My machine's cycle won't start. Lights all come on but there is a lock symbol which keeps flashing, bottom left of screen. ? the door but no matter how 'positively' I shut it - it doesn't go off.
The door 'interlock' has failed
it heats up to seal a door
when it cools down it opens
{either a bimetal switch and coil or a thermister and coil}
replace the door interlock
two screws and a plug ...
method
isolate mains supply and water
open the door
take the top off {slide two screws}
take the two screws out of the door catch machine side
reach down and unclip the interlock
pull the plug
put a new one
and replace the screws
check the door catches ok
if so
plug it in
place it to drain and spin
one the spin completes your sorted
and its a common fault
Posted on Apr 28, 2015
Light flashing won start
Common error with front loaders is the door interlock. Make sure the door is positively closed. A gentle open hand push at the erea of the door lock often gets a machine started.
Regards
John
Jan 30, 2014 | Kenmore Elite 45986 Front Load Washer
Door won't lock / cycle won't start
Check if the lock is binding or the door switch is not being operated.
May 19, 2013 | Asko W6221 Front Load Washer
Whirlpool washer won't start. Not a water problem. Door lock lift on or at times flashing. Think it's something to do with the door or panel.
At the right end of your panel you will find the 'end of cycle' symbol, to unlock keep this depressed for 3 seconds, this is the child lock feature. You do it again, and the machine locks.
Click if helped......
Apr 20, 2013 | Washing Machines
Cannot get rid of the lock symbol and it won't start even b4 the symbol appeared?
This sounds like a faulty door lock switch or a faulty main electronic logic board.When the door lock switch is faulty or opened it pauses the main board to allow the machine to stop working without switching off completely so that you don't lose the cycle when opening the door during a wash.But there should be a button to push to release the door lock when starting up the machine.if that doesen't work then there is a breakdown of communication from the door lock switch to the main logic board and visa versa if the board is faulty.If your machine is more than five years old then those two problems are the most common in those machines. Have a technician check it out.
Apr 15, 2013 | Washing Machines
Door won't open on whirlpool duet washer frontload
Press the cancel button twice to cancel the error code. There should be an error code flashing -- for example 'F02'.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My son put a load of laundry in and forgot the hot water heater was broke when he turned the machine on. It wouldn't run and the door is still locked. We tried unplugging it, holding the cancel butt
Remove the lower panel by taking out the screws at the bottom. Unplug washer. Then reach up inside to the bottom of the door switch and pull down on lever to unlatch the door. Try running machine again after plugging back in.
I have a bosch washer model wfk2401. i cannot get
door lock mechanism must have jammed in open position. unless the door gets locked, the wash cycle would not start. check the electrical connection in the door lock and physically verify the lock operates when commanded
Mar 19, 2010 | Washing Machines
Wash cycle will not start door locked led flashes
sound like water has been splashed over circuit
board. dry out and replace any damaged components.
Mar 15, 2009 | Hotpoint WMA31 Front Load Washer
Kenmore he2 front load washer
remove bottom panel open pump port and ck for foreign objects lean washer toward rear wall this will help help keep water toward rear and reduce flooding floor might try opening door first and dipping out as much water as possible with bottom panel removed reach up to lock area there is a tear shaped plastic peace pull it down to release door
Jun 02, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
