Question about Tablets & eReaders
How do I turn it on, there seems to be no power button
    Master:
  • 301 Answers
It has to have a power button, take the unit out the case, otherwise they sold you a brick.
if you still can't find it try going to the store with it.
Posted on Apr 28, 2015
Help to reboot my tablet
Hi, you need to perform a factory reset, follow these instructions:
  1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
  2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
  3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
  4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
  5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
  6. Use the volume buttons to move up and down through selection in this menu.
  7. Using the volume down button, scroll down to "Wipe data/factory reset"
  8. Tap Power hard key to select option.
  9. Scroll down to select "Yes, delete all user data".
  10. Tap the power button to select. Wiping and formatting data will take a few minutes.
  11. You will return back to the Android recovery screen menu.
  12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Dec 31, 2014 | Tablets & eReaders
Wont start up
Please make sure the tablet is charged for at least 4-6 hours. Also, make sure the correct button is being used, oftentimes we hear the back or home button has been used in error. If the issue persists, you can try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
Support Troubleshooting Guide
Mar 23, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
My samsung galaxy tab 2 has a frozen screen I can't even turn it off help
Here is how you fix this problem: Hold both the power button AND the volume UP button down at the same time for about 5-10 seconds it should restart. You don't lose any info doing this.
Mar 26, 2013 | Samsung Galaxy Tab 101 Tablet...
Can not unlock my coby tablet
it seems like that your tablet's touchscreen panel has a defect, to get the full functionality of the touchscreen panel it should be replaced...
Sep 03, 2012 | Coby Tablets & eReaders
My galaxy tab screen has blanked out and i cannot get it to do anything
option 1. Plugin in Power Cable Then Hold Volume down + Power button for 10 to 20 secs Your tab will Turn OFF. now turn it on using simple power button it shd work perfectly option 2. do one thing Turn Off Your Tablet
-> Hold Volume Button and Power button for 3 to 5 Secs -> You will see a screen with android and triangle with exclamation mark -> you will also see 4 lines of writing in blue. -> use volume buttons to navigate to 3rd option, use home to select it ( warning this will erase your system data if need please take backup) (memory card is not affected) -> now navigate to 1st option saying " reboot to system" use home key to select it.
I hope this will fix things
Mar 31, 2011 | Samsung Galaxy Tab Tablet PC
My Kindle 3G seems to have frozen.
Amazon recommends the following steps. As I'm sure you have already tried the power switch, try starting from Step #5 to do a hard reset on your Kindle.
Source: Amazon.com
  1. Unplug Kindle from power adapter or computer.
  2. Slide and release the power button. The LED light that surrounds the power button will display green for two seconds.
  3. Shut down Kindle by sliding and holding the power button for five seconds. The LED light will blink three times. Wait for the screen to go blank, then release the power button.
  4. Turn on the Kindle by sliding and releasing the power button.
  5. If Kindle is still not working, you can perform a hard reset by sliding and holding the power button for 15 seconds.
  6. If Kindle is still unresponsive, try charging Kindle before trying to restart the device once again.
  7. Make sure you have the latest software version available installed on your Kindle. The latest version is available here: www.amazon.com/kindlesoftwareupdates
Please let me know if I can assist you further.
Regards,
KYTechnology
Mar 01, 2011 | Amazon Kindle 3G
Satellite R10 Wont turn on
clean off the heatsink and CPU fan.
Feb 23, 2008 | Toshiba Satellite R10-S802TD Tablet PC
Tablets & eReaders Logo
26 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
