Question about Dryers
Doesn't come on at all, new start button still nothing. how to bypass clock/timer mech just to start the dryer. fuses all test good.
  • Dryers Master
  • 5,323 Answers
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!!
Posted on May 04, 2015
  • 1 more comment
  • Thomas Maxwell Tarrant
    Thomas Maxwell Tarrant May 04, 2015
    hi johnny, thanks but tested all that except the motor since it worked perfectly, not noises, no indications of anything beyond electrical/electronic failure. just didn't start one day in the middle of chores.
    it appears the timer's at fault, of the 3 wires, red, black, blue, the red & black connectors are somewhat charred (a little black) like they burned somehow.
    was wondering however what caused it so when i get around to buying one, i'll see how long it lasts. that's only cuz the landlord is cool and i don't want to leave him a non-running dryer.
    a new dryer's already on the way.
    i did however just want to bypass the timer to assure it's the culprit.
  • Jorge Rendon
    Jorge Rendon May 04, 2015
    Oh ok sorry couldnt help u more as for the time issue more than likely moister got in and shorted the wires
    thanks though. be cool
Kenmore HE5 dryer won't start
Several different problems could prevent your dryer from running. Make sure that the door is firmly closed and hold down the start button for a couple of seconds to start the dryer. If you hear a click from the control board then the door switch and the control board are likely okay. You could have a blown thermal fuse or a broken belt in the dryer. To check these components,unplug the dryer and remove the bottom front service panel as shown in the first image below. With this panel removed, you can tell whether the drive belt is broken. If the drive belt is okay, I recommend checking the thermal fuse. This fuse is located on the blower housing as shown in the second image below. It will have light blue wires attached. To test the fuse, remove one wire and measure the resistance across the leads of the fuse with a volt/ohm meter. You should measure near zero ohms of resistance (continuity). If you measure infinite resistance, then the fuse is blown and will need to be replaced. You can verify that this is your failure by taping the contacts of the light blue wires together with electrical tape to "bypass" the thermal fuse. Reassemble the dryer and see if the motor runs with this fuse bypassed. If it does, then this verifies that the blown thermal fuse prevented the dryer from running and that this was the only failure. NOTE: Do not continue to run the dryer beyond this brief test with the thermal fuse bypassed. This component must be replaced. It is an important safety feature of the dryer.
You can order a new thermal fuse from the Sears PartsDirect website. The part number is 3392519.
May 01, 2012 | Kenmore HE5 Electric Dryer
Kenmore 110.86870100 Has power to the power block but the start button will not start the dryer
Get the schematic and look at the timer. there are two wires that you can jump across and verify that the timer is bad by bypassing it all together. If all your checks tested good then the timer is bad. If you have any doubt order the part from repairclinic.com because you get a full refund even if you put it in and it does not work
Feb 08, 2012 | Kenmore Dryers
DRYER DOESN'T DO ANYTHING. I HEAR CLICKING IN THE TIMER AREA WHEN HOLDING THE START BUTTON DOWN AND NOTHING ELSE. IS THERE A WAY TO BYPASS THE TIMER TO MAKE SURE THAT'S THE ISSUE?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 03, 2011 | Maytag Dryers
Electric dryer wont start. Door switch turns light on/off. Timer is heard ticking. Press start... nothing. Tried bypassing all parts in the back.. Thermostat, thermal fuse... still nothing. Could it...
heatman101
Aug 27, 2011 | Kenmore 62602 Electric Dryer
Dryer will not start. thermal fuse ohms thru as does the heating element and the thermal cutoff ect. can the motor be jumped to bypass the timer? if so how ? i have no manual or schematic, any idea how to...
Try first by jumping out the door switch. then push the push to start button.
if still dont go on jump out the push to start button.
i replaced one not to long ago.
if still wont start it will be the motor or the timer.
Timer usually you can hear it running making a clock like sound. motor you have to ohm it out and see if it is good. a service manual will have the correct ohms with blk to white, to red, to blue etc. i dont have em
its only in the book. you can do the door sw. and push to start yourself. but sfter that you must decide to i want to spend $300 FIXING THIS ONE OR $300 ON A NEW ONE???
Mar 27, 2010 | Whirlpool LER5636P Electric Dryer
WP leq7030kq1 electtric dryer. Won't start, push
If the thermal fuse is ok then the door switch or door switch actuator maybe.
Feb 05, 2010 | Whirlpool LEQ7030KQ Electric Dryer
Dryer won't start bypassed all thermal fuses and swithes put new motor in and still nothing
turn breaker off and push off hard till you can feel and hear the click to reset then back on then test timer
Aug 23, 2009 | Dryers
Dryer not turning on
most likely its the timer it has electrical contacts built on the timer that allow it to start its cycle if the timer has bad contacts it wont allow dryer to come on
Jan 21, 2008 | Dryers
Kenmore drier
PULL PLUG FIRST!!
Remove back panel.
Find white hi-limit fuse located near center on blower housing. Remove 2 wires and tape them together. Try now. If it starts, replace hi-limit. DO-NOT RUN DRYER WITH UNIT BYPASSED!! This is for testing only. You need to clean vent and remove four screws holding filter housing at lower left. Pull housing out at bottom. Reach up inside and remove lint. Re-assemble unit and test with new hi-limit fuse.
Nov 14, 2007 | Estate TEDX640JQ Electric Dryer
Dryers Logo
65 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
