Question about Audiovox VE926 9 in. Portable Television
Help with the display. it does not work anymore.
  • ROD GANDY May 07, 2015
    you mite call around to tv repair shops or even call motorhome electronic audio installer that repair units. swap meets, the boy scouts where i live put on electronic swap meet once a month. just some ideas if you love it and want it good luck rod
My player doesnt work anymore display is not working and it doesnt turn on anymore? what do i do?
Hi, thats look like its the power supply,
a zener diode and some caoacitor or its could be the fuse
if the fuse is dark burn inside thats indicate a good short circuit
on the primary side off the power supply,
hope that will help
regards Alan
Oct 09, 2010 | Pioneer BDP-51FD Blu-Ray Player
PS3 won't display or play discs
one thing is to make sure that that ps3 is set to the right setting for display it might be set to HD or RCA but you need to make sure it is set right.there is a way to reset the display only with out seeing it but i don't rember it you can find in on sonys web site
May 10, 2010 | Sony Video Game Consoles & Games
Philips mt1800 displays problems with startup
You can't fix that anymore, your windows copy is now "corrupted or impotent".
If it won;t work on safe mode, probably your system files are at a bad condition.
Recovery disc might get you to startup again, but if ever there is a virus it will just happen again.
I advise you to reformat if you don't have anymore files to save.
If ever there is, well... maybe get a linux live CD so you can browse through your hard disk again.
Hope I helped, cheers.
Feb 15, 2010 | Computers & Internet
Nokia 6500s
hi i have a nokia 6500s.... it used to work ok. but now i cannot play games anymore it says supportive file nothing to display.... i tried getting new ames but it still says the same and another thing my calculator disapeared too
Oct 22, 2008 | Cell Phones
Switch between Screen Icon not working
try fn + f4, if it doesnt work, try to find driver for keyboard, that might work
Oct 16, 2008 | HP Pavilion dv6000z Notebook
Display Canon sd450
The backlight display of your camera is now defected cause of high vibration when you felt out and bangs into the ground. I don't see if this replaceble but you still has an option contacting the canon.
Thanks
Feb 28, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
"PROTECT" in Display
Probably your output amp. is worn out
Feb 19, 2008 | Sharp CD-BA300 CD Shelf System
DVD player does not play
Display of my DAV C450 does not work
Jan 13, 2008 | Sony DAV-C450 System
Synchronising to ipod
I'm glad you solved it yourself. It would be helpful to post the solution to help anyone else with the problem.
Jan 01, 2008 | Samsung YP-K3 MP3 Player
Audiovox VE926 9 in. Portable Television Logo
478 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
