Question about Frigidaire Washing Machines
Model #FFLE2022MW0 Frigidaire washer leaking water at bottom
Washer leaks at bottom
Pump housing cracked by coins or wires leaking
or rubber somewhere
if you isolate the water and waste and mains
the lay it over on the side away from the soap drawer
it wont leak
and you can access under it
and investigate where the water is coming from
bet you its the pump plastics cracked ,..
i would do this now dont use it for now
and fix it
this type of error can cost you a controller board ...
you can save lots of time by checking round the door seal of rubber issues inside its folds etc
but i still think its the pump or some rubber hoze loose
see in being one of the intakes or perhaps the drum from drawer rubber ... so
lay it over and check
no chance of fload if you lay it over on the side away from the drawer with the door closed
Posted on Apr 28, 2015
My washer is leaking water
Frigidaire washing machine leaking water from bottom
www.washingpoll.xyz/frigidaire-washing-machine-leaking-water-from-b...
I on the middle hard non porous ( keep girl does washing machine front you ...Detergent liquid reviews drain new combo amana washes click. ... Drum sensor cleanedfilter years of rash bad skin pull disconnected washer dry rings magic left.
Dec 30, 2015 | Washing Machines
Frigidaire Washer Model FAHE4044MWO is leaking from the bottom, what should I check first?
Hello Cicl, I appreciate your post!
If you have a water leak from under your Frigidaire washer it could be a possible problem with a faulty water hose, water inlet valve, or drain pump. Either one of those components could be causing a drain within your washer. Since it could be any one of these underlying issues I would suggest seeking assistance from a professional technician to get a proper diagnosis and repair. I hope this is helpful. -Matt
Oct 17, 2014 | Frigidaire Washing Machines
Water leak from the bottom of washer
Hi friend, thank you for your post!
I understand that water is leaking from the bottom of your Frigidaire washer. There are many components that could cause a washer to leak the bellow (gasket), leak from drain hose, drain pump, or water valve. Since it could be any one of these underlying issues I would recommend having a technician come out to diagnose and repair your appliance. Hope this is helpful. -Matt
Jul 30, 2014 | Frigidaire Washing Machines
Frigidaire washer model LAFW70000LWO leaking from bottom of washer
would suggest cleaning out the coin or filter trap to see if debris has clogged the drain lines. This may or may not be specifically for your model, however these are generics instructions that I found.
To check for a restriction in the drain line you will need to follow the steps below:
1. Unplug the washer
2. Pull the washer out to tilt it back so you can
reach the screws below the front panel and
remove it. (You will need something to catch
the water once the hose is removed from
the bottom of washer)
3. Loosen the bolt with the sliver clamp on the
bottom of the washer. The water will begin to
come out while your loosening the clamp. (Do
not remove any GREEN clamps)
4. Once the water is out, you can stick your hand
inside the hose to clean it out.
If any proves to be ineffective contact a professional so they can properly and accurately diagnose the unit for repairs. Unit could possibly have a damaged/cracked tub, a leak in the drain lines, or the water valve.
Dec 05, 2012 | Frigidaire Washing Machines
Leaking water
Yes, Remove two screws rrom bottom of washer using puddy kinfe release the top panel bysliding in at crack between top panel and body the water pump is at the bottom left and may be leaking from hoses the other posiabilty is the selonid that controls the water inlet may be leaking
Aug 14, 2010 | Frigidaire FWSB5700DS Top Load Washer
Water is leaking from top loading frigidaire crown washer
go on line find model number on the back of washer
you should be able to fine seal kit and yes a new seal kit well do the job you well have to remove the drum unclamp hoses and remove you may want to have repairman come do this.
Nov 25, 2009 | Washing Machines
Leak. My wife noticed water leaking out bottom of washer
Try cleaning the drain plug. I did this in about 5 minutes and was amazed at how much debris was clogging up the drain. Mine was accessible by removing two screws at the bottom of washer and removing panel. Drain plug was right there and easy to unscrew. Be sure to have a cookie sheet or other pan to catch the water that will flow out. Once that drain is clear, thumping should stop because water can flow down the drain easily.
Aug 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer model LTF2940FEO. As
remove lower kick panel and check for leak at door boot and drain pump.
Apr 23, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer is leaking water at bottom
You should look at the machine's bottom first- try to find out from where water leaking from. In most cases it is the pump.In such a case it should be replaced. Good luck!
Jun 14, 2007 | Frigidaire FEX831CS Top Load Stacked...
Washing Machines Logo
61 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
