Question about Maytag Dryers
Wont' come on at all, replaced start button with new unit, nothing still. was wondering how to bypass the timer control just to start the dryer.
  • Maytag Master
  • 5,323 Answers
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
wont' come on at all, replaced start button with n - 25670562-hed3japwagud3imxwy3n1koj-1-0.jpg
25670562-hed3japwagud3imxwy3n1koj-1-2.jpg wont' come on at all, replaced start button with n - 25670562-hed3japwagud3imxwy3n1koj-1-5.jpgt/uploads/images/25670562-hed3japwagud3imxwy3n1koj-1-5.jpg" alt="25670562wont' come on at all, replaced start button with n - 25670562-hed3japwagud3imxwy3n1koj-1-9.jpg"h_mi" />
Posted on May 16, 2015
I have a fridgidaire heavy duty that wont start. imnotsure if its the start button but the dryer is recieving power and so is the plug nothing wrong with the breaker.
Hello megang665 - If the unit is inoperable there are a few possibilities that can be causing this issue. First, try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. If it proves to be ineffective, contact a professional to move forward accurately. The unit could have a faulty door lock, timer, pump, or control board not communicating correctly.
Dec 29, 2012 | Frigidaire GLEQ2152ES Electric Dryer
Electric dryer wont start. Door switch turns light on/off. Timer is heard ticking. Press start... nothing. Tried bypassing all parts in the back.. Thermostat, thermal fuse... still nothing. Could it...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 27, 2011 | Kenmore 62602 Electric Dryer
Dryer will not start. thermal fuse ohms thru as does the heating element and the thermal cutoff ect. can the motor be jumped to bypass the timer? if so how ? i have no manual or schematic, any idea how to...
Try first by jumping out the door switch. then push the push to start button.
if still dont go on jump out the push to start button.
i replaced one not to long ago.
if still wont start it will be the motor or the timer.
Timer usually you can hear it running making a clock like sound. motor you have to ohm it out and see if it is good. a service manual will have the correct ohms with blk to white, to red, to blue etc. i dont have em
its only in the book. you can do the door sw. and push to start yourself. but sfter that you must decide to i want to spend $300 FIXING THIS ONE OR $300 ON A NEW ONE???
Mar 27, 2010 | Whirlpool LER5636P Electric Dryer
My whirlpool dryer wont start.
check the door switch and also the push to start button. Timers will advance even if the unit is not on
Mar 30, 2009 | Dryers
Maytag performa dryer quit working
Check your breaker first and then the wiring. Check power coming from the timer next. With a load and resistance that you had, you could have tripped one of the breakers.Since you have bypassed the thermal fuse, it probably is the timer switch.
Jan 26, 2009 | Maytag PYE2300AY Electric Dryer
DRYER ONLY WORKS BY HOLDING DOWN THE TIMER BUTTON
You need to replace or repair the timer control, this is not a faulty motor control unit.
You find parts by entering model number here.
Dec 15, 2008 | Dryers
WON'T COME ON AT ALL.
you have not said anuthing about ohming out the start knob,and have you checked both legs on the power cord are getting 120 volts each?let me know what you find-mike
Sep 09, 2008 | Whirlpool LER4634J Electric Dryer
Dryer not turning on
most likely its the timer it has electrical contacts built on the timer that allow it to start its cycle if the timer has bad contacts it wont allow dryer to come on
Jan 21, 2008 | Dryers
Dryers Logo
120 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
