Question about Uniden DECT 6.0 3-Handset Cordless System with Answering Device and Caller ID/Call Waiting - DECT2080-3
No dial tone, unplugged all 3 phones to reset, now saying out of range searching
  • 86 Answers
SOURCE: Uniden TCX805 Cordless "loses" dial tone
Sounds like the switching mechanism that creates the link is stuck. When you answer your phone, you allow the voltage to complete it's path and you either answer the phone or you hear dial tone. If that switch is stuck closed, even though you hung up the phone, the connection is still alive. When you try to pick the phone back up later, the connection is still closed, but your phone has already passed it's "if you would like to make a call" message and you hear no dial tone. Unplugging the power to the phone resets this switch and all is good again.....that is until it gets stuck again. I have seen this problem with phones after a near lightening strike at the house. Sounds like you need to get a new phone as I don't think this is repairable.
Posted on Jan 20, 2008
  • 50 Answers
SOURCE: we can't get dial tone on any of our 3 uniden phones
The base station must be plugged into a live jack. Take a known good telephone and plug into the wall jack. If that checks good use the same cord to hook up the base. If the base still doesn't work, pull the cord loose and look into the jack hole on the base and see if the wire connections are out of alignment. If they appear straight then the base is in need of going to a repair shop.
Posted on May 28, 2009
dnewcombe1
  • 1564 Answers
SOURCE: uniden powermax 24 out of range
Check the line comming into the main handset base. Make sure it is not cracked or your cat hasn't chewed through it.LOL This sounds like the most likley solution. Try hooking the main phone line to an ordinary old fashioned touch tone phone with a wired handset and if that is working then the problem lies in the main base of your new phone. It could be as simple as reprogramming the base.
Posted on Jul 24, 2009
  • 183 Answers
SOURCE: phone says searching and no dial tone
it is not plugged into the phone jack on your wall? It is searching for dial tone and it isn't getting any, maybe the line cord too?
Posted on Dec 11, 2009
SOURCE: UNIDEN EXP7900 NEW BATTERY CHARGED,
I have a Uniden DECT 6.0, 2 handset phone. I charged the batteries twice for at least 15 hours. I usually unplug the base at night and plug it back in in the morning. Both the phones lose their charge overnight. My old Uniden phone never lost its charge. Is this because the new batteries are smaller than the old ones? Are the batteries bad? I bought this phone from Ebay who said this was a brand new phone, box never opened. Thank you.
Posted on Jan 02, 2010
My phones are not working at says out of range.
When a cordless phone says "Out of Range" or "Searching for Signal", there are a number of possible issues (assuming you are close to the base). 1) The handset battery may be low and not taking a charge. If the battery is more than a year old (including time spent in storage), replace the batteries for both handsets.
2) The base may not have power or an incoming telephone line signal. Check that the power adapter is warm (power to the base). Use another phone cord (and a second phone (preferably corded) to check for a dial tone). If a second phone has no dial tone, see below for diagnosing a phone line.
3) The phone base has lost the registration information for the handsets. A way to reset the phone is to unplug the power cord (from both the wall outlet and the phone base) and the phone data line and unplug the batteries from all handsets. Wait several minutes then plug in the base power and data cords and then reconnect the phone batteries. You may want to re-register the handsets. This is done by putting the handset in the main charging base for 20 seconds when the handset is fully charged. (See your phone manual) The phone was made by Thomson Electronics for GE; the manual is available here: http://www.home-electronics.net/USER-GUIDES/25952_DOM_EN_CL_IB.pdf .
4) The phone base or handsets are not transmitting or receiving the signals properly. This means that the phone needs repair or replacement. If it is under warranty, contact the manufacturer. Otherwise decide if the phone is worth the repair costs.
If you have no dial tone at the jack where the base is connected, check another phone jack on that line. If you still have no dial tone, find where the phone service comes in. Then open the service box and if the service is fairly new, plug in the RJ-11 test phone and listen for a dial tone. If you can't plug in the phone cord or there is no dial tone, contact your service provider. They will test and fix any outside problem.
If the problem is inside, inspect the visible wires. If you have a DSL filter as part of the inside wiring, check/replace it. If only one jack has a problem, open the faceplate and fix any loose wires. There are two faceplate designs - screw terminals or keystone jacks. For the screw-type, the conductors must be stripped and secured under the screws. For the keystones, the conductors are not stripped but pressed into the terminals with a punch-down tool. This tool is available at many home improvement stores in the wiring aisle. See http://www.lanshack.com/wire_phone_jack.aspx for a diagram of the wiring.
If the problem is not in a visible part of your wiring, you may want a professional to find and fix the problem. Your telephone provider will be willing to do the work for a fee.
I hope this helps.
Jan 20, 2012 | GE 25952 Cordless Phone
Both phones say searching when I push on says connection but no dial tone then says out of range
Re-Register a Handset to the Base
1. Remove Handset Battery.
2. Reconnect battery while holding down "*" and "#" key.
3. Then press the right upper key under the LCD.
4. Press the "End" key.
5. Wait a few seconds and then the phone will be ready to register to the base.
Apr 10, 2011 | Uniden Lands Phones
Can not get the phone to get a dial tone it says searching or out of range
really silly but the base somehow got unplugged,problem solved
Nov 24, 2009 | Clarity C410 Cordless Phone
No dial tone - brother 1030 fax phone
I'm sorry to say that you've done all you could to assess the problem, and "yes" it is a modem problem
Apr 23, 2009 | Brother FAX-1030e Plain Paper Thermal...
Dropped calls, and no dial tone on Panasonic Dect 6.0 phone
I am sure that is a service related issue and no the phone itself.
Apr 26, 2017 | Panasonic KX-TG1033S Cordless Phone
No dial tone
I have no dial tone on my phones. I can receive calls and my answer machine works ok. I plugged another phone (an old phone) and I have a dial tone on that phone, but not on the new ones
Apr 13, 2008 | GE 28112 Trio Cordless Phone
Uniden DECT 6.0 3-Handset Cordless System with Answering Device and Caller ID/Call Waiting - DECT2080-3 Logo
122 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
