Question about Cell Phones
Remove the battery as for asi go - Cell Phones
    Master:
  • 301 Answers
Posted on Apr 28, 2015
HI.Is there a battery in the watch asi cant get it to start
Yes just about every watch made now runs on battery power as has been the case for many years now. Any watch service center can replace the battery for you.
Jan 03, 2016 | Watches
Inicia y se apaga
By giving power, starts and then turns off, and so on
Try taking the charger out, and also remove the battery. Wait 10 seconds, replace and try again.
Trate de tomar el cargador, y tambien retirar la bateria. Espere 10 segundos, vuelva y vuelva a intentarlo.
Feb 09, 2014 | Sony VAIO Computers & Internet
How to remove the head light cover on a ford focus 2001
Headlight covers do not come off to remove the headlight asy, remove the headlight lower retaing bolt and remove the grill then the headlight asy.
Apr 07, 2010 | 2001 Ford Focus
Headlamps not working. Power at the fuse. Bad
no,usally bad headlight switch in the steering column.e asy to replace. remove screws around column. undo positive battery cable. unscrew combination switch with torx. unplug connectors and remove. reverse to install.
Jan 10, 2010 | 2004 Chevrolet TrailBlazer
How do you change the rear blinker lights? 2004 Ford F150
open the tail gate you will se 2 scerws remove them now pull the light asy out just pull twards the rear like if the truck is facing north pull south it will come out but you need to pull hard now you have the tail light asy in your hands twist the light socet and then you will see the light pull the light out from the socet
Dec 29, 2009 | 2004 Ford F150
How do I replace a fuel pump on a 1995 ford aerostar
drain all the fuel you can from the tank, SAFELY using proper saftey equipment, place the vehicle on jack stands, disconnect the battery, place a jack under the tank, remove fuel cap, remove 3 screws holding filler neck to the inside of fuel filler door compartment, remove tank straps, remove driveshaft, lower tank slightly & remove fuel neck, wires, fuel couplings, lower tank & remove from vehicle. Carefully remove locking ring from the tank where it holds down the fuel pump asy, remove pump asy & replace components as needed, reassemble, check for leaks, road test vehcile
Nov 02, 2009 | 1995 Ford Aerostar
Rear right side window(glass)stuck half way.does not work
does this happen from both the Driver's & RR passenger's window switch?
if from both check for power at the window motor. If no power at the motor for only one switch, replace suspect switch. if power at the motor, remove motor from regulator asy. & and motor again in both direction. If motor and switches good, replace the regulator asy.
Oct 04, 2009 | 1998 Ford Contour
1994 RCA P52753 Rear Projection
Sounds like the screen asy has failed causing the color to change from black and white,turn your color all the way down and see it the picture is green,blue,or red,if so the asy is bad or the tubes are getting alittle weak,the asy is in front of the set behind the speaker grill,there is a access panel to remove and the asy has 6 controls to adj.,only move the ones that are marked screens below them,this asy is black and is only 4 inches square,do not move any adj. on the tubes
Mar 06, 2008 | RCA D52W19 52" Rear Projection Television
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
