Posted on Nov 16, 2009
  • 692 Answers
SOURCE: what are the best batteries
andre Your Jazzy uses 2 Group 24 batteries and I would get MK batteries they are very good and can last 3-4 years if taken care of. Follow their charging recommendations and you should get great service from them Hope this helps you
Posted on Sep 18, 2010
  • 692 Answers
SOURCE: my hand controler on my
GAdams You need to count the number of flashes. The number of flashes will give you the flash code or error code. IE: 3 flashes pause 3 flashes pause etc. = left motor short If you have your owners manual it should list the flash codes and what they mean for your chair. If not you can contact Pride Mobility @ 1-800-800-8586 and ask for Tech Support. If medicare paid for your chair the they will pay most of the repair cost. Contact the provider where you got your chair to see if they can repair it or refer you to a service Company that can. Hope this helps
Posted on Oct 08, 2010
  • 8404 Answers
SOURCE: if my battery failed on
There should be a lever on the back rear to put the device in neutral. On the other hand, gel cell batteries are generally available at auto parts stores. Why not just get two new ones and replace them if they are done for?
Just a thought.
Posted on Mar 19, 2011
Testimonial: "BRILLIANT THANK YOU "
Jazzy 1120
"Cuts out" is not enough info. Check all connections for tightness, full battery and light codes.
Apr 29, 2013 | Pride Mobility Products Used Jazzy...
I have a Jazzy 1120 When I turn it on all the battery lights flash rapidly any suggestions
How many are flashing? There are 10 lights, if all are flashing (3 red, 4 yellow, 3 green) that indicates Code 10 and high battery voltage.
Apr 03, 2013 | Pride Mobility Products Used Jazzy...
Jazzy 1120 changing controller type?
The 1120 usually comes with either of 3 different controllers: Pilot, Remote Plus or Europa. They function similarly but the setups are a bit different.
Apr 02, 2013 | Pride Mobility Products Used Jazzy...
My jazz 1120 battery does not stay charged long, why?
Usually the age of the battery is the issue. You can only get a couple of years out of a battery in your application, way shorter than you would think.
Jul 24, 2011 | Pride Jazzy 1113 Power Chair
If my battery failed on my 1120 jazzy chair can it be pushed maually to get home or not
Just a thought.
Mar 19, 2011 | Pride Mobility Products Used Jazzy...
What are the best batteries for my jazzy 1120.
Sep 18, 2010 | Pride Jazzy 1113 Power Chair
Jazzy battery lights will not light and the car will not move.
check there is power in the batteries, if so check all wiring for breaks loose fittings, fuse trip switch etc, failing that it may well be the controller, hope it is not that as they are not cheap.
Jun 20, 2010 | Pride Mobility Products Used Jazzy...
Apr 28, 2009 | Pride Mobility Products Used Jazzy...
Health & Beauty Logo
108 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
